Question about Microsoft Xbox 360 Console
My Xbox360 game is saying save content is damaged
I have Skylanders Giants, and I started playing with a thingamabobber on top of the Xbox to save it, now, it says save content is damaged.. This happened when I had a HP game, and I forgot how we fixed it
4 Suggested Answers
whootsley
  • 121 Answers
SOURCE: xbox360 memory dump
call 1-800-4myxbox and tell them they will make you do some things that lets them view your memory code they will delete corrupted files.
Posted on Feb 12, 2008
  • 452 Answers
SOURCE: My Xbox don't play games
make suer the disc is very clean.
Most likely you will need to replace the laser on your xbox. It's not strong enough to read the games anymore. You can get a laser from ebay for like $15.
Posted on Dec 10, 2008
xboxexperts
  • 19 Answers
SOURCE: cant get my xbox360 to play xbox games
This is a pretty easy one to fix if you aren't too scared to open the 360 up, otherwise you will have to send to Microsoft.
The problem is that the laser is either dying out, is dirty, or is not getting enough power.
so try to fix it using these steps...
- first open the 360 and pull out the dvd drive and open it up too.
- clean everything out good with compressed air, and q-tips dipped in alcohol.
- now you need to adjust the power going to the laser. Sometimes you may have to try multiple settings before getting it just right. Just keep adjusting the resistance lower and lower until it works.
- if you tried multiple settings and still get the errors, then either get a replacement drive, or a new laser for it. Click Here for how to properly install the new laser.
hope this helps ; )
Posted on Mar 06, 2009
Why my wii skylanders giants won't read cd
This will depend on a few things.
1. If sky landers is the only game that will not work then it is likely that it is scratched or damaged in a way that makes it difficult to read. You can buy special cleaner for your cd to help with this if the damage is moderate to minimal. Or use a home remedy like tubing a banana on the side to be read and wiping it all off with a microfiber cloth and giving it a quick rinse (never submerge) and drying. The banana fills in some of the scratches.
2. If you wii has a hard time reading any disc then you should buy a cleaning disc meant to go inside the wii and clean the reader. One designed for computers and CD players should work just fine.
May 13, 2014 | Activision Skylanders GIANTS Starter Kit...
My skylader from spyro's adventure has an error, what do I do?
If you are getting an error stating A toy on the Portal of Power has a problem, follow these steps to reset your broken toy.
Skylanders SWAP Force
  1. With the toy on the Portal, select Pause.
  2. Select Skylander.
  3. Select Manage.
  4. Select Reset. If you are resetting a swappable toy, you must reset both the Top and the Bottom separately.
Skylanders Giants
  1. Keep the broken Skylanders toy on the Portal of Power and open the Pause Menu.
  2. Return to the Main Menu.
  3. Open Settings.
  4. Select General.
  5. Select Reset Broken Toys.
  6. Select Yes when you are asked to reset the Skylanders toy.
  7. Repeat Steps 5 and 6.
  8. Keep the reset Skylanders toy on the Portal of Power and start a game in Story Mode.
Your Skylanders toy will now work again.
If the screen turns black after returning to the game, try again starting with Step 1.
If the game won't load and you are only seeing an icon on the screen, remove the Skylanders toy from the Portal of Power, put it back on the portal, and try again starting with Step 1.
Jan 26, 2014 | Nintendo Skylanders Spyro’s Adventure...
My skylander on spyro's adventure has a problem, how do I fix it?
Try this :)
  3. Select Manage.
Skylanders Giants
  3. Open Settings.
  4. Select General.
PORTAL WILL NOT RECOGNIZE CHARACTER
  3. Select Manage.
  4. Select Reset.. If you are resetting a swappable toy, you must reset both the Top and the Bottomseparately.
Skylanders Giants
  3. Open Settings.
  4. Select General.
Sep 02, 2013 | Activision Skylanders: Giants Portal...
Skylanders giants start the game on xbox 360 saysd memory error use another device or continue playing without saving. Whats going on
There's some problem with your memory unit/harddrive.
Try to turn of your Xbox, and remove the harddrive/memory unit(s).
When removed, turn on your xbox, let it start up, and then turn it back off, connect the harddrive/memory unit(s), and start it again.
Then it should be able to start.
Note: If you have the Xbox 360 Slim, the harddrive is placed at the left of the xbox if it lays down, and you can get it out by pulling back a little thingy on the back of the left side.
Jan 21, 2013 | Video Game Consoles & Games
We can't get to the next level of Skylanders giants.
What do you mean by "no longer being read" ?
If it that error "Disc is unreadable" that is the problem, you have to check your disc, because it might have scratches, dust or some gore that shouldn't be there.
If that is the problem, you should remove whatever is on the backside with warm water and gently rubbing it of with your fingers (not nails!). If you have scratches, and nothing else, then you must either get a new copy of the game or you can try something that might sound very weird, but CAN work.
- Remember that if you try to fix the game by yourself, it's at your own risk! -
If you want to try fixing those scratches you must get some toothpaste, yes toothpaste.
Then you take some of the tootpaste on your finger (remember to not hit the disc with your nails!) and gently rub it over the disc, apply more toothpaste if you can't get it over the whole disc.
When you have done that, you'll get all the toothpaste of the disc, using nothing but warm water.
When that is done, you'll just let it dry, place it on a towel or something like that (with the BACK side up).
And when it is dry, you just put it in your xbox and play the game! It usually work, I've done it with 3-4 games, and all of them worked atleast for 2-3 more weeks. :)
Jan 07, 2013 | Activision Xbox 360 Skylanders Giants...
Xbox360 will play cds but no games, says onscreen
If your Xbox 360 will not play your games this is because of the sensors on the back of the drive overheating it is not normally the laser.
Luckily you can fix this yourself and get back to your games and to do this you need the proven Xbox 360 Repair guide.
Or you can send it in and they will fix it for you the repair will take about 4 weeks.
Sometimes like you mention it will still play CD's though.
Feb 13, 2010 | Microsoft Xbox 360 Console
When I want to play some of my games that include downloaded content from xbox live, It wont let me do it offline. Is there a way to be able to use my downloaded content while im not online? I used to be...
Bad Files, make sure you are logined into your account. there is a maintence part, on the xbox360.
with the new menu of xbox360 its hard to find that.
But you should be able to , unless it says online ONLY!
make sure you read the fine print of some games..
Good Luck
Dec 19, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
661 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
