Question about Panasonic WORKiO DP-C322 Printer
THE CONTROL PANEL DOESN'T WORK
THIS PANEL DOES NOT EVEN LIGHT UP. THE SYSTEM IS GETTING POWER
Kitchenaid dishwasher 577
Does it work though? If the light is staying on after you cut power then maybe a genie is living in there :)). Other than that it could be a bulb with bad or loose connection. I do know those touch pads behave weird if there was a power cut/surge. Mine did that bit it still works. I'm just waiting to see if a light blows or if some other short happens. Anthony
Jun 15, 2013 | KitchenAid Dishwashers
My Pentair Easy Touch inside remote reads 'No Comm' even though batteries are fine. I get the same message even close up to the transmitter antenna. My pool service looked at it and noticed
Your power center outside has to be "trained" again so it and the remote recognize each other. I don't have the charts in front of me but check your manual or one online. It's fairly simple to do.
If that still doesn't work, the problem may be with either the remote or the power center. Good luck with it.
Jan 16, 2013 | Pentair Easy Touch Indoor Control Panel...
Spectroniq tv doesn't turn on, lights off.
The fuse is inside--power cord should go almost direct to it--beyond that if fuse good is power supply for the set.
Nov 06, 2012 | Televison & Video
The TV won't turn on. The little light by the power button doesn't even come on
Blown fuse caused by a shorted power supply. Relacing the power supply board should solve the issue in most cases. You can get a power supply board from www.tvrepairworld.com
Oct 27, 2012 | Polaroid LCD-1700 17 in. Television
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 | Dishwashers
Blinking lights
Power off printer, remove power plug from printer, remove usb cable from printer, pull out paper and check for jams, check toner cartridge, clean area underneath the toner cartridge head, uninstall printer from windows control panel, reboot computer, plug-in printer with a different working usb cable, plug in power to printer, power on printer, reinstall printer driver. All in those steps exactly. If that doesn't work I would say you have a bad printer on your hands.
Nov 16, 2011 | Dell 1110 Laser Printer
No power to drivers door all switces and functions including dome light,mirrors controls, window switches and even the alarm doesn't work on drivers door only
The door functions in your vehicle are controlled by several control modules and are dependent on proper class2 communications between several modules including
> Body Control Module
> Drivers Door Module
> Passenger Door Module
> Powertrain Control Module
> Instrument Panel Control Module
Begin the system diagnosis with the Diagnostic System Check - Door Systems. The Diagnostic System Check will provide the following information:
> The identification of the control module(s) which command the system.
> The ability of the control module(s) to communicate through the serial data circuit.
> The identification of any stored diagnostic trouble codes (DTCs) and their status.
> The use of the Diagnostic System Check will identify the correct procedure for diagnosing the system and where the procedure is located.
Sep 14, 2011 | 2003 Chevrolet Suburban 1500
The Plug is sending power to the air conditioner, but nothing lights up or moves..have opened it and see no damage and the correct volts are being pushed. What could cause this to not work at all even...
One of the control panel circuits may be at fault and doesn't allow the power past that point. If you have a multimeter, check the circuits in the control panel for continuity, until you find the right one.
Hope this helps & thanks for choosing FixYa.
Aug 17, 2011 | Comfort-Aire RAD-81 Air Conditioner
My HP PL4260N doesn't show any pictures. The sound and remote work fine. I even bought a new chip for it and it still didn't work. Please help!!!!
surely there is problems with the lcd controller... you need a qualified technician to check the power consistency in your lcd controller.
May 27, 2011 | HP PL4260N 42 in. Plasma HDTV
Panasonic WORKiO DP-C322 Printer Logo
21 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
