Question about HP OfficeJet 7310 All-In-One InkJet Printer
While copying on 4215 HP officejet printer, it has stopped
Releasing the copied page completely. It displays the message Printer Jam
  • kuldipshodha Jan 22, 2009
    If I want to make say 10 copies then I insert the original and start copying. It copies the first page ok but the very end of this first page does not get released. The display says Paper Jam and I have to slightly pull the first copied page to get it out. Then I have to open the top and press ok to start copying. I have to do this everytime. Hence it does not allow me to make multiple copies uninterrupted. This was not the problem earliar, It has started recently.
  • Thomas F. Schneider May 11, 2010
    So "something: is caught between ther rollers.
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 22, 2009
When I try to print from either of two computers with the HP 4215 driver and/or copy the printing is extremely slow - takes about 20 minutes to print or copy one page
You need to do two separate things: 1. You must erase the driver that you currently have for that printer and disconnect/restart the printer physically. To erase the driver in Windows 7 do the following: Start Menu -> Devices and Printers -> Right Click HP OfficeJet 4215 -> Remove Device (if this doesn't work you can also try fiddling with the properties too in the same context menu).
2. Then you need to download and install the new driver from here: (Contains Drivers for all Operating Systems)
Feb 28, 2011 | HP OfficeJet 4215 All-In-One InkJet...
I have a HP OfficeJet 4215 All-In-One InkJet Printer it is hooked up and i can copy fax and print but can not scan
go to web site of printer model and check site for trouble shooting HP has an awesome trouble shooting site
hope this helps and good luck
Apr 29, 2010 | HP OfficeJet 4215 All-In-One InkJet...
When I turned on the printer it display clear
Open the printer and remove both cartridges. Replace the cartridges and close the printer lid. the printer should detect the replacement cartridges and ask you if they are new or used. then it should go through and do an alignment on the cartridges.
Apr 03, 2010 | HP OfficeJet 4215 All-In-One InkJet...
HP 5610 all-in-one fake "paper jam"
I request you to please perform the below steps to reslove false paper jam..
Step one: Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
Step two: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next solution.
Sep 02, 2009 | HP Officejet 5610 All-In-One InkJet...
HP6110 All in one
When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
  • Add paper to the HP Officejet series paper tray
  • Clear a possible print jam and proceed printing the fax.
  • Reduce the copying or faxing resolution via the front panel's menu.
  • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
  • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
It's true. All cartridges are used for each copy. Black or color. only use GENUINE HP carts.
Jan 27, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Not printing
If either a paper jam or blocked carriage error message appears
in the front panel display there might be some packing material
inside the HP Officejet. Lift open the print-carriage access door to
expose the print cartridges and remove any packing material or
other items that do not belong there.
Jul 28, 2008 | HP Officejet 4215v All-in-One Printer
Carraige jam
If you can move the cartridge carrier, move it all the way to the left, turn the printer off and then on again.
Your printer may not be parking the cartridge completely so check the area that the cartridge rests over when parked for a sponge or wiper that is out of place.
I've pulled broken light bulbs, paper clips among the many things that can cause the cartridge from parking in the rest stop.
Jul 09, 2008 | HP OfficeJet 4215 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
59 people viewed this question
Ben Johnson
