Question about Candy Dishwashers
P1 p2 p3 lights on candy dishwasher water dies not heat
  • 1462 Answers
SOURCE: candy cd623 uk dishwasher water not heating up
not familiar with model. element can be inside cabinet in which case it will be obvious or may be in a cylinder heater mounted in the base. suspect stats as well or possibly the module
Posted on Mar 20, 2007
  • 9 Answers
SOURCE: Baumatic BFD64SS Diswasher - power light on but can't programme
http://www.manualnguide.com/dl/12334/
Posted on Jan 25, 2009
  • 96 Answers
SOURCE: The water in my Candy Nova CD112 Dishwasher does not heat up.
your water comes from your hot side of your water but your element in the bottom might be bad
Posted on Dec 07, 2009
heatman101
  • 43501 Answers
SOURCE: dishwasher not draining water
Here is a tip that I wrote that will help you with your problem...
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Apr 07, 2010
SOURCE: candy nova cd112 dishwasher fills with water then stops working
nova cd112 this is a simple fix the machine has a electronic switch to add water to the machine it then has another switch to say the machine has water iin it , this switch is the one that is not working this is the one that turns on the element and heat the water .it costs around a tenner to replace u can find it as it is connected to the element via a wire conection .this a a common problem of over enginearing as this switch is not needed and is not on older machine .ie this switch can only come on when the machine has water in it in other words only after the switch to put water in the machine has been on.can this go on i hope u know what i mean lol. now u can replace this yourself or get an engineer it should take an engineer no more than 10/15 mins to fix better still have him bypass this switch and u will never haver the problem again as this switch is prone to going fixthis and the machine should last years no problem as its not a bad machine not quite a bosch but better than a zanussi or indicit etc hope this helps and may i just say that i tried everything including replacing the element ,stat and cpu non of which worked before realizing it was this .i must also say before u try this. Switch on your machine on put it on a universal cycle as u hear the water going in the machine open the door and add hot water as hot as u can close the door and the machine should do a full cycle including emptying and reheating the water this proves its not the cpu ,element or stat note the machine will not do the cycle without the hot water going in at the start if it does the cycle then its 100 % this switch hope this helps and sorry for the lond explantion bye
Posted on May 02, 2010
Ritetemp model 8050c if i set temp. To 74 it goes up to 82 and beyond in minutes or hours. How can i set it to stay where i want it
While in heating or cooling press the temp hold button behind the door. Hold will be displayed rather than p1, p2 p3 or p4.
Jun 14, 2017 | Heating & Cooling
Water doesn't heat up and cycle seems to be stuck, candy DFI 45
What is a Candy brand dishwasher? Made in the UK? That is not a manufacturer I have ever heard of here in the US.
What do you mean, 'doesn't seem to heat up any sense?'
If the dishwasher is older than 5 years, write it off to age a buy a new, high quality machine. Or do the dishes by hand.
Machines get old and die. If you are UK native, don't buy anothre Candy.
Aug 19, 2014 | Candy DFI Plan Built-In Dishwasher
What does a P3 code mean? On a Hobart LXI high temp
P3 code refers to the probe near the airgap at the back. It is monitoring the rinse temp. P2 is the booser probe, and P1 is the wash tank. The control board will store error codes, so once changed, you can access the memory and clear it.
Jan 05, 2014 | Dishwashers
I have an asko T760 Butterfly dryer. It is stuck on P2 but will not run. I shut off the unit, turned back on. The LCD flashes between P1-P4 and what they are, such as extra dry, dry, normal dry, & iron...
Hi.
The machine is telling you that there is overfill, f2 and 4 are faults with overfill system. Lights blinking, pump running and controls dead also indicate an over fill fault :
"1. Disconnect the power to the unit
2. Remove the lower access panels and check the tray under the dishwasher (you will probably find it is full of water)
3. Use a towel or a sponge to remove the water
4. There is a float that should stop the operation of the dishwasher and run the pump if water is in this tray. Check this pump to see if it is functional
5. Test the dishwasher
6. If there are no leaks from the dishwasher into the pan, check the drain hose under the sink
7. THE DRAIN HOSE MUST RUN UP TO THE TOP OF THE UNDERSIDE OF THE COUNTERTOP THEN DOWN TO THE DRAIN. (If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overfill the tray"
Here all diagrams.
Regards.
Ginko.
Apr 26, 2011 | Asko T761 Electric Dryer
I was given a lx 30 hobart when i hooked it up i got a p1 then it spelled out d r o p can you tell me what this means thank you
P1 means a temperature probe reading is out of range, I believe it refers to the temp. probe in the sump inside the dishwasher. There are also P2 and P3 which refer to the booster tank temp. probe and the rinse water temp. probe. Remove the lower front panel and make sure the connector going to the sump temp. probe (two small black wires) is connected well and the wires look OK. Replace the temp. probe and P1 should go away.
"DR" followed by "OP" means "Door Open". If this is displayed when the door is closed, you most likely need to replace the magnetic door switch. Open the door and remove two phillips head screws which are installed vertically, holding the control panel drawer closed. Then open the control panel drawer (sometimes it's kind of stuck,but not usually). The magnetic door switch (i.e. reed switch) is located on the right side of the drawer, held down by a small metal bracket. Of course it's possible your problem could be the magnet in the door itself, but most likely the door switch is the problem.
Mar 02, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
KENWOOD DNX5120 DVD Navigation System GPS Receiver: I just purchased a used vehicle with this system. ...
Its a lil Play button at da bottom of screen wen on tuner! tap it until it say p1 p2 p3 etc, turn to wat station you want and hold either p1 p2 p3 etc!
May 09, 2010 | Kenwood DNX5120 DVD Navigation System GPS...
Send to read/writer a plus hoop design it only reads the p1 file
After I stitch out the p1, I have to go back and load the p2 design and continue stitching after I adjust the hoop to the p2 setting. Then I do the same thing with the p3. It is a pain to go back and forth, but it works!
Nov 08, 2009 | Husqvarna Rose
Hobart lx 40 - problem D 1
Does it show a wrench icon and P1?
error codes are p 1to 3 for probe errors, or E1 to 7 for error codes.
P1 is the probe on the wash tank. It's a thermistor with two black wires to a white connector. There is another on the booster front (P2) and a 3rd on the rear airgap, (p3). You could try exchanging 1 and 3 to see if the fault changes too. You have to drain the booster to swap P2. If it can't determine the wash tank temp, it won't know to control the heat and shows the error.
Mar 20, 2009 | Hobart 25 in. LXIH-4 Built-in Dishwasher
How to create owr own calculater
for all os ? you must use java language! this is the code:
//<applet code="calmayank"height=300 width=300></applet>
import java.awt.*;
import javax.swing.*;
import java.awt.event.*;
public class calmayank extends JApplet
implements ActionListener
JTextField t1;
JButton b1,b2,b3,b4,b5,b6,b7,b8,b9,b10,
b11,b12,b13,b14,b15,b16,b17,b18,b19,b20;
GridLayout gl;
JPanel p1,p2,p3;
public void init()
gl=new GridLayout(5,4);
p1=new JPanel();
p2=new JPanel();
p3=new JPanel();
p1.setLayout(gl);
t1=new JTextField(17);
b1=new JButton("1");
b2=new JButton("2");
b3=new JButton("3");
b4=new JButton("4");
b5=new JButton("5");
b6=new JButton("6");
b7=new JButton("7");
b8=new JButton("8");
b9=new JButton("9");
b10=new JButton("0");
b11=new JButton("+");
b12=new JButton("-");
b13=new JButton("*");
b14=new JButton("/");
b15=new JButton("@");
b16=new JButton("$");
b17=new JButton("%");
b18=new JButton(".");
b19=new JButton("?");
b20=new JButton("=");
p2.add(t1);
p1.add(b1);
p1.add(b2);
p1.add(b3);
p1.add(b4);
p1.add(b5);
p1.add(b6);
p1.add(b7);
p1.add(b8);
p1.add(b9);
p1.add(b10);
p1.add(b11);
p1.add(b12);
p1.add(b13);
p1.add(b14);
p1.add(b15);
p1.add(b16);
p1.add(b17);
p1.add(b18);
p1.add(b19);
p1.add(b20);
p3.add(p2);
p3.add(p1);
getContentPane().add(p3);
b1.addActionListener(this);
b2.addActionListener(this);
b3.addActionListener(this);
b4.addActionListener(this);
b5.addActionListener(this);
b6.addActionListener(this);
b7.addActionListener(this);
b8.addActionListener(this);
b9.addActionListener(this);
public void actionPerformed(ActionEvent e)
if(e.getSource()==b1)
t1.setText("1");
else if(e.getSource()==b2)
t1.setText("2");
else if(e.getSource()==b3)
t1.setText("3");
else if(e.getSource()==b4)
t1.setText("4");
else if(e.getSource()==b5)
t1.setText("5");
else if(e.getSource()==b6)
t1.setText("6");
else if(e.getSource()==b7)
t1.setText("7");
else if(e.getSource()==b8)
t1.setText("8");
else if(e.getSource()==b9)
t1.setText("9");
Dec 15, 2008 | Computers & Internet
Dishwashers Logo
56 people viewed this question
Top Candy Dishwashers Experts
Charles T Nevin
Charles T Nevin
 Evgeniy_Getz
Evgeniy_Getz
Are you a Candy Dishwasher Expert? Answer questions, earn points and help others
