Question about Dell Latitude D600 Notebook
External keyboard hookup issue
I have been using a D600 for several years at home and on the road, and gave the docking station to a coworker over a year ago. No worries until recently when less than optimal ergonomics at home finally caught up to me. The machine has no PS2 ports. I have a wireless mouse with a receiver that connects via a USB port, but no good way to connect any of the keyboards I currently have. I do have an adapter that receives PS2 connection on one end and plugs into the serial (not USB) port on the other end - but I can't get the machine to recognize the external keyboard when connected this way. Is there a way to do it, or do I have to go find a wireless or USB keyboard?
  • p_kies Jan 22, 2009
    I'm in the BIOS screens, and I see the serial port is mapped to COM1. At the bottom of the screen it says I can change values with the left and right arrows, but they don't seem to do anything. Any idea what would prevent me form being able to edit these? The adapter connects to the laptop right next to the power cord and the D600 user guide says this is the serial connector. I think I need to tell the machine that there is a keyboard on COM1, but I have no idea how. Search for hardware doesn't find it and device manager says COM1 is working properly.
  • p_kies Jan 26, 2009
    I gave up and got the port replicator back. Finding drivers for the com port and an old keyboard was next to impossible without knowing exactly where to look for them. The bulk of the drivers I could find on the net were for newer PCs, newer keyboards or different equipment entirely. I guess it's all about selling new equipment and nobody cares about making laptops compatible with old peripheral devices. Without a PS2 port on the back, you either have to buy the port replicator or a USB or wireless keyboard
  • 741 Answers
Yes, you can establish your serial port in BIOS With the use of USB ports on computers the serial and com ports are not set up many times. Upon start up and before the windows login screen will see which key to hit to get into BIOS. It is usually an F# key. Once inside BIOS look for ports and toggle until the serial port is showing up. That will establish your serial port.
Don't forget to rate this solution before logging off.
Posted on Jan 22, 2009
  • Randall  Trahan
    Randall Trahan Jan 22, 2009
    For your keyboard: if the PlugnPlay does not pick it up then you can go into Control Panel and use the Add/Remove Hardware option to install it. But you will need the disk with the drivers on it. If you have the drivers or if you can download them then your system will pick up your keyboard. I was under the impression you already had the drivers loaded. The device manager will not recognize it nor will your keyboard work until the drivers are loaded.
Hp550 computer not going to sleep mode properly
No matter which model of HP laptop you own, battery life is a big issue. Hibernation mode is designed to increase the battery life of your HP laptop by switching off the monitor, hard drive and other parts of the unit after they have been idle for a specific period of time. While hibernation mode works well most of the time, in some cases, your HP laptop may not wake from hibernation the way it should.
Docking Station Issues Many hibernation problems are caused not by the HP laptop itself but by the docking station to which it is attached. Some models of docking station interfere with the normal operation of the hibernation on the HP laptop. The easiest way to test this is to remove the laptop from the docking station and allow it to sit until hibernation begins. If hibernation mode works with the laptop undocked but not while docked, you know the problem lies with the docking station instead of the HP laptop. b> Remote Desktop Issues If you need to connect to your HP laptop from elsewhere, it is helpful to reset the power settings to the Always On mode before you leave your home or office. Many models of HP laptops do not wake properly from hibernation when users connect to them remotely using the remote desktop feature of Windows. When users connect with remote desktop, the program sends a signal to the remote computer that should wake it from hibernation and allow it to function normally. However, this process does not always work as intended with HP computers, so it helps to change the power settings to allow a seamless connection. Video Drivers Problems with HP laptop hibernation also can be caused by a corrupt or outdated video drive. HP laptops come with built-in video processors, and the drivers they use are installed during the initial setup of the unit. If there is a problem with that driver, HP releases an update, so if you see problems with hibernation, your first step should be to check for an updated video driver. b> External Keyboard and Mouse Sometimes the HP laptop does not respond properly and does not wake from hibernation when you use the built-in keyboard and touchpad mouse. The sensitivity of HP touchpads varies from model to model, and that sensitivity can be reduced over time. You can test for this problem by attaching an external keyboard and mouse to the laptop to determine whether that resolves the problem.
Feb 20, 2013 | Computers & Internet
Dell Latitude E6410 : Mouse & ext. Keyboard lost when putting back into docking station
Go to the Control Panel in your start menu whilst the PC is in the dock,disconnect the things you want it to detect, then click on "Add a device" and connect them one by one :)
Aug 16, 2012 | Dell Latitude E6410 Notebook PC - Intel...
Dell Latitude D600 Power button functions intermittantly. I need to know wher to get one and how to replace it.
I would suggest a couple of things first:
1. Have you tried removing the power button strip and checking that there is no obstruction underneath that might be causing the issue?
2. If you have a docking station do you get the same issue when using the docking station power button - this would help eliminate if it is a motherboard issue.
Dell do have some handy manuals on line that can help:
This shows how to remove the power button bezel:
http://support.euro.dell.com/support/edocs/systems/latd600/en/sm/keyboard.htm#1111863
This shows the small removable power button board (just to the right of the arrow labelled 1) - it is held in place by 2 small screws with the connector underneath which fits onto the motherboard.
http://support.euro.dell.com/support/edocs/systems/latd600/en/sm/sysboard.htm#1000461
The power button board can be found on eBay for around £5:
http://cgi.ebay.co.uk/Dell-D600-600M-Power-Button-Board-/380110416588?cmd=ViewItem&pt=UK_Computing_LaptopAccess_RL&hash=item588058aacc
Hope this helps
Feb 06, 2010 | Samsung Dell Latitude D600 14.1 LCD SXGA+...
Dell D630 Docking Station
First option if using Windows XP is to undock the system then delete the Docked hardware profile in Device Manager, Hardware Tab, Hardware Profiles. Once deleted, power off, dock the system, boot, Profile recreated.
Jun 28, 2009 | Dell Latitude D600 Notebook
USB port on docking station does not work
Power. You may find that the ower managment settings need to be changed or an external supply is needed.
May 28, 2009 | Motion Computing LE1600 Tablet PC
Screen is blank; can not see image with computer on
STEP: Toggle the Video Mode with the <Fn> and <F8> Keys
Additional Information
Press the <Fn> and <F8> keys to toggle the display mode between the video modes (LCD Only, Monitor Only, and Both).
STEP: Determine if an external monitor is being used.
Determine if an external monitor is connected to the docking station.
STEP: Determine if the video problem occurs outside of the docking station.
View the LCD panel on the system to determine if the same video issue occurs while the system is outside of the docking station.
STEP: Remove Any Docking Stations or Port Replicators From the Computer
STEP: Unplug All Accessories From the Laptop Computer
Unplug any accessories from the laptop computer, such as PCMCIA cards, external mice, external keyboards, external serial or parallel port devices, external monitors, external USB peripherals and port replicators.
Apr 23, 2009 | Computers & Internet
D630 docked , ext mouse & kybd not responding
If the docking station has power:
Make sure power is off for both the laptop and the docking station. Plug your keyboard and mouse into the docking station. Dock the D630 to the docking station and then power on docking station. This should then turn on your D630. Your D630 should detect the keyboard and mouse.
If the docking station has no power:
Verify that the power cord, AC adaptor, etc. is plugged in. If the items listed seem to be in order,
there may be a problem with the power going into the docking station. (AC adaptor?)
support.dell.com will have the specific details for your D630 and your docking station, et al.
Please let me know if you have success in this.
Binary Bob
Nov 27, 2008 | Dell Latitude D600 Notebook
Dell D600
If the docking station is not charging the laptop while docked, it may simply need to be plugged in using the power cord to recharge the battery.
Jul 21, 2008 | Dell Latitude D600 Notebook
Docking station trouble
You will need to dock the closed laptop first, then use the power button on the dock to turn it on. This will result in the output to the monitor. Alternatively, if you have the laptop open, you can toggle between the laptop LCD and external monitor (or both) by holding the blue Fn key (on the laptop keyboard) and pressing F5. Best regards, torgo
Jun 03, 2007 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
529 people viewed this question
Alun Cox
