Question about Gateway FPD 1730 17" Flat Panel LCD Monitor
Moniter transitions to LG logo
LG Flatron W2234S Monitor (purchased day after Thanksgiving)
Monitor goes black and displays LG Logo with an Energy Star icon next to it for about 3 seconds then returns to normal. The transition occurs at varying intervals but appears that something may be wrong with the monitor. Currently blinking about every couple minutes.
It displays normally otherwise.
    Master:
  • 461 Answers
Check the cable and make sure it is plugged in securely at both the monitor and PC. If the cable is connected properly, then the problem must be in the monitor itself. You could try setting the input mode manually on the monitor - the default should be auto - you could set it to VGA or DVI whichever your case is and see if it helps.
Posted on Jan 22, 2009
Black screen with.com lg logo and "energy save
this only happens when computer is on standby or there is no activity by a human like movement of mouse. it is a built-in energy saving formula on all such monitors
Jun 10, 2011 | LG W2286L Monitor
When I turn off the computer or restart the computer or put it in a sleep mode, my LCD monitor LG Flatron W2234S always turns black but the LED stays blue instead of yellow and the monitor does not react...
Try changing the Resolution for the lowest one, if it works it will see the letters and everything very big. I have same trouble, specially since I change the original Vista Starter for the new Windows 7, I have not found a free controler that helps me and I have seen many people with same the problem. Sorry for my english.
Dec 11, 2010 | LG 22" FLATRON LCD Monitor
I have lg flatron l1730s lcd black color monitor. I have problem with this. Power not come. some time when i connect it power LED blinking once then no display. Some time when i connect it power LED...
Oct 14, 2010 | LG L1730S 17" LCD Monitor
Hello, I have a LG flatron w2234s and a week ago the screen started to shut down on its own while i'm using the computer or when it goes to sleep mode. The screen gives me the LG sign and just turns off...
First try it on another Pc, you'll know the root of the problem. If there's no problem on another pc then the problem would be with your video card/motherboard. If the problem is still the same on another Pc, then your monitor has internal problem. You better call up a technician, he/she will check it for you, must be Pcb problem. Good luck. Thanks for using FixYa.
Jun 04, 2010 | Computers & Internet
LG W2234S restarting every 3 minutes
I will assume that you have already try this monitor with other PC with the same result, and also try new VGA cable with the same result, otherwise you will have to open it up and o some inspection inside the monitor.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 29, 2010 | LG 22" FLATRON LCD Monitor
LG Flatron L177WSB-how would I use my newly purchased unit after switching it on, LG logo appears followed by the Power Saving Mode it all goes black on the screen.
Hi, the Power Saving Mode, turns the screen off to conserve energy. On the remote, press Menu, and scan to Power Saving Mode. You can change the amount of time, when the Screen turn-off, the TV shut-off etc. You can set the time to (5 min) to, (never, turn-off). This should help with your problem. Thanks paul7of9
Jan 14, 2010 | LG Flatron L1750S 17" LCD Monitor
LG Flatron W2234S Monitor Monitor goes black
Ahh the same thing has happened to my monitor! Mine unfortunately is 1 month over warranty. Apparently this is a common problem with this model!
Oct 29, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
No picture lg flatron w2234s blinking blue light
Hi My screen developed exactly the same problem. It appears to be a hardwear problem associated with the screen it's self. continuity test is ok on the lead so I took it back to the shop under warranty and hey presto, the replacement works. I don't know what the problem is but there are a number of other folks on another thread with the same problem and their entries are dated May 09 too.  Dave
May 26, 2009 | LG Flatron L1750S 17" LCD Monitor
LG Flatron - Power button flashing blue
i get a similar thing, i accidently entered sleep mode then turned off my computer at the power button on the back, now i turn on my monitor( i dont get blue flasjhing but it jsut goes on and it doesnt register, then says going into power saving mode and the colour on the button turns yellow its very frustrating :(
Apr 20, 2009 | Computers & Internet
Gateway FPD 1730 17" Flat Panel LCD Monitor Logo
696 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
