Question about Samsung Washing Machines
Samsung washer melted plastic - Samsung Washing Machines
One of the thick plastic severing spoons apparently fell to bottom of washer, it has melted on to the heater part, how do I get this utensil off if the heater.
your best bet is simply to unplug it and break it off carefully then use steel wool to clean up the heating element of the remaining plastic. if need be and there is no danger of melting anything else you can use a pen torch to heat up and hard to remove plastic and wipe it away with a cotton clothe or scrap of denim some fabric that wont melt.
Sep 25, 2017 | Dishwashers
Washer leaks but onlyu during drying cycle
the main drama i have with these lg washer/dryers is the drying vent blocks up with lint which causes excess heat build up around the heater and it often results in a small hole melting through the front tub under the heater vent where it joins to the plastic tub, it also results in water leaking out the melted hole when it dries but not during the wash as the hole is at the top of the tub, parts are relatively cheap for what they are but its a massive job to replace the front tub.
Feb 04, 2017 | LG WM3987HW Front Load Washer / Dryer
Can I clean the steam kit DC97-09101J or do i need to re-order?
I would recommend having someone look at the machine. There are a few things that could be causing this to happen (The hose, your steam sensor) and it's better to spend the $ on getting it fixed than just purchasing parts that may or may not fix the issue. Good Luck!
Apr 20, 2014 | Samsung WF448AAP Front Load Washer
Samsung microwave internal vent cover melted
The temperature reached a high enough value to make the plastic melt .The device ran for too long. The device ran without any substance (food) to heat.
Nov 26, 2013 | KitchenAid KHMS145KSS Microwave Oven
Melted plastic turntable teeth
If only the teeth, get a new replacement ring . If it has melted so bad that it is part of the m/wave floor, you don't have much choice. Have you tried speaking to manufacturer?
Aug 07, 2013 | Samsung Microwave Ovens
Hole in Maytag Neptune front load washer door and flaking or melting of door.
I've owned the same Neptune since 1999 and had this problem happen to me twice, the first time the inside molded plastic door melted through in a circular pattern and had to be replaced. The fact that it was circular indicates that something was rubbing during the high speed spin. That something was a stiff bottomed duffle bag that was rubbing on the plastic door during high speed spin. The washer was full of other clothes that didn't allow the duffle bag enough room in the washer tub, hence it pressed against the plastic door. The second time it happened I got a circular groove melted in, but not through, the plastic door... caused this time by a small child's back pack. I would make sure "rigid" items have enough room to "float" in the tub cavity by not putting in other clothing that over packs the washer.
Oct 15, 2017 | Maytag Neptune Washing Machines
It get to hot, and the heating element stays on and melts plastics. Way to hot.
STOP USING THE DISHWASHER IMMEDIATELY.
It's dangerous and using it will cause further damage. It's likely that considerable damage has been done already if plastics have melted.
Your thermostat has failed and will need replacing but it's unlikely that the thermostat is the only part that will need to replaced. Your washer may even be damaged beyond economic repair.
You need to call an engineer. Your machine needs to be professionally inspected and assessed for damage before further use. If the washer is still under warranty, please contact Electrolux
customer support - the phone number for your region will be in your user manual.
Nov 03, 2010 | Electrolux 24 in. EDW5505EPS Stainless...
The ''ice full glide'' (plastic) is broken
could try melting it back together with a heat gun. remove part first. caution!!! melted plastic very hot !!
Aug 26, 2009 | Samsung Refrigerators
Need to get a plastic pulley attached to motor without motor
Hi, Is the plastic pulley on the motor or is it on the belt idler asswmbly? THe model # you have given is for a Whirlpool washer. This model doesn't have a belt. It has a coupler to connect the botor and transmission. Do have a model # for the maytag washer?
Vic
May 20, 2009 | Whirlpool WTW5100SQ
Plastic pulley melting
Whatever the pulley is attached to has seized. Either the water pump or tub drive, or something else has stopped spinning. The belt continued to run because the motor kept pulling it, and the friction from the belt melted the plastic pulley. Hopefully its the water pump, as its the most inexpensive. You should change the belt along with this fix, it has also got hot and probable will not last as long as it should.
Mar 15, 2008 | Maytag Atlantis MAV9750A Top Load Washer
Washing Machines Logo
55 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
