Question about Frigidaire FFLE2022MW Electric Washer/Dryer Laundry Center - White
Dryer heat not working
FFLE2022MW Frigidaire Electric Washer/Dryer Laundry Center dryer heat not working
  • 3 Answers
Without knowing your problem, I would guess that the heating element has burned out. This is a common issue with many dryers, regardless of brand.
The hearing element in a clothes dryer is like any other heating element, such as in a space heater, heat gun, or hair dryer. It is basically a continuous coil that is held in place by insulators, usually ceramic.
As the element ages, the coil becomes brittle and can often break. When a breakage occurs, the circuit is no longer complete and will not produce heat.
Replacing one is fairly simple.
  1. The first thing that you should do is unplug your dryer.
  2. Once unplugged, remove the exhaust duct.
  3. Use a screwdriver to remove the electric access panel in at the rear of the dryer.
  4. Locate and remove the heating element.
  5. Inspect the element for a break in the coil. The problem is not always obvious so it may be good to do a continuity test on it.
  6. Replace part if necessary. Elements will usually run $20 or so.
  7. Assemble in reverse order and test.
This website has some really great detailed step by step instructions on replacing a heater element.
Good luck.
Posted on Feb 19, 2013
SOURCE: Frigidaire Dryer WOn't Heat
I have a frigidaire frontal dyer that is 3 yrs old. The dryer works properly, it tumbles, but it is only cold air ???? What's the problem ?
Posted on Sep 15, 2008
dragonsthatk
  • 547 Answers
SOURCE: FRIGIDAIRE AFFINITY ELECTRIC DRYER NOT STOPPED HEATING
eleiment
Posted on Feb 18, 2009
SOURCE: My Frigidaire Electric Dryer keeps giving an error code
If your dryer is the same or similar to mine (Model AEQ6000ES2) then error E68 is a stuck key on the keypad. This may be mechanically stuck or the membrane contacts. The simple solution is to replace the keypad.
I found this information by searching for "Frigidaire Model AEQ6000ES2"
Posted on Mar 30, 2009
  • 59 Answers
SOURCE: Dryer will not heat up
check that you didnt disturb any wireing by mistake. then chec the contunity on your heating element. they are actually pretty fragile.
Posted on Apr 25, 2009
  • 410 Answers
SOURCE: My Frigidaire Dryer (AEQ6000ES2) won't heat. Did
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the dryer ID doesn't mean
anything to me. Over the years, I haven't had much trouble with my dryers. The E56 error code means high motor current. To help you find out why, I suggest you go to www.applianceaid.com where they have very good trouble shooting and repair information on dryers and other appliances. I think you'll find what you need there. You can probably verify the meaning of the error code there. Good luck with it. If I have helped you, please rate my advice on fixya.
Posted on Nov 26, 2009
How do I replace the dryer belt?
Hello Philip, I appreciate your inquiry!
Based off the information you have provided you need help with replacing the belt on your Frigidaire laundry center. In order to access the pulley you would need to disassemble the laundry center. I would recommend seeking assistance from a professional technician for proper disassembly of your laundry center. Incorrect disassembly could cause personal harm or future issues within the laundry center. Best of luck! -Matt
Dec 15, 2015 | Frigidaire FFLE2022MW Electric...
Frigidaire FFLE2022MW washer dryer combo beeps twice and stops during all washing cycles after it fills with water and lid is still locked. Does anyone know how to correct this? Thanks
Thank you for your inquiry, Criss Ard!
From my understanding you are having issues with your Frigidaire laundry center not starting a cycle. You stated that the washer fills with water then locks. It sounds like your timer is not advancing and that could be due to a faulty timer or wiring harness. You may want to perform a reset on your laundry center and you can do that by disconnecting the power cord for roughly ten minutes. If this troubleshooting step does not help resolve your issue you may want to consult with a professional technician for proper repairs. I hope this information is helpful. -Matt
Feb 20, 2015 | Frigidaire White Electric Washer And Dryer...
My Frigidaire stackable laundry center will not fill with water?
Hi Keith Knapp, I appreciate your inquiry!
I understand that your Frigidaire laundry center is not filling with water. It sounds like you could be having a problem within water valve, control board, or door switch. I would recommend having a technician out to your home to properly diagnose and repair your appliance. Hopefully this is helpful. -Matt
Aug 21, 2014 | Frigidaire FFLE2022MW Electric...
My frigidare laundry center, FFLE2022MW will not fill with water at all.
I have a Frigidaire Landry center model # FEX831FS4 I washed a small but heavey rug in it and it quit during the spin cycle and now wont do nothing but the dryer still works...can you help me out?
Aug 21, 2014 | Frigidaire FFLE2022MW Electric Laundry...
How do you change the heating element
Good Afternoon Friend,
I understand you want to know how to change the heating element in your laundry center, model# FFLE2022MW. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician, for further assistance. They have been trained on you appliance and should be able to change the heating element with ease. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire FFLE2022MW Electric...
Top load frigidaire washer will not spin, it agitates, it drains
You need to replace the starter cap on the motor this is why it will not turn and the smell is the cap that's not starting the motor it also will hum.
Dec 29, 2013 | Frigidaire FFLE2022MW Electric...
Brand new Frigidaire FFLG2022MWO Washer/Dryer Laundry Center. After a wash cycle is finished, the washer will start again after a few minutes. A truly never ending cycle. Please help.
Good Afternoon Mauricio, thank you for your question! Try resetting the unit by either unplugging it or flipping the household circuit breaker to the off position. Wait roughly ten minutes and turn on the appliance. Select a normal cycle and verify if the washer continues to run after ending cycle. If resetting the power does not correct the issue, your appliance could be experiencing a communication error with the control board, timer or could have a wiring failure. I would suggest contacting an experienced service technician to determine the precise cause.
Aug 19, 2013 | Frigidaire FFLE2022MW Electric...
Frigidaire FFLE2022MW Electric Washer/Dryer Laundry Center - White Logo
140 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
