Question about Dryers
How to remove cover on my arlec ceiling fan to clean
SOURCE: light bulb burned out in ceiling fan
THE FAN IS ACTUALLY A WINWARD II BY HAMPTON BAY. ACCORDING TO INSTRUCTION MANUAL YOU TURN THE GLASS BOWL COVERING THE LIGHT ASSEMBLY UNTIL IT MAKES CONTACT WITH A COUPLE OF GROOVES IN THE RIM AND THE GLASS ASSEMBLY SHOULD RELEASE. I DID NOT RECEIVE ANY HELP FROM "FIXYA" BUT MAYBE THIS INFO WILL HELP SOMEONE ELSE WITH THE SAME PROBLEM. THE MODEL # OF THE HAMPTON BAY FAN WAS 523 342. (I FOUND MY INSTRUCTION MANUAL AND THIS IS WHERE I GOT MY INFO)
Posted on Mar 28, 2009
  • 7 Answers
SOURCE: removing ceiling fan blades
Wait? Why would you want to remove the blade? Are they broken? Is the fan unbalanced? Try cleaning the blade. If the fan still wobbles, try tightening the screws. If the fan still wobbles, Unscrew the blade and unconnect the blade from blade iron. Buy the new blade iron. If the blade is broken, Also buy the new blade.
Posted on Jul 12, 2009
  • 17 Answers
SOURCE: how to clean blades and/or how to remove fan cover for cleaning
I am certainly not an expert on this field; yet i have done this my self and this is what i did:
MOst fans have clips.
check where the from and back pieces attach. there should be several clips there remove them and voila.
if not there possibly check the centre pice of fan this may have a screw that holds front and back pieces together as well.
Pllease note you will also have to remove the legs from the side of fan as well. if the pic is the same one you have
Hope this helps
Roty:)
Never argue with an idiot
They bring you down to their level
Then they pummel you with experience
Posted on Aug 20, 2009
  • 3600 Answers
SOURCE: need to tighten the ceiling fan but cannot get the
does it have a light kit? if it does remove the likt kit and inside you will see a black and white wire be sure to turn wall switch off and tpe it to the off postion once the light kit is off you will see a shaft that runs from the center up to the cealing you will see a nut that is on the threded shaft remove that nut to get to the upper part of the motor. and reinstall after words. you can also go to hampton bay web site and you can see a parts blow up of your fan and you will see how it works. hope this helps. go to this web site and sign in and you can get the picture.
http://www.homedepot.com/webapp/wcs/stores/servlet/ContentView?pn=KH_BP_LF_Hampton_Bay_brand&langId=-1&storeId=10051&catalogId=10053&cm_sp=THD_Marketing-_-hampton_bay_brand_page-_-vanity09
Posted on Sep 29, 2009
Testimonial: "thanks it was very helpful!"
heatman101
  • 43501 Answers
SOURCE: trying to remove cover that houses the ball and
There should be a couple of small screws at the very top on the side of the canopy...you will need to loosen these a few turns and then turn the canopy and drop it down...
This link will help you they had the same problem as you...
http://www.askmehelpdesk.com/electrical-lighting/hampton-bay-ceiling-fan-removal-25673.html
heatman101
Posted on Apr 29, 2010
Nutone bath fan how do you clean the vent
Usually the vent cover pulls straight down, and is held in place with 2 V-shaped metal spring wires.
Squeeze each spring wire together to release cover from ceiling box.
Use vacuum to clean vent fan housing. Some vent fans can be disassembled and motor housing removed for cleaning. Do NOT use water on electric motor. Simple vacuum, or dry toothbrush cleaning is good enough.
Spay tiny bit of WD40 on the fan motor shaft or add tiny dab of white grease if desired.
The plastic cover can be scrubbed with soap and water, rinse to remove soap residue, and when dry, paint with aerosol spray paint using 3-5 very light coats applied in 5 minute intervals.
Jul 28, 2012 | Broan-NuTone Fan,Bathroom Exhaust Broan...
Ceiling fan not working. How do I remove the fan to see if the vent is clogged?
Usually the cover pulls down, and is suspended on wires.
Push together the wires to release cover.
Use vacuum to clean.
Dissemble using screwdriver if possible. Some newer fans are one-piece and cannot be taken apart.
See if fan turns on.
Open wire cover and inspect wires.
Use non-contact tester to see if unit has power when switch is turned on.
See if switch is good.
If fan does not turn on, then wires are loose, switch is bad, fan motor is bad.
Some fan motors are sold separately, and some are not, and whole unit has to be removed from between the joists, and new fan installed.
Dec 05, 2011 | Broan-NuTone Nutone 70 CFM Deluxe Ceiling...
The house we bought had a Hampton Bay St. Regis ceiling fan light. We had to buy a remote and it works but the top tier light stays on and will not go off as long as the switch is on. Any ideas? Thanks.
Sounds like the remote control receiver has gone, replace the receiver. Purchase them seperatley very common for these to play up, even new ones made in China especially arlec brand !
Easy to get a new one though, find them at home depot or hardware and lighting stores. the receivers simply go at the top of the fan where they meet the ceiling. Easy to wire up too. But should be done by an electrician, athough it's not rocket science.
Jun 04, 2011 | Hampton Bay 60 In. St. Regis Fan, Ancient...
How do you remove the cover for cleaning?
the cover is just held in place by two spring type hangers. if you pull the cover straight down from the ceiling it should pop down about 2 inches, and then you will need to squeeze the clips to get them to release.
c...
Feb 24, 2011 | Broan-NuTone Broan 110 CFM Premium Bath...
REMOVAL FROM CEILING
In general, the steps are:
1. Turn off power at the breaker -- not just the light switch.
(There are still "hot" wires in the junction box when "Off".)
2. Take out any light bulbs.
3. Remove any light globes. Some screw in, but most are held by springs so just pull gently with a bit of force.
4. Remove fan blades. Most have a spring at the inside edge of the blade -- press down on the spring and push the blade toward the fan motor.
5. Remove the ceiling mount cover. There is usually a circular ring up next to the ceiling; just twist it off with your hands ("lefty - loosy, righty-tighty").
6. Unscrew the ceiling mount screws. Usually there is one or two in a "simple" hole, and two one "sliding" slots. Take out the "simple" screws, and loosen (but don't remove) the "sliding" screws. Be careful not to drop screws or washers into the fan motor.
7. Twist off the ceiling mount cover to expose the wiring.
8. Disconnect all wires. For safety, put a wire nut on the wires from the ceiling.
9. Tip the fan and remove it from the ceiling mount. Keep in mind that the fan is pretty heavy, and you're on a ladder!
NOTE: Be careful not to put any pressure on any of the blade holders, especially if you intend to re-use the fan. If you do, the blades will wobble.
10. If you're installing a new fan, you can probably re-use the mount. If you want to put up a simple light fixture, remove the mount by unscrewing the two long screws holding it to the junction box.
Jul 17, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
Trying to remove cover that houses the ball and pipe that hangs the fan. There is no screw to hold the ceiling mount cover to the ceiling mount. I tried pushing up and twisting but no luck. Could someone...
heatman101
Apr 29, 2010 | Hampton Bay 46056 Callaway II Ceiling Fan
How does the cover plate attach to the ceiling plate to access the wiring from the ceiling
The trim ring (flush with ceiling) rotates ccw to remove. Than you'll see small screws holding cover in place. Remove, lower cover and wires will be accessible.
Feb 02, 2010 | Hampton Bay 24002 Ceiling Fan
Have a broan n688 ceiling exhaust fan in bathroom and now it takes a couple of minutes to actually start, finally making a whirring noise before coming on. Solution?
First turn the power to the fan OFF. Take it down from the ceiling by removing the screws holding the cover on. Then remove the screws holding it to the ceiling. Then unscrew the screw caps that twist (connect) the wires from fan motor to the house wiring. Do a general clean up on the fan. Use an old paint brush to get in the hard to get at places. Rotate the fan by hand. If it does not rotate freely, put some oil on the shaft where it goes into the motor, and put some on where the shaft comes out the back. If it still does not rotate freely, buy a replacement and install it.
Oct 07, 2009 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Removing ceiling fan blades
Jun 13, 2008 | Angelo Brothers Westinghouse (r) Savona ES...
Dryers Logo
114 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
