Question about Sport & Outdoor - Others
Like to repair a mossberg 200ka shotgun circa 56-59
Internal receiver part broken
5 Suggested Answers
  • 121 Answers
SOURCE: I cannot find the serial number on my 20 gauge
Please repost in the correct thread...
Posted on Oct 21, 2009
  • 15 Answers
SOURCE: i want to fix my mossberg airsoft shotgun
Get a quality airsoft gun, not a crapsoft gun. Youre details also havent given users enough info to help you please be more detailed or dont post.
Posted on Mar 28, 2010
  • 2418 Answers
SOURCE: How do I mount the reddot bkrd30 to a mossberg 500
Check out Amazon They list a scope mount for that gun.
Posted on Jan 11, 2011
  • 679 Answers
SOURCE: looking to buy 5 shot mags 595/695 bolt action
You can check this website http://www.gun-parts.com/mossberg/ Most of my friends buy their gun parts and accessories here. thanks
ZJLimited
  • 17970 Answers
SOURCE: I never got an answer to my original question
This site has no specialists in the area that you need answers (weapons). If your delaer cannot offers details about this "bugs", try to find addition al information in the guns forums: thefirearmsforum.com/showthread.
Hope helps and good luck.
Posted on Jan 14, 2011
How do you load a mossberg 88 maverick 12 gauge shotgun ?
this is the same for your maverick 88.
Sep 14, 2014 | Optics
Disassemble bolt on bolt action shotgun
Pretty much all bolt action bolts work the same. You need to relieve the spring force. That means pulling back on the cocking knob. The head will come off easily then. You need to have the bolt in the exact condition it's in when cocked, cocking knob back, to disassemble it. Reverse that to reassemble.
Apr 21, 2014 | Mossberg Optics
Mossberg model 88 manual
Yep. The back end of a Mav 88 is identical to the Mossy 500. Same gun, after all. The front end, forearm is the only real diff accessory-wise. You'd need to buy a Mossy action tube (the forearm steel) to put a forearm on your Mav. Stock, yes....forearm, no.
May 17, 2013 | Optics
How do i install a utg shotgun top rail #mb500t on a mossberg 500 tactical cruiser shotgun?
For any top mounted rail on any gun, you'll need the gun to have or be drilled for the proper screws. Your Mossy, if it's already drilled, will have four tiny little screws plugging four tiny little holes on the topo fthe receiver. Remove those, put the rail in place, and replace the screws with the ones included in the rail kit. If your gun IS NOT drilled, you can have it drilled....which will cost more than the rail kit....or you can skip that rail and go for a clamshell or side mount rail instead. Both of those use the ejector screw and the trigger retainer pin to attach them.
Feb 09, 2011 | Mossberg Utg 500590835 Rail Mount For...
Looking to buy 5 shot mags 595/695 bolt action mossberg shotgun.
Jan 11, 2011 | 1&1 Soft Air Smith Wesson Mad Max...
How do you load a 12 gauge pump action Mossberg (500)? There is no magazine for it, but, is mag ready. How do you manually load?
The loading port is on the bottom of the reciever. You mention that it is "magazine ready"? Mossberg shotguns have a tublular magazine underneath the barrel, surrounded by the action bar and front grip.
Loading the magazine entails holding the shotgun in one hand, taking the shell in the other with the folded end facing the front end of the barrel. Place the shell in the magazine opening (on the bottom) and push it up with your fingers and forward with the thumb of the same hand. It will go completely forward of the silver/blue lifter and stay there when you let go. (the action must be closed to load the magazine).
Alternately, you can open the action and pop a shell into the ejection port on the right side, close it back up, and shoot!
Sep 17, 2010 | Mossberg Optics
How do you reasembal the trigger assembly of a mossberg 500 i am haveing problem with the spring positioning
look on the internet you will find a blow up picture of the mossberg 500 in this list of guns
type in shotgun schematics
Sep 25, 2009 | Mossberg Marlin Rifle 992m,989,mossberg...
Broken forearm on a mossberg 535 shotgun
I'd be amazed if Mossberg didn't have one available. Give them a call.
Jan 05, 2009 | Mossberg Sport & Outdoor - Others
Sport & Outdoor - Others Logo
231 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
