Question about HP OfficeJet 6210 All-In-One InkJet Printer
Printer says paper jam but can't find any paper jam. Won't pick up pages and feed through. problem started suddenly. Turned power off for a day and printed two pages fine--thought it was fixed but now having same problem
  • 45 Answers
How to correct a Paper Jam message, when there is no paper in unit(printer)
First up, put paper in it. A failed pick up also registers as a paper jam. Run a test page and find out WHERE the paper feed stops. If the paper does not feed - Clean the primary pick up roller at the Front (usually) that takes paper from the cassette. Please not some of the larger machines have the pick up roller inconveniently placed at the back of the tray cavity
Mar 15, 2016 | Brother International Brother MFC-8910DW...
Constant Paper Jam
check the wheels that pick it from the tray.
If they feel smooth, try to put some tape on them and rip it back off.
This cleans the wheels. Also try a new pack of paper and check if it\'s set to plain paper and not to heavier or coated paper
May 30, 2013 | Brother MFC-7840W Multifunction Laser...
Paper feed issues when there is no Paper jam. All the rollers move when the printer tries to feed paper. It'll feed about and inch and a half of paper and then stop showing a Paper Jam.
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 19, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
My HP laser printer 1300 had a paper jam
When printing or copying, paper will not pick up or feed into the HP LaserJet 1000, 1200 or 1300 series product causing paper jams or wrinkled output. Symptoms are as follows:
  • The pickup roller will spin and try to pick paper.
  • The paper will partially feed into the product accompanied by a crackling, crunching noise then jamming.
  • The paper may feed all the way through the paper path accompanied by a crackling, crunching noise. The output will be skewed and wrinkled.
SOLUTION: Reposition the black Mylar light shields back into the proper position.
  1. Unplug the power cord from the product.
  2. Remove the paper and paper input tray.
  3. Slide hands, palms side up, into the paper input tray cavity (see Figure 1) until the fingertips reach the end of the cavity. Figure 1: Paper input tray cavityc00068598.jpg
  4. Bend fingers up to push the black Mylar light shields back into place. The proper position of the black Mylar light shield will be flat.
  5. Reconnect the power cord.
  6. Print a self-test/configuration page to verify product is functioning correctly.
Feb 24, 2011 | HP LaserJet 1300 Printer
A sheet of paper had remain in the cylinder
  1. Remove the rear cleanout from the printer.
  2. Gently remove any jammed paper or bits of paper.
  3. Close the HP Paper Feed Cleaning Kit software on the computer.
  4. Load plain paper in the printer paper tray.
  5. Press the Power button to turn the printer off.
  6. Press the Power button to turn the printer on.
  7. Try printing again. If the printer still does not pick up paper or if a paper jam occurs again, service the printer.
Other solutions customers found helpful » HP Paper Feed Cleaning Kit -- Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000 » HP Deskjet, Photosmart, and PSC All-in-Ones -- 'Out of Paper' Error Message and the Printer Does Not Pick Up or Feed Paper » HP PSC 1600 and 2350 All-in-One Series Printers -- 'Paper jam: Press OK to continue' Message Displays on the All-in-One
Dec 15, 2010 | HP PSC 1610 All-In-One InkJet Printer
My printer keeps telling me to remove jammed paper, but there is no paper in it!! Help, and thanks!
OK do one thing off the printer then restart it.Reset the printer from printer option botton. then off again. After that when you on the printer then the massage naver come.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 31, 2010 | Canon PIXMA MP150 All-In-One InkJet...
HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Aug 31, 2009 | HP LaserJet 4L Printer
Samsung CLP-300 picking up too many pages
Hi
Thanks for using FixYa. Paper jam is a very common problem with the printers.
First of all clean off the rubber piece that pulls the paper into the printer from the tray with rubbing alcohol, and also take a knife to the rubber piece to rough it up to create more traction.
To clear the paper jam problem you need to remove the back roller mechanism to get at paper. If still the problem persists, then check the following to resolve the issue--
1. Please check all interlocks, electrical and signal connections are seated properly.
2. Front cover, back cover and lid are closed properly.
3. Power plug and USB cable are connected.
4. Printer is turned on with switch on the back.
5. Toner signal lights sequenced, with yellow overall led on.
6. There is some noise of paper roller movement.
7. Toner signal lights all out, overall status light turned to red
8. No visible paper in paper tray or anywhere else.
9. No paper in tray---added paper
10. Waste toner container is full or not installed ---empty, installed properly.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Samsung CLP 300 Laser Printer
My Kodak ESP5 keeps saying "Paper Jam please remove paper jam" But there is no paper in it?
My esp 5 gave me this same message. I'm not an expert but here is what worked for me.
I turned off and disconnected both cables (usb and power) then reconnected and turned on.
At this point it still read paper jam, so I took ink cartridges out and paper out.
I then reinstalled ink cartridges and PULLED OUT THE PAPER TRAY to it's FULL capacity, added about 5 sheets of paper, and on the main menu I chose the allignment function and printed a test page and suddenly....no jam!
Hope this works for someone. For some reason pulling the tray all the way out cleared the "jam" message for me. Now if I could just get the new ink cart to work I'd be all set! Good Luck!
Dec 20, 2008 | Kodak ESP 5 Printer
Doesn't Print - Says "Paper Jam"
That is the problem, machine will show printer jam if paper feed rollers fail to pick up paper when requested, your machine sounds like it needs new paper feed roller or you can clean the paper feed roller with a slightly! damp cloth.
If no jam light shows when power is turn on and machine comes to ready and then you send a job to printer and it then shows jam then it is the feed roller or sometimes the feed clutch
If on the other hand it always show jam then there is or a switch is stuck.
Oct 25, 2007 | Kyocera Mita FS 1200N Laser Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
