Question about Home Security
I need the code to remove parent contorl
Some one put and code on my tv for parent control and i don't know the code to remove it i can't watch none of my channels
  • 322 Answers
Ask your mum !!
Posted on Nov 19, 2009
    Problem Solver:
  • 71 Answers
Id try calling your cable company and see if they can fix it.
Posted on Jan 22, 2009
Need to know how to remove the red key on tv and code
When a red key appears in the lower left corner of your Apex television screen, the set's V-chip is engaged, preventing you from watching restricted content. You can override parental controls and reset your television's pass code with your remote.
Parental Lock
  1. The Apex prompts you to enter a 4-digit code when you set up parental controls. You can block programs according to their MPAA ratings or their content designations, such as V for violence or S for ****** situations.
Disabling the Lock
  1. You can override parental controls on most Apex models by simultaneously pressing the F and mute buttons on the remote control. If you own Apex models GT2011J or GT2011S, hold the remote's display button for ten seconds. The red key will vanish and the V-chip will unblock your program.
Override Codes Apex's default parental lock control code is 6688, so if you haven't set a new code, entering 6688 will remove the red key and unblock your program. If you've set a new password and forgotten it, entering 3308 will reset the code and unblock your program.
Sep 25, 2012 | Apex Digital Televison & Video
Need code for AT2704S Apex DIGITAL
Your Apex TV is locked by someway. To unlock it,
Apex TVs have parental locks that allow you to block certain programs based on
their rating. When this feature is no longer needed and you want your TV to display all programming no matter its rating, you must unlock your TV. Unlocking your Apex TV is done completely from your remote control and does not require any tools. The process takes less than 5 minutes.
• Press the "Menu" button on the remote control and use the arrow buttons to scroll down to the "Parental Guide" option, then press the "Enter" button.
Type in the default parental code "6688" if you have not set your own code. If you have set your own code, type it in. If you set your own code and forgot it, override it by using "6688."
Use the arrow keys to switch the parental lock to "OFF." This allows all programs to be viewed no matter the rating. Press the "Exit" button on the remote and start watching all your channels.
If you want more details, click this link. Pull up older posts there.
Sep 25, 2012 | Apex Digital AT1308 13" TV
My akai tv is locked,don't know the code
Most TVs have a parental control lock that can be set to prevent children from watching specific television shows. In order to activate or deactivate the controls, you need to know the four digit security code or parental lock control password. If you forget the number you chose or if the lock gets set accidentally, it is still possible to unlock the TV.
Instructions
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
Call the technical support service number in your owner's manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure that you have the model number and serial number of the TV.
Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on.
Sep 13, 2012 | Jensen Q2749J 27" TV
How can i remove my parental code and my secret question and i dont know them for Nintendo DSi
How to Remove Parental Controls:
Use the information below to remove any Parental Controls that have been put in place.
  1. On the Nintendo DSi Menu, use the stylus to select the Settings ("wrench") icon.
  2. Select the right arrow twice to reach the third page, then select "Parental Controls."
  3. Select "Yes," to change the parental controls.
  4. You will be prompted for your 4-digit PIN.
    • If you know the PIN, select the empty text box and enter the PIN using the on-screen keyboard, then select "OK" to continue.
    • If you don't know the PIN, select "I forgot," then select the  empty text box for the answer to the secret question and enter it using  the on-screen keyboard.  Select "OK" to continue.
    • If you don't know either the PIN or the secret question, the  Parental Controls will need to be reset.  Please call 1-800-255-3700 for  assistance.
  5. Select "Clear Settings," then select "Yes" to confirm.
Jul 19, 2011 | Video Game Consoles & Games
I have a 32" Dynex
Need the model number to look up the parental control steps. you will need to access the control settings in the Menu, the channels option. the TV will prompt you for a password, if you don't know it, there is always a default you can use listed in the manual. You can turn off Parental controls in here.
May 11, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
I'm trying to play a dvd but it says that parental controls have been set. I know the passcode is 8888 but when I type that in on my remote (universal, not original) it doesn't even recognize that I've...
Sorry u have to buy an original remote for this.The universal remote,will not be response by the tv for tthis function.Try website like Remotes.com to buy an exact to the original remote.
Oct 21, 2010 | RCA 20F510TD 20 in. TV/DVD Combo
Fpa lock on how do i get this offf
hello Lock/Unlock Parental Controls
Selecting this option lets you lock and unlock parental controls settings
using a password.
If you do not lock parental controls, none of the settings for V-Chip,
Channel Block, or Front Panel Block will take effect.
If you forget your password, press the MENU button, then select Parental
Control
(the password entry screen appears). Simultaneously press and
hold CH+ and VOL+ on the front panel for 8 seconds. Parental Controls
unlock and the Parental Control menu appears. You can enter a new
password by locking the Parental Controls again.
Front Panel Block
Selecting this option lets you block (disable) or unblock (enable) the TV’s
front panel. The remote still tunes to any channel. When using this as a
Parental Control method, remove access to any remote that is capable of
operating the television while you have the front panel blocked.
Don’t forget to lock parental controls after you change the status. If you
don’t, the front panel block will not take effect .if this don't work get back to me i've got manual good luck
shaun
Sep 19, 2009 | RCA R52WH73 Projection Television
How to erase parental control code
I finally found out how to reset the V-chip password on this princess DT1350-P Tv. All you have to do is turn the TV on and turn to a channel that doesn't prompt the V-chip password (even if it's snowy) and hold down the volume (down -) button on the main unit while holding down the number "0" on the remote control. It might take a few tries, and you might need to change the TV channel for some reason but if done correctly, either the TV will turn off, or the menu screen will pop up and ask if you want to set the vchip password, either way you should be able to watch your TV now! :)
Nov 12, 2007 | Disney DT1350-P 13" TV
Bought a TV and has a password i want to remove
When there is a parental code, you have to ring up your tv service provider for the code.
Sep 12, 2007 | Televison & Video
Home Security Logo
132 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
