Question about Galaxy Radios DX55HP 10 Meter Radio
Need adjustment chart
Internal vr adjustment
    Novelist:
  • 146 Answers
Http://www.cbtricks.com/radios/galaxy/dx33hp/dx33hp_adj.htm
This should be the same your radio just has a new revision to the 3600 pcb and yours has mosfet finals so research voltage if you are going to tweak the bias voltage but it is not suggested.
Posted on Mar 04, 2015
Cobra 1000 gtl modulation/swr meter vr adjustment
you are not matching it correctly. get hold of a friend that knows how to match it and see if he will help you.
Mar 18, 2013 | Cobra 148 GTL 120-Channels Base CB Radio
S/rf is too high on transmit on my cobra 29 ltd bt
no matter what s/rf you are looking at it should not key much beyond an s-9 . vr 3 controls the meter. Key the mic and adjust it to s-9 then check you modulation.If you still think you need more then adjust vr 4 .
Jan 07, 2012 | Cobra 29 LTD CB Radio
How to adjust frequency on transmit??? Galaxy
hELLO THERE
hERE IS SOME MODIFICATIONS FOR THIS RADIO
Galaxy Mods DX 2527 - VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...Hi Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VC 1....10.240, VC 2....10.240. DX 2517- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5....FM Deviation, VR 6....SSB Carrier Balance, VR 7....TX Offset, VR 8....CW Beep Level, VR 9....RF Meter, VR10...Final Bias, VR11...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM/FM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM/FM Low Power, VR601..13.8 Volt Power Supply. DX 22B- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...High Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VR21...TX Offset, VC 1....10.240, VC 2....10.240. DX 11B- VR 1....AM/FM S-Meter, VR 2....SSB/CW S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...CW Tone Level, VR20...Final Bias, VR21...TX Offset, VR601..13.8 Volt Power Supply, VR803..AM/FM Low Power. DX 77HML, DX 88HL, and DX 99V- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...AM/FM Low Power, VR20...Final Bias, VR21...TX Offset.
Unmarked VR in R189..AM/FM Medium Power for DX 77HML only. DX 33HML, DX 44V, DX 55V, DX 66V, and DX 73V- VR 1....AM/FM S-Meter, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 8....RF Meter, VR12...Low Power AM Modulation, VR13...AM/FM High Power, VR14...High Power AM Modulation, VR16...AM/FM Low Power.
Unmarked VR in R188..AM/FM Medium Power (DX 33HML only)
Unmarked VR in C139..Med Power AM modulation (DX 33HML only) DX 949,DX 959- VR 1....AM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM Squelch Range, VR 6.....SSB Carrier Balance, VR 7....TX Offset, VR 9....RF Meter, VR10...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM Low Power, VC1....10.240. DX 2517 and DX 2527-
Symptom:Buzzing or motorboating sound in either the transmit or receive.
Problem: TR602 is oscillating
Cure: Replace C602 with a .01uF cap {Cap is located in the power supply board}.
RG 66,99,DX2517 Replace Q54 2SB754 60watt 7A with a higher power 2SB817 100 Watt 12A. Derating of this component will cool operation, provide better voltage stability,decrease wobble, allow voltage increase to 14.5 volts comfortably. (replace 10 volt caps in this section of the radio to a minimum of 16 volts before increasing supply voltage to this level)and provide faster swing rise time, Replace Q37 2SA473 to a 2SA1012-0 or ECG153 this will improve the clarity and volume of the modulation and it will also run a lot cooler.
Nov 12, 2009 | Galaxy Radios DX-949 40-Channels Base CB...
Hi, I need to adjust the modulationand power output on the yaesu vertex 2000 vhf radio. Can someone please tell me what vr to adjust.
You should be able to find a service manual at: www.mods.dk.
You may need to go into the "setup" menu to access the modulation settings. On some Yaesu radios, it's NOT a VR setting.
Aug 26, 2009 | Vertex Radio Communications
Installation of new cd player in 2002 VR-X Lancer
There are aftermarket wireharnesses available. I suggest the $15-25 purchase. The wires usually match color for color to the aftermarket stereo saving a major head ache if attempting to figure out the factory harness. These adaptors are available at many audo part stores and local installation shops. To check the harness you need, Metra, on of the main aftermarket wire harness manufacturers has an application chart on line, see metraonline.com or a search for American International or Scosche.
Nov 14, 2008 | 2002 Mitsubishi Lancer
Audio limiter
tintlady, here is the info you requested;
the AM limiter is R 276
These are the variable adjustments inside,and what they control.
VR-1 AM S-METER
VR-2 SSB S-METER
VR-3 SSB SQUELCH RANGE
VR-4 AM SQUELCH RANGE
VR-6 SSB CARRIER BALANCE
VR-7 TX OFFSET
VR-9 RF METER
VR-10 FINAL BIAS
VR-12 DRIVER BIAS
VR-13 SSB ALC
VR-14 AM HIGH POWER
VR-15 AM MODULATION METER
VR-16 AM MODULATION
VR-17 SSB POWER
VR-18 AM LOW POWER
VC1-10.240 MHz Frequency adjustment
Hope this helps you out, let me know,,Mechanic
Jan 20, 2008 | Radio Communications
Screen problem
This is a problem we have seen on this particular unit. There are internal adjustment that must be done to correct this problem. This adjust is done on the power supply. There are VS, VE and VA adjust. Look on the interior of the Panel for voltage chart. Adjust these voltage accordingly.
Best regards
Circuitcity
Dec 07, 2007 | LG 42PX5D 42 in. Plasma HDTV
Will this camera take VR lenses?
Yes. Please see the lens compatibility chart for complete information. Download FinePix S3 Lens Compatibility Chart
Aug 29, 2005 | Fuji FinePix S3 Pro Digital Camera
Galaxy Radios DX55HP 10 Meter Radio Logo
91 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
