Question about Taylor 2751 Digital Wireless Rain Gauge With Thermometer
The rain gauge won't register - Taylor 2751 Digital Wireless Rain Gauge With Thermometer
Are there different types of rain gauges?
There are a few different types of rain gauges. Standard rain gauges, Weighing percipitation gauges, tipping bucket rain gauge, optical rain gauge and the aucoustic rain gauge. They each measure rain in a different and some of them interesting ways.
Dec 29, 2013 | Garden
Tip
How to measure rain fall when your rain gauge overflows
Most rain gauges that you will make at home will only measure up to one inch of rain fall. The problem with this is that if you live in a place where you will get more than one inch of rain your measurement if taken incorrectly will be very skewed. If your rain gauge has been constructed correctly you should have a fail safe in place.
When you construct a rain gauge you should have a measuring tube inside of an over flow tube. The meausuring tube will hold about one inch of rain fall, but when more rain falls the inside tube will overflow into the outer tube. To measure the excess rain fall you will follow a few simple steps.
Start by reading the inner tube of the rain gauge and then carefully empty the tube. Make sure that you don't pour out the water that has overflowed into the outer tube.
Once all the water for the measuring tube has been emptied carefully pour the excess rain water into the measuring tube. To get the most accurate reading try your best to not spill any water out, you can pour the water over a bucket to make sure that if you do spill any out you will catch it and be able to measure accurately.
If there is a lot of overflow you might want to measure a little bit of overflow at a time to get an accurate read. As you measure, write down the measurements and when you finish add up the values to get the reading.
The readings are done in inches so you have a reading that is 1.00 and has an overflow that measures up to .50 then the total read out will 1.50 inches.
on Feb 02, 2014 | Garden
The gauges don't register and it won't turn over
Haveyou checked your fuses under hood and in cabin?
May 28, 2013 | 1998 Jeep Cherokee
The screen displays PE, machine stops working
PE means Printer Error. your printer is stuck. call a tech
Mar 21, 2013 | Royal Cash Register 500dx
Just ran out of gas in 1999 Kia Sportage...put gas in and still won't start. turns over but won't catch. fuel gauge is registering 1/4 tank. is it flooded? should i let it sit a few minutes then...
put foot flat to floor DONT pump the accelerater pedal turn on ignition turn over engine as soon as it starts take foot off pedal happy motoring..
Jan 12, 2013 | Cars & Trucks
2007 jeep liberty suddenly won't start after
Try starting in neutral. Gear sensor may be heating up and not registering park.
Mar 03, 2012 | 2007 Jeep Liberty Sport
I recently purchased and installed an Oregon Scientific Model WMR200A. The rain gauge worked for the first rain fall but it has not worked since. Today we probably got 3 inches of rain but it registered ...
Oregon Scientific has an FAQ webpage for your weather station:
http://us.oregonscientific.com/service/faq.asp?t=1&cid=2
There are several Q & As that are pertinent to your problem.
I hope this helped you.
Good luck from Detroit, MI.
Jul 19, 2011 | Vacuums
Temperature gauge, fuel gauge and speedometer not functioning correctly , temp gauge states overheating , speedometer does not register proper sped , fuel gauge always says empty
Faulty instrument cluster. GM has had many problems with their instrument clusters and this is one of them.There has been a recall untold,that if your vehicle is not over 7 years old and have less than 70,000 miles on it they will replace it at no charge.GOOD LUCK!! P.S. if they won't cover it then you can get one at www.Dorman.com .
May 14, 2011 | 2004 Buick LeSabre
What does a simple rain guage consist of?
There are a variety of commercial rain gauges available on the market, however making a simple rain gauge is quick, easy and only costs as much as a plastic bottle. Chances are you already have everything you need to make this simple rain gauge, which is fun to construct, and interesting to use. Read on to learn how to make a simple rain gauge.
  1. Cut the top off of your plastic bottle. Cut about a quarter of the way down, to where the bottle begins to have a consistent diameter. Be careful to cut the edge as smoothly as possible, salvaging both pieces of the bottle.
  2. 2
    Remove the bottle cap and turn the top part of the bottle upside down, placing it into the bottom part. Connect the two halves with paper clips.
  3. 3
    Place the plastic bottle rain gauge in a location where it will easily collect rain without impediment from surrounding trees, plants or buildings.
  4. 4
    Help your rain gauge stand upright by placing it in a sand or gravel filled bucket. Simply make a hole in the sand or gravel large enough that half the bottle gauge sits into the pit. Use the gravel or sand to support the edges of the bottle gauge.
  5. 5
    Measure the amount of rain caught by your gauge by emptying the contents of the bottle rain gauge into a measuring cylinder.
Feb 07, 2011 | Home
2005 F350 DIESEL,WAS RUNNING,SHUT IT SHUT OFF,WON,T START
first check the oil and see if it is full. the injectors are fired by oil pressure so check those things first.
Jan 31, 2009 | 2005 Ford F 350 Super Duty
Taylor 2751 Digital Wireless Rain Gauge With Thermometer Logo
103 people viewed this question
Top Taylor Measuring Tools & Sensors Experts
deton8 von Splosion
Are you a Taylor Measuring Tool and Sensor Expert? Answer questions, earn points and help others
