Question about Samsung RS263TDWP Side by Side Refrigerator
Samsung refrigerator not cooling and is frozen behind vegetable bins
Cleaned condensor coils and fan
  • 108 Answers
SOURCE: Refrigerator freezing up and fan catching
From your information Bill it seems the defrost system has failed. There are several componants that could cause this. First check the defrost heater which is located on the evaporator. You will need to pull the plug and let the ice melt completely first. Store your perishables elsewhere.
With an ohmmeter, check for continuity across the defrost heater. With all due respect, if this is confusing you need to call a service tech. If you have continuity across the heater, check the defrost thermostat which is a round disc fastened to the evaporator.
Finally, look for the defrost relay. It should be found somewhere on the lower rear of the refrigerator. Check for power to the relay, and on the outlet side. A wiring diagram located on the back of the unit will help you find the correct wires. All of these parts should be available from your local refrigerator parts supply, or check with Samsung online to order. Be advised Bill that this is not a simple repair, but if you have some electrical understanding, you can do it.
Ray
Posted on Nov 16, 2008
tborn6
  • 700 Answers
SOURCE: fregerator not cooling
check out the refrierator defrost sensor for the refrigerator side. the connection may not be making a good contact. open up the refrigerator evap section and behind the lights for the crisper is the connections. be carefull because the evap may be frozen up and the styrofoam wil break if its frozen up. thaw it out first with a shop vac blowing air out.
Posted on Mar 07, 2009
  • 9 Answers
SOURCE: The refrigerator side won't cool and the coils are
if the coil keeps freezing over it could be a few things, if the fan is working, it could be a problem with the defrost cycle, defrost bi metal, defrost timer, or defrost heater would need checked to determin which componet is bad.
Posted on Mar 15, 2009
relaga58
  • 158 Answers
it can be fan defect or fan switch or timer as well as thermostat defect causing build-up of ice jamming the fan
Posted on May 06, 2009
SOURCE: Samsung Model No.RS2533SW Refrigerator
My ice maker has stopped working. Water is not flowing to the fridge at all
Posted on Aug 09, 2009
KENMORE TRIO 2004 59675523400 REEFER/FREEZER NOT COOLING
it should not be the compressor as the bottom is only not cooling.
Jun 23, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refereigerator Model GBE18JBRWW, bottom freezer Not cooling properly. I opened the condensor coil sections and noticed the frozen ice. Disconnected the refereigerator for few hours and the refereigerator...
You have a defrost system problem. The coils with the ice are the evaporator. If the fan is working inside either your defrost timer or defrost heater assembly has failed. you may want a tech for this
Jun 22, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Inside strip of fridge is very hot. cleaned out behind fridge and the coils, etc. fan is barely moving/not moving. any suggestions???
Replace the fan. The strip has a freon line running behind it, and when it is hot, this tells us that you have a dirty condensor, bad condensor fan motor, bad evaporator fan motor, defrost problem, or a freon system problem. When you say your fan is barely moving, I am assuming this is your condensor fan motor, which sucks air through the hot freon lines in the condensor coils, and cools the freon off. If it is barely moving, it can't cool the freon. In some brands a slow moving condensor fan can be caused by a bad main control board. Good Luck, Appliance Specialists
Jan 28, 2010 | Refrigerators
My refrigerator and frezzer are not cooling. i cleaned the coils. the condensor pot is vary hot is this normale? i unpluged it for about a half hour while i cleaned all the dust out. and pluged it back in...
If the condensor coils and compressor motor seem too hot, make sure that the compressor fan is turning. This is what removes heat from the coils by pulling room air across the coils.
The fan is usually at the back of the refrigerator down low. If it's not turning, you will need to replace the fan motor.
Oct 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ge tpx21pr side by side refig/freezer Freezer is not cold enough
If your unit is NOT a static condensor, (the type with cooling fins and tubes on the outside of the back of the unit) If the door seals are okay and sealing properly, you might need to service the forced air condensor components located at the rear lower area, usually behind a fiber board cover. Remove the cover and look for dust on the condensor fins and fan blades. If clogged, carefully brush, vacuum, or blow the dust out, opposite the direction of the fans natural air flow direction. (You don't want to lodge the debris further into the condensor fins.)..Be sure to unplug the unit first.
Jul 31, 2009 | Refrigerators
How do I install a condensor fan on an older refrigerator, top freezer, bottom fridge. The repairman told us the part we needed and we have it but can't tell how to get back panel off or do we go from...
The condensor fan cools the coils and compressor behind the refrigerator . The evaporator fan , fulls ait over the inside coils into the refrigerator section and is located inside the freezer (inside).
Jul 19, 2009 | Refrigerators
I REPLACED THE DEFROST ASSY COMPONENT ON MY JENN-AIR REFRIG, BUT STILL WON'T COOL ENOUGH. fREEZER WON'T FREEZE side by side jcd2289
Make sure both fans are running and check that your the coil is not frozen. The coil is behind the freezer panel.
Jul 02, 2009 | Refrigerators
Can't find refrigerator coils/ cooling issues
There're two coils ,the condenser coil wich you already clean (also make sure the condensing fan motor works properly and the fan blades are also clean).The other is the evaporator coil wich is located inside the freezer behind the back wall cover.
Apr 21, 2009 | Refrigerators
It is the compressor that has failed. The hum is it trying to start and the following click is the overload protector opening. What is the temperature where the refrigerator is located? Allow the compressor to cool down before trying to restart it. If it still does not restart after it has cooled off it is done.
May 17, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Samsung RS263TDWP Side by Side Refrigerator Logo
70 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
