Question about Dryers
I have a maytag quiet series 200 gas dryer that will not stay heated
    President:
  • 1,922 Answers
Replace the gas valve coils on the top of the gas valve they get weak from the heat of the dryer and can't keep the valve open
Posted on Jan 12, 2013
fphandyworks
  • 56 Answers
SOURCE: my maytag dryer is blowing cool air
it should be located it a small trap door around the drum either on the side , inside , or on the bottom. to replace it you must remove the screws the hold it in place slide it out remove the wiring and then slide the new one in screw it back in and plug the wires back on it. please make sure during this process the dryer is unpluged from the wall plug. hope it works out for you .
Posted on Jan 05, 2009
  • 1214 Answers
SOURCE: Maytag Quiet Plus 2 dryer
I can't speak for which one is best, but I I can help you fix the no heat problem.
I am assuming it's electric heat. If it is, I bet the element has failed. If you know how to troubleshoot with a volt-ohm meter, I can walk you through the repair.
Let me know if you have the wiring diagram, or can find it on the appliance. Also let me know if you know how to read one.
Posted on Feb 01, 2009
dragonsthatk
  • 547 Answers
SOURCE: gas dryer burner won't stay lit on maytag dryer
thermo cupple need's to be replaced
Posted on Feb 17, 2009
SOURCE: Maytag Quiet Series 200 Electric Dryer
I also had a similar problem with my maytag dryer which is 3 1/2 years old. It was the idler lever assembly with pulley. The part number is 11222607JG and the cost is about $20.00. Hope this helps.
Posted on Sep 07, 2009
  • 55 Answers
SOURCE: I have a Maytag Heavy
That's easy, first of all you must have the Dryer on flat floor I mean verticly right. And try not to put too many clothes to get dried.
Posted on Sep 12, 2010
What causes the dryer to blow air but not heat up?
Sounds like the thermostat has gone out. www.repairclinic.com has helped me so much in the past. Have the model number ready and look at the troubleshooting questions. Good luck.
Oct 08, 2014 | Dryers
MAYTAG QUIET SERIES 200, THE DRYER ISN'T DRYING NOT HEATING CLOTHES
this problem could be that the heating element in the dryer is not working and may need replacing
Aug 14, 2011 | Dryers
Maytag quiet series 200 electric dryer the dryer turns on and seems to work correctly but does not dry the clothes does not get warm or even hot
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 28, 2011 | Dryers
I have a quiet series 200 Maytag dryer. The dryer comes on but the drum does not turn?
Sounds like your belt broke. Here is a video to show you how to replace it if it is broken.
Here is a link to the part.
Nov 30, 2010 | Maytag PYE2300AY Electric Dryer
Maytag quiet series 200 does not heat up..turns any blows cold air..it's gas
souds like u have a bad ignitor or thermocouple open panel and turn off gas and start dryer and watch to see if the lighter is trying to light it if it is then u probably have a bad gas valve
Feb 24, 2010 | Dryers
Apr 04, 2009 | Maytag Dryers
My maytag dryer is blowing cool air
Jan 05, 2009 | Maytag MDE3706 Electric Dryer
Maytag gas dryer fires, then shuts down
may be the coils on the gas valve. there are 2. usually they need replacing when the ignitor glows but no flame
Nov 20, 2008 | Maytag Dryers
Open Questions:
Dryers Logo
95 people viewed this question
Top Dryers Experts
