Question about Refrigerators
Refrigerator samsung RF26DEUS dispenser opened and close continuously
Dispenser open and close continuously without stop for long periods of time
  • 788 Answers
SOURCE: our refrigerator lights are all flashing and the
I have reviewed your problem and have the fallowing for you to aces.
This sounds like to have had a power serge and a possible problem in a power board.
Please try the fallowing.
First, disconnect the unit from its power source.
Next, please check voltage at the power source and verify that it is correct.
Next, please check the ice maker and remove any ice or particles that may be restricting normal operation.
Note... I assume that the unit is cooling and freezing properly, as you have no listed complaints.
Note..... I am asking you to disconnect the unit from its power source and not turn unit off and control panel.
Also, You will want the unit to sit for at least 10 minutes with power disconnected, in order for the unit to reset.
Finally, please re-connect the power source and in available, please push reset on panel.
I the unit work properly afterword's, please have unit serviced asap.
Please let me know if you need anything.
Please rate......
Posted on Oct 30, 2009
woodchuck789
  • 4059 Answers
SOURCE: Ice dispenser appearing to get stuck in the open
The noise is probably the solenoid which operates the door or the one that switches it from cube to crushed ice. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Here's a diagram of the dispenser which may help.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=48122&diagram_id=656733#d656733
Posted on Jan 08, 2010
SOURCE: lights on panel blinking. ice dispenser keeps opening and closing
there is the HV board on the back under a cover . 2 680uf capacitors @ 35v are likely domed instead of flat on the top and are likely hot. replacing these with an equal value will cure the problem. they are in parallel so 1000 and 470uf will cure it. mine was same model except white. local dealer said no warranty. did not call maytag but he indicated it might help. good luck
Posted on Jun 02, 2010
cadillac02
  • 318 Answers
SOURCE: The refrigerator water dispenser started running
Pull the fridge out and look behind it. You're looking for the water line that could possibly have valve shutoff. If not, follow the line back to the source. Could be tapped under the sink, could go anywhere. You are attempting to shut off water to the fridge without shutting water off to entire home. Worst case scenario is if you can't locate the fridge shutoff and you can't get it fixed today and you don't want to leave the freezer door open, locate the main water shutoff for the house and shut it off over night. Hope this helps.
Posted on Jan 26, 2011
Sea Breeze
  • 4654 Answers
SOURCE: Our maytag refrigerator (msd2756) water/ice
Yes it sounds like you may just have a short circuit below the keyboard overlay=> 61005274 Dispenser Control Board Here is a photo of the fountain parts=> MSD2756GES_Dispenser_Parts and tale a look at the wiring diagram=> SD2756GES_Wiring_Diagram
and follow the directions after clicking. I will be HERE to help or here on Fixya, Please rate this solution, Thanks Sea Breeze
Posted on Sep 05, 2011
Samsung Refrigerator water dispenser does not work? Ice maker works
The electrically operated valve that opens when you attempt to get water is probably bad. This unit may have one unit with two valves. One each for the ice maker and water dispenser. This valve unit will be in the back of the refrigerator and have a copper or plastic supply line from your house. This line will be "live" so be sure and find and close the valve attached to your house's water supply.
Mar 02, 2015 | Samsung Refrigerators
Samsung refrigirator water dispenser works without filter but does not work with filter
Not enough water pressure in supply line to get past filter?
Open valve feeding supply line more and see what happens.
Sep 06, 2017 | Samsung Refrigerators
Hi My Samsung refrigerator is working fine, but water dispenser is not working. Water is leaking continuously. I guess the lever is broken or not working. Can I open the unit and repair it myself?
Yes you can, it's yours but if still on warranty period, do not do it, warranty will void.
If you can do then do it, be careful with parts you disassemble. If you can't call a service technician to do that.
I hope I give you some idea, good luck!
Jun 11, 2011 | Samsung RS2534 Side by Side Refrigerator
Not getting any water from the dispenser, water supply is ok, I can hear a clicking when depressed but no water?
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer.
May 15, 2011 | GE Refrigerators
Ice dispenser stuck on
Either the paddle for the ice/water dispenser is stuck or you have a bad microswitch behind the dispenser.
To stop the ice/water from dispensing open the freezer door and press or hold the child lock button down. Once the unit is in child lock mode you can shut the door without energizing the dispenser.
Another option is to remove the upper freezer door hinge cover and disconnect the wire connector up there. This will remove voltage from the dispenser as well. Then either replace the paddle or switch. Sometimes the paddles/switches will get stuck because of splash up from ice dropping in sugary drinks.
May 05, 2017 | Amana ASD2328HE Side by Side Refrigerator
Water dispenser does not stop and the water continues to come out
Your water control valve is stuck open or you have air in the lines just like after you change water filter. Try unpluging the side of valve that leads to dispenser tubing. I will return with part numbers; Sea Breeze
Feb 12, 2010 | Samsung RS2578BB Side by Side Refrigerator
Jan 08, 2010 | Maytag MZD2768G Side by Side Refrigerator
GSH25KGRWW dispenses ice/water all by itself! Heard noise last night, and refrigerator was dispensing ice all over the floor!! Attempted to stop by tapping the lever, but this had no effect; pushed water...
as you explained that by opening the freezer door the problem stopped the problem is: that you have a pinched dispenser wire or, two in the area between the door and, the door opening
these wires are low voltage so they are not going to cause a fire
but, if they touch the cabinet due to a bare wire they will ground and, start running the dispenser.
the door cover needs to be removed and, the problem (usually at the door hinge must be found and, corrected i.e. wire taped, shielded etc.
Sep 14, 2009 | GE GSH25KGRWW Side by Side Refrigerator
Stuck Water/Ice Dispenser LG LRSC26920TT
THE ACTUAL BUTTON AND ACTUATOR NEEDS CHANGING AND POSSIBLY THE SWITCH. EARLIER MODELS WERE CHANGED BECAUSE OF THIS.
Aug 18, 2009 | LG LRSC-26922 Side by Side Refrigerator
GE Profile Refrigerator water dispenser stop working...
This could be a bad water valve on the back of refrigerator or the dispenser is not asking the water valve to open. There are 2 valves in back, one is for ice maker and other is for the dispenser. I will help to try to locate the problem if you need, let me know, Thanks, Sea Breeze
Mar 26, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
