Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
I screwed up used other brand
Hi;
I HOPE I'M NOT THE ONLY ONE WHO HAS TRIED TO SAVE A BUCK. I ORDERED A GENERIC BRAND AND IT FIT FINE BUT THE QUALITY WAS AWFUL. I ORDERED MY INK FOR THE 5100 ALL IN ONE BLACK AND WHITE INK. I INSTALLED IT AND THE TROUBLE STARTED ITS AWFUL. FIRST THE BLACK INK , IF IT PRINTS AT ALL IS TO LIGHT TO SEE NEVER MIND READ. THE COLORED LOOKS LIKE A UFO GOT HOLD OF MY PRINTER. I HAVE TO TELL YOU MY HUSBAND AND I ARE NOT REAL SMART ABOUT THIS STUFF SO I REALLY NEED HELP. IM EVEN WORSE ON THE COMPUTER, PLEASE HELP ME FIX MY PRINTER, THANKS FRAN
  • 40 Answers
Just Checking . Pull out the ink and see if the ink is comeing out . take a pice of tolit paper and rub gently on the bottem.This is to remove the crust that builds up.Then reinstall and realign the ink cartrege in the settings.
Posted on Jan 22, 2009
  • 741 Answers
Yes it is always recommended to use the brand name ink for your printer. I know it cost a little more but the quality is better. Not much you can do except take it out and throw it away and get a new cartridge. The longer the Generic stays in the worse you're problems will be, especially if the ink leaks into the rollers...
Don't forget to rate this solution before you log out.
Why does my Epic 1080 camera cut off with a loud beep?
Hi Roger, Are you using name brand alkaline batteries or some generic brand that cost $2.00 per case ?? If you are using high quality batteries then the camera has a serious problem.
Jan 17, 2013 | Cameras
Tip
Printer Ink refill ....
Well, in general I recommend not using refills. They are probably OK for printers with ink nozzles that are NOT built into the cartridge (like Canon printers), but I would still be careful. The ink may not be the same quality as what you would get from the manufacturer.
If you are using an HP printer, the ink nozzle is built into the printer cartridge and is not meant to be run for refill after refill. When you replace your ink cartridge, you also replace your old nozzle with a brand new one. Helps keep the print quality good (especially important if you're trying to print out photographs).
Another point to consider is that when you bought your printer, you were probably looking at print quality. Why take a chance on compromising that print quality to save a few bucks?
on Dec 01, 2009 | Office Equipment & Supplies
Can changing transmission fluid and filter cause transmission failure on a honda civic lx 1995
DO NOT use generic ATF - HONDA BRAND ONLY. If our transmission has less than 50k miles on it, you might get away with it for a while, but their ******'s are very unique - made by Honda and designed to run on their fluid. I learned the hard way how generic fluid can destroy a ****** - trust me, it's not worth saving 10 dollars on fluid! My trans. was a little glitchy and I trusted the O'reilly guy on fluid - it stopped shifting at all withing a week. Go to the dealer or save a few bucks by ordering from Car Quest Auto Parts if you have one.
May 01, 2012 | 1995 Honda Civic
I have seen many nails that supposedly fit the senco sn4 nail gun. Some are 31 degree, some are 33 degree. All have paper collating. What angle nails should I search for to fit the senco sn4?
Senco uses 33 degree paper tape clip head, however many generic brands will label their box 30-34 degree to fit several nailers. This practice causes jams in some guns and others work fine. The goal is to save money but could cost more in the long run if gun is damaged. You can use generic (other than 33) if you take a strip of nails and place them against the outside of the rails aligned with either the line of driver path of angle of the rails. This will give you a visual as to the alignment. Best result is when the complete nail is in line with the path of driver. Next best result is when the head is in the path of driver and point of nail is slightly away from path, worst is when point hits path and head is back. Good luck
Mar 26, 2011 | Senco Air Tools & Compressors
Using generic cartridge
no using generic brand catridges is fine does the pop up stop you from printing if not continue using the cheaper ink its just there to somewhat scare you into buying hp cartridges
if you cant notice any difference in colour or quality its all good
Dec 30, 2009 | HP Photosmart C6180 All-In-One InkJet...
What is the price of an air condition compresser
It would cost you any thing between 125 and 150 bucks. To order, follow the below link ;-
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=regal+95++ac+compressor+&_sacat=See-All-Categories
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 07, 2009 | 1995 Buick Regal
I need a head support for my cabriofix car seat
Although you can buy generic head huggers that will fit fine, you could contact www.maxi-cosi.com who will be able to help you to buy the branded version.
I hope this helps.
Sep 05, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Memory card problem
Hi.
Maybe there's something wrong with the compatability of your MMC with your phone. Try to buy a new a new one but this time try to buy the genuine one. By the way. was your memory card a generic one? Sometimes, other generic MMC wont work with the phone we've been using these days especially Nokia and Sony Ericssons phone. Genuine is expensives but its worth it. Or rather try buying a Kingstone or Transcend brands.
Hope that will help you.
Dec 17, 2008 | Nokia N72 Cellular Phone
Convergence still bad after replacing IC's
What type, brand or model number is the TV set you have there? Your question has no information in it.. It could be many things with different types of sets. Have you checked for blow resistors around the IC's? Did you purchase good original IC's or inexpensive aftermarket types? Have you checked the plus and the minus power supply fuses or circuit protectors that feed the B+ to the IC's? Way to many things could still be bad without the right information given.
Feb 28, 2008 | Zenith R60V26 60" Rear Projection...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
29 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
