Question about Jenn-Air Dishwashers
Dishwasher model JDB1250 has L3 on control panel, what does this mean
2 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: Fon the dishwasher
Hi, welcome to Fixya.
Based on the info you've provided, the dishwasher is indicating a error during the "fill" stage, hence the "F" being displayed on the Bosch machines.
Here's how to perform a test or diagnostic...
Make sure the power button is in the off position ( open & closing of the door will activate the "auto shut off" ).
Once certain it is "off" press and hold both the regular button and rinse & hold button, then turn the unit "on" while continuing to depress those 2 buttons. Initially, control module version # will display ( i.e. "20" = version "0" without jumper...not important for this ).
When the buttons are now released, the lights above them will flash. To start testing, press both the "regular wash" and "rinse & hold" a second time.
Let the test follow through, ( grab a coffee and observe, this will take a while )
When testing has ended, the display will show an error using codes as follows...
"0" = no error.
"1" = aqua sensor fault.
"2" = heating fault.
"4" = filling fault. and finally.
"8" = NTC ( temperature sensor ) fault.
The "F" code will not appear in test mode, only during wash. If you have a failed level switch for instance the test will display "4" and will continually fill and drain and test won't complete until you press the "on/off" button.
If the test complete's without and error or won't fill, replace the water valve. Original part Part # 425458 at "searspartsdirect.com", "apwagner.com" or #1105846 at "repairclinic.com" ( they use there own numbers ) or you can check locally by your model number & serial number.
Let me know if I can assist you further. Hope you found this helpful and if so please allow for a positive rating.
Thank you for choosing "fixya" and good luck.
macmarkus :)
Posted on Jul 08, 2010
Zdt12011fa dishwasher is built in and the flood alarm is in operation - how do I reset?
First you need to remedy failure or any leakage than reset appliance.
Under Reset I mean to delete all alarm stored in memory.
1. Turn off the dishwasher.
2. Press and hold S1 while switching on the dishwasher. Keep
holding the Program button until:
- LED L1 blinks, L2 and L3 is on
- Release S1
3. When L1 is blinking, L2 and L3 is on, press the S1 before L2 and
L3 is turned off.
- LED L2 is blinking, L1 and L3 is turned on.
4. Wait till L1 and L3 is turned off, then press S1
- All used LEDs flash 5 seconds on 1 second off repeatedly.
- If buzzer is equipped, it beeps for 5 seconds
- The alarms saved in the memory are erased
5. Switch off the appliance.
26259192-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Dado
Aug 14, 2016 | Zanussi Dishwashers
I have a Whirlpool Quiet Partner Two dishwasher. The rinse only light & quick wash light constantly blink and I can't run it, none of the buttons will work. Is there a way I can reset my dishwasher?
This generally means the control panel is no longer working and must be replaced. That's the entire plastic assembly at the top of the door, in which the buttons reside. Disconnect power first, remove screws inside the door which hold the panel in place. Unplug power connectors, remove circuit board control board. Find dishwasher model number and search parts for that model. The part is pricey, more than $100 last time I replaced mine. Install control board into new panel, make power connection. Reassemble door. Good to go.
Oct 03, 2015 | Whirlpool Dishwashers
Start button does not light
please follow this steps and fix it. GOD BLESS YOU
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer or Electronic control
Replace if defective (note: uncommon problem).
4. Selector switch
Read more: http://www.appliancepartspros.com/repair-help/dishwasher-repair-help.html#ixzz2aaj83j00
Jul 30, 2013 | Jenn-Air 24 in. JDB1250 Built-in...
Dishwasher not rinsing or cleaning properly. It appears to be clogged. Not sure the model number. We cannot even find the model number.
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Apr 24, 2011 | Jenn-Air 24 in. JDB1250 Built-in...
Dishwasher will fill and drain, but no water will go through the spin arm.
the spin arms get clogged with food ....
try cleaning the spin arms............
cheers
Apr 11, 2011 | Jenn-Air 24 in. JDB1250 Built-in...
Not draining properly, water left in the base after a wash cycle
check the ABS fitting under sink where drain hose attaches. remove debris if needed. if that doesn't fix then call a servicer
Nov 28, 2009 | Jenn-Air 24 in. JDB1250 Built-in...
Dishwasher will not drain completely
dishwasher will not drain.kenmore model.
I have taken it apart can not figure our how to take out last plastic part a bowl shaped black plastic.
Mar 22, 2009 | Jenn-Air 24 in. JDB1250 Built-in...
Whirlpool GU2500XTP dishwasher went dead in mid-cycle.
"Wondering if this model has had reliability issues with the circuit card." ...If by circuit card you mean the electronic control board, that part number is used in many other models as well. In my experience with these control boards, I believe they have a low failure rate.
Make these checks if you haven't done so yet...
Check for 120V (breaker). Look for loose/shorted wiring connection at the dishwasher's junction box. Check all wiring connections to the control panel, electronic control and thermal fuse. Test the continuity of the thermal fuse (part # 8193762). If that's ok, you have already replaced the control panel so the problem is likely with the electronic control board (part # 8564546).
Good luck.
Mar 12, 2009 | Dishwashers
Dishwashers Logo
49 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
