Question about Cobra Radio Communications
Will improper ground on your antenna mount make cb not work
    Genius:
  • Cobra Master
  • 1,795 Answers
What do you mean by not work? does it come on? If you have no ground it will still come on but you will not hear anything until it is grounded. Also your SWR has a good part in it. If it is to high you will not be able to hear the person next door and you have a chance of burning out your finals over time. keep the SWR out of the red and you will be ok as far as the finals go.
Posted on Nov 04, 2013
Shuttle83
  • 1139 Answers
SOURCE: CB transmission
Hello 64driver,
Make sure the radio is grounded properly and that the SWR is around 1.2:1, 1.3:1 is good but try to get it to 1.2:1. Also take a power output reading while keying the mic. To do this with your power meter put it in-line with the CB and your antenna and key the mic you should get about 4 to 5 watts PEP. If this is the case your unit is putting out the proper power level, if not have the power amplifier checked by a qualified repair shop.
I hope this helps
Shuttle83
Posted on May 14, 2008
  • 39 Answers
SOURCE: I have a Maxon Hcb 10c and I lost the antenna that
Radio Shack
Posted on Mar 08, 2009
  • 13 Answers
SOURCE: Cobra 75 WX ST powers on but does not work
MAKE SURE THE ANTENNA IS NOT CONNECTED, THEN TRY AND SEE IF RADIO POWERS UP, IF IT DOES NOT THEN YOU DO NOT HAVE PROPER GROUND
ALSO ARE YOU USING THE COBRA STOCK MIC ?
ALSO MAKE SURE THE RADIO IS ON CB MODE NOT WEATHER MODE
Posted on Apr 01, 2009
tbirdfan1
  • 3051 Answers
SOURCE: With my CB I am getting feedback through the am fm radio speakers
Hello there:
the shielded coax rgu-45 series is probably the best one for this application also if you run the radio to a different fuse or u can also get a surpression filter that goes on the coax line I own a WL9000 KW. i had the same problem untill i got the filter installed at a loves truck stop in texas and no more problems since ok?
drive safe and best regards mike (warner transp.)
Posted on Aug 17, 2009
Goofguyster
  • 379 Answers
SOURCE: poor receive with my Connex 3300 HP radio
get a K-30 antenna ist magnetic if that dont work your speaker in the Cb is broken
Posted on Sep 14, 2009
Do i need a certain antenna?
The fiberglass provides no ground plane area for the antenna and radio waves. Your Standing waves (aka: SWR or Reflect) are probably very high. I suggest mounting the antenna on the cab of the truck. You "could" try aluminum tape on the cap and mount the sheilded side of the coax to it somehow. Without a ground plane much of the RF Power of you CB will be reflected back to the Final Output Transistor(s) (Final or Finals), overheat it and possibly damage and burn it/them out. If you are just running the CB without an amplifier(Linear or sometimes called a box), a magnetic mount antenna should work fine and be less of a problem than permanently mounted antennas. That's a plus when going into a parking garage. Even if you decice to get an amplifier at a later date, you should be able to use it with the magnetic mount antenna as long as the antenna you but is rated for several hundred watts, you Standing Waves are Low, and the amplifier doesn't put out more power than the antenna is rated for. I hope this helps.
Apr 17, 2014 | Midland 1001Z 40-Channels Base CB Radio
Added new antenna and now im failing rf output and antenna radio test?18ft coax and a 48in ant.
First thing is to be sure the mount is not shorted in any way--and also to make sure that where it is mounted it is actually connected to ground--many newer vehicles have insulators so a bumper even if metal has no ground to work off of.
No ground, open or short in coax, open or short in mounting bracket all can cause no swr or high swr.
May 01, 2012 | Cobra 29lx Cb Radio W/clock 29 Lx Lcd
When i key my mic my antenna light comes on. i have tried 2 different antennas and it still does it. what can i do to fix it?
The problem is most likely the coaxial cable.
A ground problem can cause this problem. Coax connection and bottom of antenna lug mounted should be in contact with mount's base. Antenna should not touch mount there is a insulator between them that antenna shaft passes thru. Mount must have a metal grounded mount location is a electrical circuit also.
Check SWR with the meter in radio. The ant light circuit could be out of alignment from factory.
Aug 16, 2011 | Cobra 29 LTD CB Radio
My radio receives the wx stations fine, it transmits fine but it will not receive when switched to cb, I have tryed ex speaker, still nothing. mete wont move in receive mode, but when keyed the tx is over...
Here is the list just scratching the surface.
  • Bad antenna
  • Bad coax cable ......grounding externally or internally with shield.
  • Bad/poor ground for antenna..........door to body, painted parts when mounted elsewhere.
  • Antenna installed incorrectly. Nylon grommet must insulate antenna from contact with mounting bracket. Coaxial connector must have contact with bracket for grounding.
Jul 02, 2011 | Uniden Bearcat Pro PC68LTW 40-Channels...
I can't get the swr value close to 1 it's over 3 what am i mising
Several things are working against you.
1 Antenna location= Needs to be in CENTER of car or truck, and high. no grounded metal can be next to the element (the hot/positve part of the antenna)
2 the only way to really ground the antenna is by having a flat metal ground plane under the antenna. DC grounding does NOT do this, that is a misunderstanding.
3 make sure you use a tunable antenna. I have found the wilson's to be very easy to tune and performe very well, for a base loaded antenna.
4 in short a wilson or k40 magnet mount placed on the very top of the roof in the center will have a perfect ground plane. Then shorten or lengthen the steel whip to ajust your SWR's. You will get the best results this way. This is the ONLY way to achevie good performace.
5 I will say this the absoulte best antenna is the 102"steel whip, if you got the clearnce and dont mind it hitting tree limbs put it on a big magnet mount with a spring at the base and youll have a perfect antenna. But the wilson is shorter and easier to tune.
May 15, 2010 | Cobra 29 LTD CB Radio
Antenna isnt grounded
Could be fuel pump whine.
You'll have to add a electrilytic capacitor from the pos lead to the pump to chasis ground. Or, get an antenna mount that mounts to/and is grounded to the body of the car or truck. You can also try ground straps from the body to the trunk lid if the mag mount is on the trunk lid.
Apr 02, 2010 | Cobra 29 LTD CB Radio
I have everything hooked up but all i get is static. I had someone from radion shack check the ground and hookup and they said it all looked good. I have tried numerous CB's and different anntennaes still...
Truck boxes may be the best looking place to mount a CB antenna but in my experience they are the worst place for performance.
The 'ground' you need is not an electrical ground but an RF ground. The easy answer is that you need to mount the antenna to a mirror or the bumper or even use a magnet mount instead on the roof. The body of the vehicle provides an RF ground that the small truck box cannot. The only way it might work is to use flat, wide ground straps at all four corners of your box to the bed of the truck. You need metal-on-metal contact.
Feb 07, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
On my 77-099 Cb MIDLAND Radio I wonder can i use a antanna that is used for vehicle can be made for a home base radio place.I BOUGHT A MIDLAND CB RADIO AND MADE IN TO A HOME BASE RADIO THAT IS MADE FOR...
Generally this is not a good idea. The antennas that are designed for use with a car, use the body of the car as a ground plane. If you try to use this in a house (or even outside the house), it's not going to work.
Your only chance at even getting such a setup to work would be to attach the antenna to a LARGE flat piece of metal, approximately the size of a car, which is then grounded with a long metal rod into the earth.
I'd really suggest looking into buying a proper home CB antenna, which would then need to be mounted somehow to the roof of the house (or as high up as possible.) If this is not a feasible option, you should do a Google search for "CB Dipole Antenna", and get instructions on how to build and tune your own antenna. Dipoles are not overly difficult to construct, and perform quite well.
Nov 08, 2009 | Midland 77-099 CB Radio
What antenna would you recommend for my cb? cobra 29ltd
depends on what vehicle its going on. If its a car, you don't need anything crazy, unless you are going to run a linear.
You are fine with a wilson 500/1000 mag mount or a k40 mag mount.
just make sure you tune the antenna for lowest SWR.
Sep 29, 2009 | Cobra 29 LTD CB Radio
I have a Cobra 29 LTD with Bluetooth. I have no static no matter where I set my squelch and RF gain unless my noise blocker is off. Both my rx/tx and antenna lights turn red when mic is keyed. I have try...
if the antenna warning indicator is lighting during transmission then the antenna is either located and.or installed improperly or a defect exists in the antenna mount or the feedline itself, including connectors.
Jun 08, 2009 | Cobra 29 LTD CB Radio
Radio Communications Logo
24 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
