Question about Cooktops
Spinflo caravan gas hob something missing from press down tap?
Hello, I've got a Spinflo gas hob with a press down ignition button system. Under the button the innards are missing, all that remains is a small coiled spring in the base which I assume is for a battery to fit onto (1 of AA size I think) but nothing at the top - which I guess would be the positive end of the battery. Does anyone have this type of ignition on their gas hob? Could anyone throw some light on this problem please? no pun intended. Thank you for any help/info.
SOURCE: Gas Hob constant ignition clicking
Had the same problem. All five burners were continuously igniting, after my wife had given the stove a clean. Turned off the power, removed the five knobs and corresponding rubber rings, and used a hair dryer on the five holes where the knobs were for about ten minutes in total. Hey presto, when I turned the power back on, the constant igniting had stopped. Thank you all. I love the internet :-)
Posted on Jan 06, 2008
Eddie Rentas
  • 59 Answers
SOURCE: hob ignition switch keeps on clicking.
Hi
Glad to Help you!!
Take the knob off, them remove the cover that housed the switches, OK, Now, Look at the switch that is continiusly clicking and it will have two wires goin onto it, remove these wires and just lift the sending unit, and inspect it for water, grease etc ect....clean and dry and put back on and try again it should work, if it does not work, then just get a replacement one, they are not expensive, I just replaced two on my Jenn-Air myself and it cost me $25.00.
Hope this will help!!
Eddie Rentas
Tupper Lake NY
Posted on Jun 26, 2008
  • 222 Answers
SOURCE: injectors for hobs convert from LPG to natural gas
try to call wat brand u have to buy a injector for convertion,big different the injector for LPG and the natural gas,the LPG injector is small hole & the natural is have big hole.
Posted on Dec 02, 2008
SOURCE: creda gas hob now keeps ignighting
the ignitors have got wet usually due to cleaning. they are usually located under the rotating switches just let them dry out ( very well .....may take days) and it will work normally again
Posted on Apr 11, 2009
heatman101
  • 43501 Answers
SOURCE: ignition not firing on a neff hob, gas fine
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Posted on Aug 19, 2010
CDA gas hob ignition
try the fuse ..
Dec 27, 2013 | Cooktops
Cleaned my gas hob but now when you turn the gas on the automatic ignition doesn't switch on. Model candy pl 40 ax. I have checked the fuse on the plug but that's ok is there another fuse I should kno
Is it pluged in. Check to see if the plug Still works behind the stove It might be on a GFI plug needs to be reset somewhere along the backsplash counter
Jul 19, 2013 | Cooktops
No gas coming out from all hobs
Do you have a drop down lid over the burners, if so the mechanism may be faulty. Most of this type of design has a safety cut off when the lid is shut, and it won't allow gas to flow through to the hob, lift the lid and check behind and see if it has stuck closed.
Apr 28, 2013 | Verona 34 in. CTG536S Gas Cooktop
Gas hob keeps sparking all the time
check the ignition button or its wiring, the button may be broken and 'on' all the time, or the wires underneath broken off and shorted together.
Jan 18, 2011 | Rangemaster Professional 4 Burner Hob 23...
Ignition not firing on a neff hob, gas fine
heatman101
Feb 22, 2010 | Cooktops
Smeg gas hob ignition
There is a problem with the board. It has malfunctioned onto an ignition mode. By switching it off, it shows the capacitor is holding chage untill flat.(Hence the continual sparking) Replace it.
Sep 20, 2009 | Cooktops
Stuck auto ignition
try easing each knob upwards a bit.
Jul 15, 2008 | Smeg 23 in. SE64 Gas Cooktop
Candy sprinter
Great.. finally. i manage find from solution from user guide.. L is Locked. below is the instruction. will check out tonight.
The locking function holds the current settings, or prevents anyone from starting the hob. It is also used for cleaning the control strip as the controls can be locked without the hob being on. To lock the hob : -Press the on/off button     . -Press simultaneously " - " button and " + " button of the front right zone (PVD 633 front left zone), and then press again on the " + " button of this zone. The hob is locked, the locking indicator " L " is displayed on all zones for 20 seconds. To unlock the hob : -Press the on/off button      . The locking indicator " L " is displayed on all zones. -Press simultaneously the " - " button and the " + " button of the front right zone (PVD 633 front left zone), and then press again on the " - " button of this zone. The hob is unlocked.
Jun 24, 2008 | Cooktops
SPV577x Hob
i think there is a problem with the mercury fillament. there is a mercury filled nipple next to the flame, if this cools down and the mercury contracts the gas shuts off. this is to prevent the gas from flowing if the flame isn't lit. i have the same problem myself as well as one of the ignitions doesn't work. i beleive the cooker hood will hinge up giving access to the parts beneath althoguh i'm not sure what to do when i get under there, i'm pretty sure this is how to go about it. hope this helps
Feb 19, 2008 | Smeg 27 in. SPV577X.1 Gas Cooktop
Stuck auto ignition
Either one of the ignition switches are stuck down internally or the ignition pack is faulty, no other possible cause. Regards Advisor
Aug 29, 2007 | Smeg 23 in. SE64 Gas Cooktop
Cooktops Logo
106 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
