Question about Onkyo TX-DS575 Receiver
TX-DS575 reciever i have a onkyo TX-DS575 reciever and when i turn it on it does nothing i have to tap it kinda hard to get it working. If anybody knows what the problem is please contact me Thanks.
  • 56 Answers
Normally you hear a clicking sound coming from the inside when you turn on your amp. That's the sound of the magnetic circuit breaker (switch). If you tap your amp to turn it on, and if the amp gets turned on after you did it:), then I suppose the problem is on the relevant switch.
Posted on Jul 04, 2007
SOURCE:
I have lost the remote control of my Onkyo TX-DS575 AV reciever/DTS Amp and cannot find one in the market. I have used a universal remote which had a couple of Onkyo codes with it but it doesn't work. Is...
Amazon.com, MyRemoteControls.com, and Remotes.com all sell a replacement remote for the TX-DS575. I have also seen the Onkyo TS-DS575 receiver with remote listed on eBay for as low as $35. Keep looking; the remotes are out there.
Jan 22, 2014 | Onkyo TX-DS575 Receiver
Onkyo TX DS575x reciever remote problem
You might try this replacement
http://www.remotes.com/remotes/servlet/rs?a=gmi&uid=11953114154530&smodel=TXDS575&brand_pn=ONKYO_TXDS575
Nov 17, 2007 | Onkyo TX-DS575 Receiver
Remote doesn't operate reciever
Hello Fixya customer,
Thank you for your question.
Please determine if the "Audio" button is actually working.... after pressing the audio button, can you still control the DVD, if not then the remote has switched to the Onkyo. Although, this is not 100% conclusive, unless you have a 2nd remote to test the Onkyo with, it provides a sound basis to proceed.
Assuming the remote is transmitting and the IR receiver on the front of the Onkyo is not otherwise blocked, likely faults include the IR receiver, input to the Micro processor, and the Micro processor.
The most probable fault is the IR receiver.
Thank you for using Fixya, and if I can help you further, please let me know.
Apr 29, 2010 | Onkyo TX-DS575 Receiver
Left speakers are not working on my onkyo tx-ds575
Check the units internal "menu" settings for speakers and audio. beyond that, there would be an internal problem and neded service. Hope this helps
Jul 05, 2009 | Onkyo TX-DS575 Receiver
I need the remote code for my onkyo tx-ds575, my remote isn't working and i want to program another remote to control this unit.
Get yourself a remote from Logitech Harmony family. It magically knows all the possible codes. And the support is VERY helpfull.
Mar 22, 2009 | Onkyo TX-DS575 Receiver
Onkyo TX-DS575 - intermittent audio
You have a problem that was inherent with all Onkyo receivers from this period. You need to contact Onkyo because the microprocessor needs to be replaced. Last I checked, its about $80 from onkyo.
This is NOT an isolated incident as darn near every Onkyo receiver model had this problem.
Good luck...
Rob
Nov 15, 2008 | Onkyo TX-DS575 Receiver
Onkyo TX-DS575X, remote intermittend malfunction
You have to raplace IR sensor PIC-26043TE2 or similar and should help.
Oct 08, 2008 | Onkyo TX-DS575 Receiver
Will not power up but stand by light is powerd up
I have onkyo tx-ds575 and i need to conect it to my tv and have audio from a LCD flat panel.
Oct 05, 2008 | Onkyo TX-DS575 Receiver
Need fiber optic input jack for Onkyo TX-DS575
Had it ever worked, or are you setting it up for the first time?
Have you ASSIGNED the digital input in the menu?
Dec 18, 2007 | Onkyo TX-DS575 Receiver
Onkyo TX-DS575 turns off after about 10 min.
it could be a failing speaker causing the fault. Disconnect one speaker and run it to see if the problem persists and repeat with a different speaker until all speakers have been disconnected and the unit run to failure. If it stays ok, with a particular spkr off, it's the speaker. If it shuts down no matter which ones disconnected, it's probably a crack on the PCB which expands as it heats and causes shutdown.
Dec 16, 2007 | Onkyo TX-DS575 Receiver
Onkyo TX-DS575 Receiver Logo
274 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
