Question about Kenmore 64902 Electric Dryer
Dryer won't turn on just ticks. Kenmore model 101.60612990
  • 3 Answers
Check start (button) switch
Posted on Jan 22, 2009
  • 34 Answers
SOURCE: Kenmore Dryer 70 series Problem:
Sounds like your door switch has gone bad. This is a very simple and ever so easy repair. It will require you to access the internal workings of your dryer. There are step by step instructions on this website of "how to open your dryer" that are really good. A quick search should locate them. Usually a dryer switch is just a couple of screws and a molex (special type of plastic molded electrical connection) or a few spade/wire terminal connections. Make sure the dryer is unplugged before you work on the internal areas or the control panel. Popping the top up is usually done with either a screw driver or putty knife. You should be able to see a small portion of (2) clips where the top meets the rest of the body in the front. A bit of effort is required to get these clips to release. Once open, you will probably have two screws--1 on each side at the top left and right just down a short ways from the top. Removing these should allow the front to come off. Be careful when you remove this. The drum usually rides on the front portion of the dryer and will shift down when the front is removed. Just make sure when you put it back on that it is seated where it should be. The dryer front/door section should lift up off hinges at the bottom. Some of these have screws that attach at the bottom front. You may have to remove these. Once you have the front door off, the door switch should be on the back of the front panel of the dryer. From there it should be a matter of a few screws. If you have a meter, you can check if for continuity. If it has none and the dryer door is still closed, it needs to be replaced. Look for the link for dryer access on here if your dryer is a bit different. A door switch is only about $10 - $20 dollars on line. Make sure you have your model and serial number handy. It is either on the back or on the inside of the dryer door/lip. Hope this helps.
Posted on Feb 05, 2011
SOURCE: Kenmore dryer will not start
This was over my head and I let someone else look at it. Found out some wires had burned. He replaced them and we are back in business again. Thanks for your input. It saved me a few hundred dollars.
Posted on Jul 23, 2008
SOURCE: Kenmore dryer not running
I have a 29" Kenmore electric dryer. Apx 4 years old. It runs but is not heating. What do I need to do?
Posted on Aug 03, 2009
SOURCE: How do i replace the belt and specifically the
Kenmore Dryer model 11062622101, Belt 529597 or any 92" 1/4 belt will do.I found an srticle which told me to remove the the lint screen and then the 2 screws underneath it. Then I took the back panel (unplugged the unit first) off and then detached the lint screen shute. Pull the top slightly towards you and the top will open like a car hood. Then I removed the two screws holding the front of the machine to the sides and took the whole front off. Just lay a broom handle under hte top near the back of it to keep it propped up. This is enough. The drum then can be removed. Just lift the drum out towards you. Then I bought the belt and the the appliance repair guy told me how to put the belt looped through the idle arm and on to the drive shaft. This is tricky and remember to not twist the belt. Give the unit a good vacuuming and wipe it down and it will last another 10 years. It now runs quieter and stronger than before.
Posted on Oct 12, 2009
  • 523 Answers
SOURCE: very old dryer Kenmore model nbr 86180100.GETS HEATSUP SHUTS OFF
check the vent
Posted on Apr 25, 2010
My Kenmore dryer ticks constantly (runs fine)
sounds like the timer running,put your ear to the timer dial to see
Jan 14, 2013 | Kenmore Dryers
My kenmore elite dryer model 110 63032102 won't turn on
Check the door switch. Push it by hand and you should hear it click. If no click is heard, replace the door switch with this part.
If the switch is OK, then the only other problem will be with the thermal fuse located on the rear of the machine. Here is a link to that part.
Oct 15, 2012 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer 70 series 66722690 - has power but won't start (no humming noise, no ticking noise from timer, and no light when you open door) nothing!
I would check the breaker before you go any further. Here are some things to remember when you do this. 1) The breaker for the dryer is generally located outside on the side of the house somewhere near the electric meter. Most 220vac breakers are, which include any electric range, cooktop, wall oven, etc. 2) When your checking the breaker, actually physically touch it. Sometimes breakers can trip a but the spring that actually pulls the breaker to off position is weak and by visual inspection would appear on. Just simply reach in and tap the bar lightly in the off direction. If it pops over to the off position, turn it back on then go check your dryer. If the breaker passes inspection, I would unplug the machine because there migfht be a short at the terminal block where the plug connects to the dryer. After you've unplugged it, remove the back and check to see if everything is ok. I have a strong feeling that you won't need to get to this point cause I'm betting on breaker.
Apr 30, 2012 | Kenmore Dryers
Kenmore model 665.13243 normal wash light is blinking and won't start the new cycle
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 07, 2011 | Kenmore 65924 Electric Dryer
My kenmore dryer just stopped working. the timer
the timer has internal cog teeth with works with an ecentric cam to keep the timer operating. the cam is working if ticking although a tooth appears to be broken keeping the timer to advance on its own
Mar 13, 2010 | Kenmore 63942 Dryer
My dryer won't turn on. I've checked the breaker,
need model number,sounds like thermal fuse is gone,dryer might need a clean out
Nov 03, 2009 | Kenmore Dryers
Ticking sound is the timer running--so it is not the problem unless a contact has failed or a wire has come loose.  Broken door switch, thermostat failed in open position, or clogged lint filter/exhaust vent/outlet would keep unit from running.  If you can hear the motor running but the drum is not turning then the drum belt is broken.
Jun 04, 2009 | Dryers
Kenmore 64902 Electric Dryer Logo
93 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
