Mic is not working.
No recording
  • 27,725 Answers
Click start control panel on the left select Hardware and Sound then select manage audio devices then recording you should see a Microphone right click select enable Windows 7
Click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a Microphone right click select configure speech recognition then You will see earphones with a speaker among a list set up a microphone headset with Microphone then next and next again you should see your earphones with microphone being configured Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list Make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab Make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it b> Windows 7 right click on the speaker icon in the taskbar select either playback or recording devices you should see your microphone listed under the recording tab right click on it select properties at the bottom select use this device enable Hope this helps.
Posted on Jan 11, 2013
The Mic is not working
right click on the speaker icon and make sure external mic is set up. One time I had to use my internal mic to record stuff it was a pain.
Play back devices
Recording Devices
Jan 28, 2014 | Frisby Computer PC Laptop Headphones...
Won't Record From Shotgun Mic.
Adjust Recording Levels.
Win 7Start > Control Panel > Hardware and Sound > Sound > Microphone >Properties > Level.
Oct 04, 2012 | Alesis PalmTrack Handheld Portable SD...
Aiptek GSV 1080P HD Camcorder external mic feature won't work.
Possibly an impedance mis-match - check in both manuals.
Sep 27, 2017 | Video Cameras
I have a DELL Studio 1737 running Windows 7, with integrated web cam. i am trying to make videos with web cam and video is perfect but no sound on playback. Dell webcam central is what i am using to make...
Sounds like a software issue, possibly with webam central. There's a free player that has good codecs, and it may help you. Here it is:
http://www.finalmediaplayer.com/
This will be an easy fix if it works.
Jul 31, 2010 | Computers & Internet
Mic not working properly : I have a iNTEX Headphone with a mic, the mic is not working at all. I've tried recording my voice(which did not work out),In control Panel the default Voice recording device is...
u need to check u r sound setting .plz click on sound icon in taskbar then click on sound property and recording there u can check u r mic if mic not working so srry dude u need to buy a new mic kkkkkkk
Oct 28, 2009 | Logitech Premium Headset
Webcam recorded audio have interferance
make sure you only use 1 mic .if that dont work try pluging in a diff mic. most laptops have built in mic's it might be bad disable it in control panel and use new mic
Oct 07, 2009 | Toshiba Satellite A135-S2386 Notebook
My laptop microphone isnt working
Good day, Hi, to test your laptop mic, open the sound recorder. 1. if you ar using XP, goto START, All Programs, Accessories, Entertaiment, Sound Recorder. If the sound recorder loads normally, press the red button, shout as load as you can, you will see sound waves on the recorder. 2. If the sound recorder does not loads, chances are your mic isn't working properly, Load the device Driver for your mic, you can find the driver on the CD that came with your laptop, if not you may need to go to the Internet to find the MIC driver. 3. If the driver is loaded on your laptop, chances are it may be defective, you have 2 options, 1. replace the mic on your laptop, which requires you to dismantel it, get the defective mic and replace it. 2. just get an external mic. hope this may help.
Aug 02, 2009 | Computers & Internet
I got a problem with my mic
Good day, sir/ma'am , there are several reasons why a mic does not work, let me give some. 1. its not activated, to check if it is activated, load the sound recorder program on windows. press record and shout on the mic, wave patterns can be seen on the recorder. 2. you may activate the mic and speaker if you cant hear the voices by. opening the volume control settings, options, properties, place a check on mic volume. there are other optons as well. 3. the mic is physically damage due to open wiring. get a new one. hope this may help. thanks
Jul 16, 2009 | Radio Communications
No recording?
The static after several seconds seems like this is a problem with certain versions of OS X. You might be able to fix it by downgrading or upgrading. Apple Forums say that it's fixed in 10.5.6.
You can double check that this is the problem by trying it on a Windows computer.
Jul 28, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Microphone not working
To locate the source of your problem (with the information available):
Try your mic on a different recording device. Something simple like a tape recorder.
  • If it works, the problem lies in the your recording system.
  • If it doesn't, The mic is the problem.
Or:
Try a known working mic on your system.
  • If it works, the mic is the problem.
  • If it doesn't, the problem lies in the your recording system.
Thats about all I can give you with the info provided.
If these tests point to the mic, replace it. If they point to your recording device/system/whatever, more details will be necessary to effectively troubleshoot your problem.
Hope this helps,
Mike
Jul 23, 2008 | Audio Players & Recorders
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
