Question about Mitsuba DV500 Camcorder
When in digital camcorder mode the camera only records 43 seconds how do i get it to record for a long period of time
Mitsuba dv 500
  • mjlux May 19, 2009
    same **** happens to me...at first i thought it was the memory card cuz mine came w/ a 2gb and its only compatible up to 1gb ...so i got a 1gb mem card and it still dont work past 30-42 seconds.. also when fidling around trying to get long video clips we realized that the flash wasnt even working for still pictures
    Problem Solver:
  • 6 Answers
Throw the damn thing at the wall and next time u see the person who sells this POS punch them in the face for me
Posted on May 19, 2009
SOURCE:
How long recording time with a dv tape in canon zr70mc
That obviously depends on the length of the tape. With an 80 minute tape, you can record for 80 minutes in SP mode or 120 minutes in LP mode. With a 60 minute tape, the numbers are 60 minutes and 90 minutes.
Sep 11, 2013 | Canon ZR70MC Mini DV Digital Camcorder
Malfunctioning One-Touch Navigation & Joystick Control
You can try first a reset from menu, then , if firmware is available you can reinstall firmware.
Sep 11, 2008 | Panasonic PV-GS300 Mini DV Digital...
No playback after recording
check if you are using with a full battery..
if yes reset the unit and try again..
To reset the Camcorder, remove the battery from the Camcorder, press the Power button for 30 seconds and then reinsert the battery in the Camcder.
Dec 12, 2007 | Sony DCR-VX2000 Mini DV Digital Camcorder
Panasonic HVX200 will not play back tape
Your playback heads might be clogged. I am not sure if this camera with give you a RF warning if your record heads get clogged. Also most professional machines drums are rated at 1000 - 1500 hours before they need to be replaced. If you are at 500 and never cleaned the heads it is time to. Run a cleaning tape a few times.
Dec 16, 2008 | Panasonic AG-HVX200A Mini DV Camcorder
Canon zr40 stuck in pause mode
Remove the battery.   Wait 10 seconds.  Put it back in and see if that resets it.
Sep 09, 2008 | Canon ZR40 Mini DV Digital Camcorder
How to record with dates
you shoul really need to look at the instructional functions of the can corder . simply look for the settings for you to get the right file
Mar 13, 2008 | Canon Optura 500 Mini DV Digital Camcorder
Blue lines in play mode
This is not a problem with the tape but the camera. The only way to fix it seems to be to find an empty spot on the tape or a spot you don’t care if you record over. Then record for a second then go to video mode and you can play the tape without the blue lines. Or buy something else to play the tapes which should be fine either way. Darn camera !
Oct 14, 2007 | Panasonic Palmcorder PV-GS12 Mini DV...
Record button doesn't function
You may want to check the record lockout safety switch located on the tape. This button can get moved by accident and the camera will refuse to record on that tape. Also, be sure the camera is in "video" mode, not "photo" mode. Some of Canons camcorders have a digital still camera mode which stops the camcorder from functioning because the photos are being recorded to a memory card and not your tape, please check this swithc as well. Good luck. Joe Weibel customelectronics.org
Feb 26, 2007 | Canon Elura 65 Mini DV Digital Camcorder
Any movement recorded in HD mode is not clear.
HD mode images may appear to move somewhat stiffly compared with SD mode or DV mode images. This is because they are shot at a rate of 30 frames per second compared with the 60 frames per second for the SD or DV mode images. The movie is shot at 24 frames per second, and looks good. So HD mode can have the same feel as a movie material. For smooth movement during video clips, we recommend you minimize rapid-panning or avoid shooting fast-moving subjects. Should you wish to record more natural motion in the picture, we recommend setting a slower shutter speed, or changing the recording mode to SD or DV.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Mitsuba DV500 Camcorder Logo
87 people viewed this question
Top Mitsuba Video Cameras Experts
Ekse
pictureman4u
DrDazzDaBoom
Level 1 Expert
Are you a Mitsuba Video Camera Expert? Answer questions, earn points and help others
