Question about Chamberlain Elite Miracle One Swing Gate Operator
Does not open or close gate
You hear the motor running
New FM502 Dual gate opener pressed remote which starts the second gate opening then the master moves a few inches stops. Hear 3 beeps 2 seconds 3-. .Conections are good to circuit board! What up!
reprogram the opening sequence in the control box
it should that the first gate opens then the second gate opens a few seconds behind it
closing is the reverse
you can program that only one gate opens
you can also program that one gate is a entrance gate where it opens until you stop it , then when you have passed through , press it again and it closes
read the operating instructions and follow the programming procedures closely
Oct 24, 2016 | Miscellaneous
Lift gate will not power down to closed when button on gate or remote is pushed. Lights do flash though.
There are switches on both ends of the course of the motor, if one fails it will only work on the side that´s ok. That´s why it opens but do not close.Check it out.
Oct 24, 2015 | Cars & Trucks
My nice sliding gate only closes with the fob and will not open
There are several possible causes, but the first to check is the limit switches. When the gate opens, it is supposed to trip a limit switch that tells the mechanism that the gate is fully open. If the switch is not tripped, it will not respond properly to a command to close. It may think the gate is running into an obstruction and then just shuts down.
Feb 02, 2015 | Nice Robuskit Slide Gate Operator Motor...
Gemini gate motor
Check if it has stops anywhere in the system, usually there are micro switches that are activated by arms, etc that tell it how far to open and close. You may need to adjust them.
Aug 20, 2014 | Cars & Trucks
The air control dash works but no air coming out
Check for leaks under dash check to see all gates are opening & closing , Check the vent gates or the( little doors) that open&close I realy need more info to narrow things down. is fan motor running ,can you hear vent doors opening and closing, can you hear air leaking wene you change settings But its probably The electronic Module under Dash just right of center left side of glove box size Aprox(5-4- 2 maybe a little bigger has 2 looms of wires plug into one side of moduale feels like one but it is two there are locks that hold these in place, ( push tabs) salvage yard 20-40 bucks dime a dozen.
Jun 19, 2014 | 1994 Buick LeSabre
My electric driveway gates open and close but not completely. The power switches off before they close or open fully
sorry but we have no way of knowing what your control box is set for . try a local repair shop
Jan 10, 2018 | Cars & Trucks
2011 expedition rear gate will not open
Is it not under warrantee ?
The Dealer should help you with
that
Jun 05, 2012 | 2004 Ford Expedition
You can hear my gate motor working, but the gate does not open or close. you can open and close the gate by hand. it is as if the gear does not engage
Your manual override is active. This disengages the gearbox from running the gate. You will need to release the manual override. What make and model gate motor is it?
Apr 03, 2012 | Cars & Trucks
My gate is equipped with a D3 Centurion gate motor. When I push the button to open the gate, the motor turns in the opposite direction (close) and tends to close further. Then if I deactivate the gear box...
if you push the open button and it closes indicates that you have the wrong polarity connected to the motor
gate motors are DC so where the positive and negative wires are connected are critical for rotation direction of the motor
Jul 29, 2017 | Garden
My sl 3000 ul gate wont open unless I help it out after i press button on board I have to turn motor shaft and push on gate and then it will catch and opne/close. Is it my motor or my worm gear?
if the motor cant rotate the shaft by itself, its likely a burned coil in the motor, but if the motor is running but not moving the gate then its a broken gear
Jan 24, 2010 | Elite Sl 3000 Ul Sliding Gate Operator
Chamberlain Elite Miracle One Swing Gate Operator Logo
Top Chamberlain Home Security Experts
Norm Pearl
Tom Chichester
Bill Boyd
Are you a Chamberlain Home Security Expert? Answer questions, earn points and help others
