Question about Maytag 21.9 Cu. Ft. Bottom-Mount Refrigerator - White
I can't locate a filter for Ice Maker
I am renting a house with this refrigerator, and want to change the filter for the Ice Maker (it doesn't seem to make ice like any I have had before). I can't locate a filter, and wonder if this model uses and external filter. The supply line just hooks straight to the refrigerator, but the water here in Yuma is terrible, and I don't care to consume it when avoidable.
22yooper
  • 828 Answers
SOURCE: Maytag refrigerator Model MZ02766GEW does not dispense water
In the water supply line to the refrigerator is normally a saddle type valve where the water supply is connected to your house water line. Trace it back and shut the valve off fully then turn it back on. When some work is done to any part of your household water system sediment may have lodged in the saddle valve causing a restriction. Closing the saddle valve and reopening it may dislodge the restriction.
Posted on Dec 02, 2008
SOURCE: Maytag plus MSD2756GEQ ice maker not working
I had similar problem in that the fan in the freezer that blows freezing air into freezer and over to fridge was not working. Fridge was running warm (over 40 deg and freezer up near 20) Service call around $160 with new fan.
Posted on Apr 12, 2009
lojacksdad
  • 121 Answers
SOURCE: I have a Maytag MTB2156DE refrigerator with an ice
the water line comes from the bottom back of the fridge it sound like you have a blocked line meaning
you have a bad water replace valve and clean out line
Posted on Apr 13, 2009
philbran
  • 242 Answers
SOURCE: Water wont fill ice maker
the relay is the ice maker , buy the kit that contains the valve and it is a complete new ice maker system.
easy to find at sears parts.
Phil
Posted on Jun 11, 2009
erpaalai
  • 999 Answers
SOURCE: Maytag Model MSD2651HEW - Changed Filter and
Was the pressure ok before you changed the filter? The water valve itself could be partially plugged or the supply line may be filling with minerals. Usually happens in the piercing tap used to attacc to the house line. Difficult to say for sure without seeing the way it is installed. If it was just the drinking water I would suggest the reservoir being froze up but since it affects both look at my initial comments...
Eric
Posted on Oct 12, 2009
Jd-21 ice maker filters?
Take up this issue with Sears
Jun 30, 2013 | Refrigerators
Frigidaire Gallery French Door Refrigerator ice maker not making ice
You can search with your model number to see if a filter is available or not. Secondly unless the ice maker was damaged for sure it's likely that the fan is not running in that compartment or air is leaking into the refrigerator and making the ice maker think its not cold enough to make ice.
Apr 13, 2013 | Frigidaire Gallery 25.8 Cu. Ft. French...
Frigidaire french door refrigerator not making ice
Hello jcwilson2929 - If your ice maker has stopped producing ice completely, you can check the following:
1. It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
2. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
3. When was the last time the filter was changed? Most side-by-side filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency. The ice maker fill tube may be blocked with ice or have a clogged water filter. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
4. Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Sep 26, 2012 | Frigidaire FGHB2844L (27.8 cu. ft.) French...
Ice maker stopped working, but used to work very well. During a course of a week, ice production kept slowing down to nothing. Test button on the side of the ice make unit does nothing. Unit is only a...
I had a similar problem with my Samsung fridge, my problem was the the ice holding unit had been taken out and not reinstalled correctly,
There is a rod on the rear of the tub and it has to be placed properly in the drive gear at the rear of the ice making housing so that it fits properly and smoothly.
If you still have a good water supply available at the door then the problem is probably what I just described, Good luck
Aug 27, 2011 | Samsung RF26VAB (25.5 cu. ft.)...
My LG refrigerator has the ice maker hooked up to the hot water heater, is this right. MY HOT WATER HEATER HAS SLUDGE IN IT THAT IS GOING INTO THE ICE MAKER AND MAKING FOUL SMELLING AND TASTING ICE. ...
Having ice maker hooked up to hot water side is common practice...because the water is heated before it gets to be sent to the ice maker, it would have less air in the ice...kinda like a crude way to distill the water.
The sludge is from mineral deposits in your water...sometimes called hard water.
One of the best investments in areas of hard water is a water softener system, in-line water filters, or a combination of both.
Ya might look to see if there is a filter in the refrigerator to filter water before it gets to the ice maker as well.
Hope this helps...
Jul 24, 2011 | LG Refrigerators
Ice maker doesn't make ice. It seems to not being able to rotate the ice tray to dump the ice.
this may be a bad heater in bottom of ice maker . if so replace the ice mker .. but do ck the tempts ..freezer must be 15 de or lower for ice maker to work properly .. hope this helps mm .. feed back pls ..
Jul 10, 2011 | LG LMX28988
Our ice maker makes a little ice , and it doesn't drop. What is wrong with that? Also the house was built in 2005, but the previous owner hasn't live here. How come it can be that? Thanks
Turning the fridge temp down a degree or two will create more ice and at a faster pace. It usually takes a few hours to notice the increase in ice production.
Jul 04, 2011 | Sub-Zero 695/O Side by Side Refrigerator
Ice cubes taste bad
there should be one in the frigerator for the water if not go the the local home depot and get a inloine on for it.
Apr 20, 2009 | GE GTS22WCP Top Freezer Refrigerator
Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Apr 14, 2009 | Kenmore Refrigerators
Water leaks
I have the same problem- had service man out & he replaced the ice maker- not a cheap fix, especially since the ice continues to accumulate at the bottom, then melt onto the floor.  no good answer yet---
Apr 20, 2008 | Jenn-Air JCD2389G Side by Side...
Maytag 21.9 Cu. Ft. Bottom-Mount Refrigerator - White Logo
27 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
