Wiring diagram for a berkely pump (water well) Jet pump
I need a wiring diagram for a 120/230 water well pump, Berkely
It doesn't say any where on it if its wired for 120 or 230, But it has 3 wires coming from the windings down below that are hooked to one post.
Anybody got a clue?
Please send an email to goldguy65@yahoo.com
Thanks Duane
SOURCE: Wiring Diagram for Ruud Heat Pump
you should give more data as;
Brand of the air handler, the condensor and the thermostat
Posted on Jan 16, 2008
dcp2
  • 63 Answers
SOURCE: Wiring connection for a Ruud air handler & seeking its wiring diagram.
The orange wire coming out of the outside unit is for the reversing valve( controls the heat and cool mode of the ac) If its unhooked, it will be either in the ac mode all the time or the heating mode all the time depending on the style of the reversing valve. The orange wire goes to the (O terminal) inside the outside unit.
There is also another orange wire that goes from the air handler to the thermostat. One orange for the thermostat, and another to the condenser( out side unit)
Posted on Jan 26, 2008
  • 20 Answers
here is a basic wiring diagram for all air cond systems your thermostat consist of treminal r w y and c run a four conductor wire fromm thermostat to ai handler the air handler should allso have eather have red blue white wires or a teminal block marked r w c r stands for red w for white c for comon allso blue run color for color from the thermostat to ai handler with exeption of yellow yellow runs straigth to condenserand retuns in white wire to air handler wich gets conected to comon hope this help[s you
Posted on Jul 23, 2008
SOURCE: Wiring diagram needed RV rooftop coleman
Motor1258,
Thanks for the response, to be more specific, the nine pin connector was damaged, but I was able to connect the wires back to main unit panel. I am ready to hook to the hunter thermostat and do not know which wires to connect to. This is my problem and I do not want to short something out. Hope this helps, I want to get it installed again. Thanks again for caring....Jerry
Posted on Aug 16, 2008
j_del
  • 1586 Answers
SOURCE: 1998 Audi A4 Quattro rear speaker wiring
You can't use any of those - the large connector at the OEM speakers is because the rears are amplified. Your factory head unit puts out a line level signal to the rear speakers. There's an amplifier on the driver's side rear speaker (the box around the magnet that you can see from inside the trunk).
You need to either replace the head unit with an aftermarket one to drive your new speakers, or you need to tap into the amp connector and find the line level wires, break them out, put RCA plugs onto them, and plug them into an aftermarket amp, which you'd use to power your rear speakers. Doing it that way allows you to keep the factory head unit.
Posted on Oct 25, 2008
I have a 36 gallon utilitech water tank hooked to a 1/2hp shallow well jet pump my pump runs constantly and I think it's because my tank has no water in it any help would be greatly appreciated
do you have a pressure tank or what, are you doing a gravity type deal with a pump to back it up, all pumps need pressure tank too. or your pump will constantly be on or your tank fill hole is not tight a pump is designed to trip the breaker if it wired direct, if it is not wired direct like wired to an extension cord, then who knows what it will do burn up I imagine if it is constantly going on without water pumping thru it need more details
Nov 17, 2015 | Jet Plumbing
Where do the wire leads connect to the switch?
Look on the id plate on the motor, and inside the cover on the back and inside the switch cover.
Jul 03, 2015 | Utilitech 1/2 HP Convertible Jet Pump...
Not enough flow and pressure to run sprinkler system
pressure in centrifugal pumps depends on the number of impellers in the pump housing, the clearance of the impellers to the housing and the power of the motor to drive the impeller/s
volume flow is also important as a pump without a high output will not produce pressure
check the jet size at the foot valve that is used to help lift water to the pump
It is a jet pump and will have a smaller line back to the foot valve for that purpose
next wil jet pumps if there is too much flow to the outlet , the pressure required to help lift the water to the pump is reduced and the volume is also reduced
you indicate 4 sprinkler heads per zone but how many zones are operating at one time
check the expected delivered volume for the new pump against delivered volume of the old pump as a starter to find the reason for the poor performance of the new pump
check also the rpms of each pump as that also has a bearing on volume produced
Mar 26, 2017 | Flotec Pump FP4032-10MK
Motor won't turn on
CHECK POWER AT THE PUMP, MOTOR BUZZES ? YES CHECK TO SEE IF ROTOR TURNS, YES CLEAN START SWITCH, HAVE CAPACITORS CHECKED , NO ROTOR DOESN'T TURN MOTOR WILL NEED TO BE SERVICED. ROTOR MAY HAVE RUSTED TO STATOR OR LOCKED UP BEARING .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FL
May 15, 2012 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Well water jet pump
the diagram is on the tin cover that covers the wires
Mar 23, 2012 | Plumbing
I have a 3/4 hp Flotec 4022 pump. Prior to that I had a goulds 1 hp pump on the same 120 circuit with no issues. The Goulds pump housing started to go so I replaced it. Since replacing it with the Flotec I...
Hi Eglenni,
Here are the specs for your pump:
Thermoplastic Shallow Well Jet Pump 3/4 HP. This new revision of an "old hand" provides good pressure pumping from wells where the depth-to-water is 25' or less.
BODY CONSTRUCTION: Thermoplastic
HORSEPOWER: 3/4
MAXIMUM CAPACITY: 12 GPM
FLOW at 10' LIFT and 40 PSI: 9.7 GPM
MAX LIFT: 25'
MAXIMUM PRESSURE: 78 psi
PRESSURE SWITCH SETTING: 30/50
SUCTION PIPE SIZE: 1-1/4" NPT
DISCHARGE PIPE SIZE: 1" NPT
AMP DRAW (full load): 6.1 amps on 230v / 12.2 amps on 115v
VOLTAGE: 230v / 115v, 60 Hz
RECOMMENDED BREAKER: 15 amp on 230v / 20 amp on 115v
MAXIMUM WATER TEMPERATURE: 140 °F (60 °C)
Note that this pump can be operated at 115 volts or 230 volts (A/C) It may have come wired for 230 volt use from the vendor.
Make sure the pump is piped correctly.
There should be a wiring diagram either on the pump or in the literature so you can check to see how the pump is wired.
MAKE SURE
you have the pump wired for 115 volt use in your case. Also make sure the wire size is #12 awg for the power wiring.
Make sure all connections are tight. If you have an amprobe (an instrument that measures electric current) you can check to see how many amps the pump is pulling when it runs.
You said your old pump was 1 HP. This Flotec pump is 3/4 horse so there could be some pump performance loss depending on the well depth and length of the piping runs.
Here's the link to the website for the pump. There are additional resources available on the website:
Thermoplastic Shallow Well Jet Pump 3 4 HP
Jul 05, 2017 | Northern Tool Electrical Supplies
Just replaced my 1000 GPM Intex filter/pump with the 1500 GPM. Worked great for about two weeks. Now it doesn't pump much with the filter in. Seems to pump fine without the filter.
The filter needs to be cleaned. the cartridge should be removed from the housing and sprayed on the o with a hose and sprayer. A strong, concentrated jet of water works best. I hope this helps.
Aug 15, 2011 | Intex 1500 Gph Swimming Pool Filter Pump...
Im hooking my pool pump up to a 220 and I dont know what wires go where. On the motor there is a A and B and a L1 and L2. What do I put my brown wire on and what does the white one go on. Can u help me...
There should be a diagram on the side of the motor showing you where to put the brown and white for 110/220 volt operation. Most new motors of this size are shipped strapped for 220v. The two hot wires will go to L1 and L2 and it doesn't matter which wire goes to which lug. For 220v you will usually have 2 black or 2 red wires and a green ground wire. If it is 110v supply, you will usually have a white and a black wire, and a green for ground. Hope this helps. Since you said you are hooking to 220v the brown and white should be on the correct lugs if this is a new motor.
Jul 19, 2011 | AO Smith 1.5 hp Swimming Pool - Jet / Well...
My pump builds pressure to 60 psi but will not go any hire for the shut off what can be the problem
most jet pumps have a pressure switch to regulate cut in/ cut off pressure. Normally 40/60 psi. The pressure switch should be located at the rear of the pump where the wiring enters. First disconnect the power supply to the pump. Remove the cap where the wiring enters. On the inside of the cap there should be a diagram showing how to alter the cut in/ cut off pressure.
Jun 13, 2010 | Jet Plumbing
I have a Jacuzzi Jet Pump Model 7C-S/B. Not Working
Check the breaker that supplies power to the unit. If it is in tripped position, check if the motor is grounded ( continuity between terminals and motor body), check for shorted windings (infinity resistance value between the winding phases), and finally check if the pump is stuck up due to debris or defective motor or pump bearings.
Jun 08, 2009 | Plumbing
Heating & Cooling Logo
790 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
