Question about Canon PIXMA MP470 All-in-One Printer
Error message displays there is no paper load paper but it is loaded properly but want print
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
Load error
When trying to print on continuous stationery, the display may show "Online Single Load". This will occur if the printer is expecting to print on single sheet paper even though you may want it to print on continuous paper. To clear the error follow this procedure. • Take the printer off-line by pressing the Online key • Press the Setup key • Press the key under "Paperway" in the display • Select Tractor 1 (or Tractor 2 if fitted/required) • Press the key under "Set" • If the job still refuses to print try loading the printer with a single sheet of paper to clear the command. To do this remove the tractor feed paper and close the cover on top of the tractors but not the outside cover. You will see a guide into which put a single sheet of paper and press the key under "Load" in the display. • The printer should commence printing. If it does not, then press and hold the key under "LF/FF" to eject the single sheet. Now follow the instructions above again to select the Tractor. The display should read "OnLine Tractor Load". Load the tractor fed paper into the Tractors and press the key under "Load". The printer should now be ready to print. Check your software settings for the correct paper path type. Ensure that the display does not show "Manual" otherwise you will have to clear this error in the same manner as you have for Single sheet
Dec 06, 2011 | Tally Dot Matrix T2265C Printer
Shows code U165
This section explains the way to confirm the ink status and the procedure to replace ink tanks. When ink runs out or other errors occur, an error message is displayed on the LCD to inform you of the error. See "An Error Message Is Displayed on the LCD".
When printing from your computer, error messages appear on your computer screen as well.
NOTE
Be sure to install the ink tanks in the correct order indicated by the label on the Print Head Holder.
The machine will not print if an ink tank is installed in the incorrect position.
With the LCD of this MachineMake sure that the machine is turned on, then press the COPY, FAX, SCAN, or MEMORY CARD button. The current ink level will be displayed on the LCD for a few seconds.
g0011480_tcm14-605381.png(A) Confirm whether any symbols are displayed here.
g0011482_tcm14-605375.pngColor or black ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.g0011483_tcm14-605376.pngColor or black ink may have run out. See"An Error Message Is Displayed on the LCD".
REFERENCE
The ink status information is also displayed on the screen that appears during printing.
An error message may be displayed on the LCD during printing.
g0011494_tcm14-605377.pngMachine detected ink out condition. See "An Error Message Is Displayed on the LCD" and take appropriate action.
(B) Empty ink tank.With the Ink LampsYou can confirm the status of each ink tank by the ink lamps. Open the Scanning Unit (Printer Cover) of the machine to confirm how the ink lamps light or flash.
  • Ink lamp is on
The ink tank is correctly set and there is enough ink remaining to print.
  • Ink lamp is flashing
Flashing slowly (at around 3-second intervals)
Ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.
Flashing quickly (at around 1-second intervals)
The ink tank is inserted in the wrong position or it is empty. Ensure that the ink tank is in the correct position as directed by the label on the Print Head Holder. If the position is correct and its lamp flashes, it is empty. Replace it with a new one.
  • Ink lamp is off
The ink tank is not set properly or the function for detecting the remaining ink level is disabled.
If the ink tank is not set properly, press the g0009324_tcm14-605384.png mark on the ink tank until the tank clicks into place. If it does not click into place, make sure that the orange protective cap has been removed from the bottom of the ink tank.
If the function for detecting the remaining ink level is disabled, replace the ink tank with anew one. See "Replacing Ink Tanks".
If the lamps are still off after reinserting the ink tanks, there has been an error and the
machine cannot print. Check the error message displayed on the LCD. See "An Error
Getting the Clear Ink Status InformationClear ink is used only when printing on plain paper.
When Plain paper (Cassette) is selected for Media type and printing begins when clear ink (PGI-9Clear) is low, a message will be displayed in the LCD.
g0011497_tcm14-605385.png(A) Confirm whether a symbol is displayed here.
g0011502_tcm14-605378.pngThe clear ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.g0011503_tcm14-605379.pngThe clear ink tank is empty. See ""The clear ink tank is empty. Replacing the ink tank is recommended." U045" and take appropriate action.
NOTE
  • The ink status information is also displayed on the screen that appears during printing.
  • Clear ink is used only when printing on plain paper. Therefore, it is possible to print on photo paper, or any type of paper other than plain paper, loaded in the Rear Tray, even if clear ink has run out.
The following error message will be displayed on the LCD when the clear ink has run out during printing on plain paper.
g0011506_tcm14-605380.pngRefer to "Replacing Ink Tanks"If you continue printing under the clear ink out condition, see ""The clear Ink has run out. Replace the ink tank." U165/U166" and take appropriate action.When the clear ink hasrun out, printing on plain paper from the Cassette is not possible. The fax, which is received under the clear ink out condition, will be stored in memory.
NOTE
It is possible to print on photo paper, or any media type other than plain paper, loaded in the Rear Tray, even if clear ink has run out.
Oct 01, 2011 | Canon PIXMA MX340 Wireless Office...
Cannon mp530 says load paper when paper is loaded
Paper not loaded error is displayed by the printer when the printer doesn't detect any paper. Here try this one.
  • Make sure that your paper is properly inserted.
  • If properly inserted and still the printer doesn't detect it. Try putting more amount of paper in the tray.
  • Be sure that there are no damaged paper in the tray.
  • Clean the rollers using a cotton buds and a clean water.
  • Now try printing again.
Hope my solution will help. Thanks for using fixya.
Jul 08, 2011 | Canon Office Equipment & Supplies
Hp j6480 printer wont print keeps sending a paper mismatch message
Paper mismatch errors occur because the product scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the product, the product reports a 'Paper Mismatch' error. The message saves paper and ink by preventing print jobs from accidentally printing on the wrong paper. For example, the print job might be for a 101.6 x 152.4 mm (4 x 6 inch) photo, but there is letter-size paper loaded in the product. The error message displays to make sure that ink is not wasted on the wrong paper type. try this out , disable the automatic paper type sensor.
  1. Open the Print dialog box.
    1. In Word 2003, click File , and then click Print
    2. In Word 2007, click the Office button (c01850900.gif ), and then click Print .
  2. Make sure that your product is in the Name drop-down list box, and then clickProperties .
  3. Click the Features or Paper/Quality tab.
  4. In the Paper type drop-down list, click Plain paper .
  5. Click OK to close the Properties dialog box.
  6. Click OK again to print the current print job.
Feb 24, 2011 | Digital Products Hewlett Packard OfficeJet...
Printer showing error message ...."printing
This means that your machine has received a print job that is teling it to print on paper that is loaded or supposed to be loaded in the bypass feed tray. You will either need to delete the print job using the operation panel or simple load some letter size paper in the bypass tray over on the right side of the machine.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 18, 2010 | Panasonic Workio DP-3030 Printer
5110 ERROR ON PIXMA PRO 9000
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Solution: Removing paper jams MP800R / MP830 / MP530
Removing Obstructions or Jammed Paper If [Paper output slot - The paper is jammed. Clear the paper and press OK] appears on the LCD, follow this procedure to clear the paper jam Clearing paper jams from the auto sheet feeder (ASF) or paper output slot
Clearing paper jams inside the printer
Clearing credit card-sized or 4" x 6" paper jammed inside the printer
ASF / Paper Output Slot
  1. Turn off the printer.
  2. Remove paper from the ASF.
  3. Gently pull the jammed paper out.
  1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
  2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
  1. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
    Note: Be careful not to touch the components inside the printer.
  2. Turn on the printer and confirm that the Alarm light is off.
    (If the jammed paper remains in the printer, the paper may be automatically ejected.)
  3. Load paper back into the ASF.
  4. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Paper jams inside the printer
  1. Turn off the printer and disconnect the power cord and USB cable.
  2. Remove the jammed paper slowly using the following procedure.
  3. Open the rear cover to check if the paper is jammed.
  4. Pull out the cassette and check if the paper is jammed inside the cassette area.
  5. Stand the printer with the rear side down, holding the document cover.
  6. Press the tabs together and pull the green cover toward you.
  7. Check if the paper is jammed.
    (If you were not doing Duplex printing, you do not have to follow this procedure.)
  8. Close the green cover and place the printer back to a normal position.
  9. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
  10. Load paper back into the ASF or cassette.
  11. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Clearing credit card-sized paper jammed inside the printer
Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
  2. Load the same paper type that is jammed inside the printer in portrait orientation.
  3. Power on the printer.
    The paper stock in the ASF will automatically feed the jammed paper from the printer.
  4. To resume printing, load the paper in portrait orientation.
If 4" x 6" sized paper was loaded in landscape orientation in the cassette and did not eject (exit), please follow this procedure.
  2. Open the rear cover.
  3. Fold in four a piece of letter-sized plain paper.
  4. Push in the folded paper until it hits the jammed paper.
  5. If the jammed paper is visible from inside the printer area, pull it out and proceed to step 7.
  6. If the jammed paper cannot be pulled out, push in the folder paper from the rear so the jammed paper is in between the feed rollers.
  7. Pull out the folded paper and close the rear cover.
  8. Power on the printer and confirm that the Alarm light is off.
    The jammed paper should automatically eject.
  9. To resume printing, load the paper in portrait orientation.
Thanks
Thiru
Jun 17, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Our 4506 message says load SEF letter
Check if the orientation of the printing document matches to the paper available in the copier's trays.
Load SEF letter: means Load Short Edge Feed letter (landscape).
Good luck and please rate me, thanks.
Jan 30, 2009 | Ricoh 4506 Copier
Show the load paper error
There is a paper motion switch behind the tracter feed assembly that might be stuck. Check that and also clean arround the tractor assembly.
Jan 01, 2009 | Printronix Line Matrix P5005B Printer
Can't print faxes due to error messages
Please check rear door area for paper, can you use manual feed slot? Power off machine with all jams removed and paper loaded, then power on, can you tell us exact error message/lights that are shown in this state?
Oct 15, 2007 | Brother IntelliFax-2820 Laser Fax
Canon PIXMA MP470 All-in-One Printer Logo
67 people viewed this question
old marine
old marine
