Question about Western Digital My Book Premium ES Edition WDG1SU5000 500 GB USB 2.0 Hard Drive
Power For WD 5000H1U Drive
Have misplaced the power supply and need to knoiw what it takes. Need to know volts and amperage.
  • 3 more comments
  • rickwatts Jan 24, 2009
    Same problem, hope some kind person will copy off the supply specifications and an example of the brand name for all of us.
    RickWatts@juno.com
  • joemav57
    joemav57 Sep 11, 2012
    12 volts - 1.5 AMPS - 18 watts
  • joemav57
    12 volts - 1.5 amps - 18 watts
  • joemav57
    BTW, you can order one at Western Digital for $9.99 Make sure you have the model and serial numbers available
  • joemav57
    1 (800) 275-4932 Western Digital support toll free number
Http://support.moonpoint.com/hardware/power/adapters/
kevin
Posted on Jan 28, 2009
What volt adapter for WD 3200H1U-00?
Most external hard disks use a 12 volt 2 amp power supply. The modern ones are small and cheap. Be aware the power plug should be the same as the power plug on the old power supply. and the polarity also.
Jul 09, 2014 | Western Digital My Book Essential 1TB...
How can I get a replacement power supply?
What you are after is an AC adapter this model I found on ebay has 120 volts to 240 volts to 12 volts make sure the DC voltage output matches the Voltage of your hard drive. The current output has to be the same amount or larger in value. So if your drive needs 2A a 2A or larger value means it can handle the current load put on it by the Hard drive.
http://www.ebay.com.au/itm/AC-DC-Adapter-For-SimpleTech-96300-40001-001-SimpleDrive-HD-Power-Supply-Cord-/400716519670?pt=US_Monitor_Power_Supplies&hash=item5d4c90d8f6
or
http://www.ebay.com.au/itm/12V-AC-Adapter-For-SimpleTech-Simpledrive-External-Hard-Drive-HD-Power-Supply-/281311386852?pt=Laptop_Adapters_Chargers&hash=item417f771ce4
this one below matches the exact model number of your hard drive
http://www.ebay.com.au/itm/AC-Adapter-For-SIMPLETECH-BOM-No-96300-41001-133-96300-41001-045-96300-41001-073-/400705526395?pt=US_MP3_Player_Chargers_Cradles&hash=item5d4be91a7b
Jun 04, 2014 | Simple Technology 96300-41001-073 1tb...
Wht kind of current comes out?
The computer's switch mode power supply produces DC (direct current) electricity.
Nov 05, 2012 | Computers & Internet
Need to know amperage of unit
The switching power supply for my WD My Book Essentials 1TB drive shows as follows:Input 100/240V 50/60hz 500mAOutput 12V DC 1500mA
Sep 23, 2011 | Western Digital My Book Essential 1TB...
I have a simpletech 120 GB external USB hard drive with NO power supply. Do you know what the power rating is (ac or dc, how many volts, amperage...) or where I can get a new power supply for it? -Thanks
12VDC, 1.5A external power adapter Well that is what this page says, it's not your 120GB drive but unsure if it's no the same model maybe. However all external HDD that need a power supply should be needing 12 volts, as they are just internal drives mounted in a shell and some simple circuitry to power and connect it.
May 22, 2011 | SimpleTech 120GB SIMPLEDRIVE PORTABLE USB...
I would like to find out the voltage and amperage of the simpletech 500gb external hard drive, I need to replace the power cord. thanks alot greg holland greg.holland@sbcglobal.net
The Pinafarina unit requires 5 volts DC at 1 ampere.
This link will take you directly to the PDF user guide for your unit in case you misplaced it.
Hope that's helpful.
Jan 01, 2011 | SimpleTech 500GB SIMPLEDRIVE EXT HD-USB...
Hi. I have a LaCie Hard Drive designed by Poulton with N2870 on it. I've misplaced the external power cord adaptor, and need to know what kind to get. The guys at Radio Shack said they need to know: ...
I have the same one. The power supply I have says input 100-240V output is 24W 12V 2A.
I'm replacing the power supply but my big problem is not knowing the polarity of the tip There is no sticker on the hard drive itself or on the power supply (that I suspect is fried). Can anyone help?
Lisa
Dec 13, 2010 | LaCie Hard Disk 500GB with Hi-Speed USB2.0...
My western digital hard drive doesnt work. it lights up so the power is fine but it doesnt get reconised on the computer or media player. i hav alot of things on it and really need it working again......
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Note that W.D. has a "Customer Loyalty" program. Buy a new W.D. disk-drive through the W.D. web-site, at a significant discount.
Nov 03, 2010 | Western Digital 500GB My Book Pro-External...
Harddrive won't start
* USB cable
Nov 02, 2010 | Western Digital WD Passport 250GB Portable...
Need to know Amps & Volt. for Simpletech "Simple Drive" 1Tb.
The output of your adapter is 12volts 1.5amps the outside terminal is negative polarity and your connector looks like this (see below)
4927b50.jpgThere are two options of adapter (see below) both will work
EBAY Search for your adapter
Feb 13, 2010 | SimpleTech 1 TB 7200 RPM SimpleDrive USB...
Western Digital My Book  Premium ES Edition  WDG1SU5000 500 GB USB 2.0 Hard Drive Logo
1,619 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
