Question about Fimco High Flo 3.8 Gpm Sprayer Pump 5275088 - (Fimco)
High flo model 5275704 what betry and other electrical i need ?
I have a Fimcoatv sprayer with a high flo gold series pump mod # 5275704 ..the pressure will rise to 40psi & then drop to 20psi & then back to 40, this cycle continues through out the spraying...
As it is a diaphragm pump some pressure fluctuation will be normal but that is likely to be more of an oscillation at the speed of the pump rather than a steady or slow cycling of pressure.
If it is important those oscillations are damped to provide a smooth noise-free pressure the design would include an accumulator.
If everything remains constant - a constant fluid intake and a constant spraying orifice and the pump running at a constant speed then the pressure would be constant and the motor would be consuming a constant current.
Clearly something is not constant. Something must be changing and cycling to cause the pressure fluctuations. I have a theory but am not in a position to test the theory myself - Inserting an ammeter in series with the motor in the electrical supply to the pump and monitoring the current drawn should show it fluctuating at the same time the pressure fluctuates. If the current falls as the pressure falls my theory is the pump intake is being restricted somehow and if the current rises as the pressure falls the pump is labouring due to outlet being restricted in some way or because there is a motor fault. It would be important to monitor the supply voltage at the pump at the same time to ensure it remains stable.
Jun 01, 2014 | Northern Tool Garden
10 second in betry low
I assume "betry" is a battery? It may be time to replace the Battery, always get a genuine replacement, inexpensive aftermarket batteries don't work well.
Apr 12, 2013 | HP Pavilion dv6000z Notebook
2 Speed Flo-Master stuck in high speed after turning on and off the electric
Is your switch an "air switch" ... could be you have a leak in the hose that connects from the push button to the actuator that actually does the switching. Check it out.
Dec 12, 2012 | Pool & Spa
I have an appolo spa explorer model...bought it
you must have a small pump call laing if you do, air picket inside the plumbing try to turn both pump on high and wait few minutes if doesn fix try to loose the nut just a little bit with the breakers off and let the air go out. try one more time. if doesn work turn on high both pump and touch if they are working then a impeller may be broken inside one of them try to turn each one separate to find wich one as t he broken impeller.
Oct 29, 2009 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Heater will not light off
Be sure filter not dirty or too old lack of flo can cause tripping of high heat switch check flo switch also always check simple things 1st traceace
Dec 20, 2008 | Jandy Laars Lite2 Ld 400,000 Btu Heater
I left My nokia 3230 fo long time without using it
its need a Professional box tool called Tornado we use this one for flmash the phone to revive it again
plz do arte this post
Sep 28, 2008 | Nokia 3230
Fimco High Flo 3.8 Gpm Sprayer Pump 5275088 - (Fimco) Logo
100 people viewed this question
Top Fimco Garden Experts
lnbn1975
Jay Finke
Jay Finke
ray gallant
Are you a Fimco Garden Expert? Answer questions, earn points and help others
