Question about Fisher Price M5584 Papasan 2008 Cradle Swing
I need a replacement leg for this swing - Fisher Price M5584 Papasan 2008 Cradle Swing
I need a front left leg for my fisher price swing n glider my little animals
They do not make parts for these so you are really out of luck here.
Sep 28, 2016 | Fisher Price Baby Swing N Glider
GROVEPARK 4 LEG METAL SWING SET - MODEL#MSC-3886
Yea, what is your question?
Apr 30, 2015 | Toys
How to put the legs on flutterbye dream swing
Request instructions directly from Flutterbye.
Jan 25, 2015 | Toys
I AM USING SOMEONE ELSE'S SWAY & PLAY. HOW DO I CHANGE THE BATTERIES AND WHAT SIZE ARE THEY?
tools needed : 1 Phillips head screw driver, 4 d cell batteries.
as you look at the swing, from the front, you will see a mobile set into the side of the leg on the RIGHT side.
it's the leg with the on off switch.
insert the screwdriver through the hole in the mobile and into the screw inset at the top of the leg. You will see that it's at the top of a rectangular door..this is the battery door.
unscrew the 1 screw and remove the door. the mobile will come off as it's attached to that door. change the batteries and put the door back on and re-install the screw.
hope this helps!
Aug 02, 2013 | Cosco Juvenile Cosco Sway n Play Swing...
My proform 2605 elliptical the right foot pedal is making a loud noise like it's slipping.
Detachthe ends of the pedals from the crank axles. Spread a layer of machine greaseover the crank axles, then reattach the ends of the pedals.2
Removethe bolts connecting the pedals to the swing arms. Detach the pedals from thearms, then spread a layer of machine grease over the axles on the swing arms.On some models, the bolts may also serve as the axles. Reattach the pedals tothe arms.3
Removethe bolts connecting the swing arms to the elliptical's upright. Detach theswing arms from the upright, then spread a layer of machine grease over theaxles on the upright. Reattach the arms to the upright.
Oct 01, 2011 | Proform PFTL79807 - 850 W/ Gamefit...
We closed up the swing for storage now we need to use it and the seat is wobbly any ideas where to tighten screws?
The main ones to tighten are the ones on the legs that you can see. What makes it really wobbly are the legs not being balanced or spaced apart wide enough. They should be extended out enough for them to be resting on the side of the top where they enter the motor housing, and the feet should be relatively flat on the floor. Push them out (don't force them of course) then use your foot to nudge them out until they're stable enough for your needs. I found it also helps to set this up on a carpet instead of bare wood floor. The swinging motion can sometimes rock the legs up/out a little and make it look unstable.
Aug 25, 2011 | Fisher Price Starlight Papasan Cradle...
My Starlight papasan craddle swing clicks loudly and the gears seemingly miss causing it to not swing properly whenever I put my baby in it (he only weighs 8 pounds). When there is no weight in it, it...
Make sure the legs are pulled out all of the way by pulling the legs outward. Make sure the buttons snap into the notches in the motorized frame. Also check to be sure the legs are locked into position by pushing the legs inward. The legs should not move. Also if you can adjust the swing from side to side make sure it is locked in place. That should fix it.
Jul 19, 2011 | Fisher Price Starlight Papasan Cradle...
I have just purchaced a graco bounce n swing. ive inserted leg tube into wrong side n cant get it out. what should i do?
There is a plastic casing around where the leg snaps in. Lift this section with a screwdriver being careful not to break it. With it lifted, push down on the end of the leg that is incorrectly inserted and push down. I had the sane exact issue and this is how I figured it out. Good luck!
Mar 29, 2011 | Graco Swing N Bounce, Inman Park
When I open bottom or top fridge doors they swing all the way open by themselves instead of staying put partially open
The fridge needs to be leveled better...
When the doors swing open then gravity takes over and pulls the doors open the rest of the way...
to fix this adjust the legs of the fridge so that it leans just a bit away from the hinge side and back just a bit...then the doors will swing closed by themselves...
The back legs may have to be shimmed and the front leg adjustments are usually right behind the front cover at the floor...sometimes there are screws there to adjust the back legs from the front also...
heatman101
Jan 16, 2011 | Kenmore 64802 Top Freezer Refrigerator
Graco swing has very limited range of motion. It still "works", but something inside is damaged or fell off. I have taken it apart to see the parts in motion, and it all looks like it is doing...
We bought a used swing (lovein hug). It was in super condition but we noticed the same thing where it would hardly swing. My husband, who seems to analyze things that don't work, took it apart to see why so much slop was in there. He couldn't find anything obvious why it was doing that, so he took a piece of small cardboard (off an oatmeal box) and wrapped it around to make it fit on both sides and wrapped it with black electrical tape and stuck it back in. It's hardly noticable. We also changed the legs around to make sure the legs make the swing lay back.
Hope this helps!
Oct 20, 2008 | Graco Simplicity Rock n Roll 330 Crib
Fisher Price M5584 Papasan 2008 Cradle Swing Logo
18 people viewed this question
Top Fisher Price Baby Gear Experts
romney2012
Lyle Siemens
Lyle Siemens
Josh Whitehead
Josh Whitehead
Are you a Fisher Price Baby Gear Expert? Answer questions, earn points and help others
