Question about LG WM Washing Machines
Water leaking from bottom of machine tromm model #wm3677hw
ngafm
  • 166 Answers
SOURCE: tromm drain pump wm3677hw
you may be able to find parts outside the manufacturers realm.
I would call Tromm, and ask for a supervisor and show them that it started before the warranty was up!
Almost every manufacturer will send someone to help you for free or do whats called a, "PUSH-PULL"
If there is a lemon or the customer is ********** cause the unit broke to many times and he got no satisfaction.The manufacturers will send a dealer to deliver a new one and take the lemon away for free. They pay the dealer they arrange this with!
We do it when ever they ask us to for all the manufacturers.
YOU PAY NOTHING ,except a tip to the delivery guys if you want to!
Discount Parts Major Appliance & Consumer Electronic Parts. TOLL FREE 1-(888)-338-3790 8:00AM - 12:00 MIDNIGHT 7- DAYS A WEEK
Posted on Sep 05, 2008
futureloginn
  • 734 Answers
SOURCE: water leaking from bottom of front lode washing machine
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: front load washer leak
This could be the rubber seal or the door lock. If the door lock is not pulling it tightly closed then it needs to be replaced. Check the seal really closely and make sure there are not cracks and it does not look deformed
Posted on Feb 16, 2009
Karthik316
  • 187 Answers
SOURCE: Front bottom leak from my LG TROMM HE Washer
  • Hi
  • Try these:
  1. Inspect the water supply connections
  2. Inspect the drain hose
  3. Inspect the water pump
  4. Inspect outer tub for cracks or corrosion
  5. Inspect the tub seal
  6. Inspect the tub bearing
please rate my suggestion...
Posted on May 22, 2009
  • 35 Answers
SOURCE: Leaking from the bottom of maytag washing machine
a good possibility that the front door seal is leaking check for tears or any small holes if it is that it it is hard to do
Posted on Jun 07, 2009
Water leak out the bottom of the door when it running door seam lose
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Manufacturer Part Number 4986ER0004G
Jan 27, 2015 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have a Tromm wm2077cw washer that leaks water about 3 times a year. Usually if I clean the small filter on the bottom left it corrects the issue. Not the case this time it still leaks about 1 out of
If its leaking then its a seal I would look up the parts detail on that specific model to look were all the seals go and go from there. even though its leaking from the bottom could be from the top and water just coming out from there.
Sep 28, 2014 | Washing Machines
Water Leaks out of bottom of door
the first thing i would try is to loosen the hing screws couple of turns,push in on the bottom hinge and tighten screws.
Dec 10, 2013 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Where does the lin tgo on my LG TROMM Model WM3677WH
Per the LG web site, the combo units are self cleaning. The trapped lint is washed out of the system automatically.
You should pay attention to the "cleaning" instructions for this unit. It is important to keep excessive soap buildup cleared out. Also be sure to use the correct soap - special, low suds.
Oct 11, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Washer-dryer # wm3677HW will not dry,heats up, run, on and on
You're a moron. This unit washes and dries. That's the whole point of it. Perhaps you should do some research before answering the question. the most likely cause is the water lever sensor.
Aug 09, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
  • Hi
  • Try these:
May 22, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Water leaks from bottom of door
I had the same problem and it would leak huge amounts of water all over the floor.  After having a repair person out 5 times.  It was supposedly a fault that the seals on the door needed to be replaced.  My washing machine leaked from brand new.  It does leak from time to time but no where near what it use to.  Hope this helps!
Ren
Mar 29, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
