Ferguson 19inch lcdtv/dvd f1906lvd blue light flashes but will not turn on.
Ferguson TV help? Can't get the TV to turn on.
sounds like it is stuck on stand by,with out the remote i dont think you will get it to turn on,when mine done it i just turnd it on and off a couple of times by the mains mine came back on.
might work.
Aug 12, 2015 | Televison & Video
Technika television
its an error in the power supply board.
Aug 19, 2008 | Televison & Video
FLASHING RED LIGHT ON MY SHARP LCDTV REMOTE RC1910
Check it with fresh batteries. For some remote controls; if battery became low, this should happen. Electro help
Oct 24, 2014 | Sharp LC Televison & Video
Pioneer pdp 5071pu
You can get some information about your problem from service manual:
http://www.nodevice.com/manual/newmans/lcdtv/pdp-5070pupdf/get74015.html
Sep 24, 2013 | Televison & Video
Ferguson ldvd200 portable dvd player - my battery has been on charge for a number of hours and the chg light flashes - is there something wrong or should I wait longer?
i had this problem my self flashing charger light but not charging i fixed this by sripping the battery pack unsoldering the positive and negative from the small circuit board geting a 10v charger and directly charging the batery for a few secs checked the battery with a volt meter to insure that there was a charge in it then reasembled then run the player till it was flat put on charge did this a few times this to cycle the battery each time i did this it took more of a charge untill it was back to normal note the light should stay on not flash hope this helps
Aug 21, 2011 | Audio Players & Recorders
My sony SLV-D300P suddenly would not turn on. The blue ps button/light just flashes, but no attempt to turn the unit on works. It was working fine, without any problems, until this one occurred.
I have the same problem -- tried power reset, tried holding stop button for 5 second reset, nothing works. If I push the power button or the eject button, the blue light flashes momentarily then goes out.
Aug 28, 2010 | Sony SLV-D300P DVD Player/VCR
Ferguson FVD100-01 manual needed
ONLY FOUND 1 LINK TO DOWNLOAD , hope it helps , AJ
http://sharibear.50webs.com/dvd-drhd.htm
Nov 18, 2009 | Televison & Video
Hanspree codes
The information that I have found by searching is saying that your remote is not a "learning" remote and you need to get a rev 8 remote which is a "learning" remote.
Jan 05, 2009 | Televison & Video
Can't power on
try unplugging the dvd player then plug it back in as this treats it like a reset.
Mar 13, 2008 | Aspire Digital AD-8091 DVD Recorder
Televison & Video Logo
Top Televison & Video Experts
