Question about Logitech Marble Mouse Trackball
Need the ability to "tab" from field to field on right of kybd
I do a lot of data entry. I need something easily accessible by the right hand to move from field to field across the page - left to right. Just as it would do if you hit the "tab" key that sits above caps lock on the left side of the board. I do not need the left movement, only moving to the next entry point on the right.
Often I am holding docs with data my left hand and doing numeric entry to spreadsheets or forms. This function would greatly speed my input.
When you press ENTER to finish working in a cell, Microsoft Excel moves the cursor one cell down by default. However, you can select the direction in which you want the cursor to move.
  1. On the Tools menu, click Options.
  2. On the Edit tab, do one of the following:
    • To change the direction in which the cursor moves, select the Move selection after Enter check box, and then select a direction in the Direction box.
    • To keep the cursor in the current cell, clear the Move selection after Enter check box.
Note When a range or set of ranges is selected, pressing ENTER moves the cursor within the range or set or ranges only.
Posted on Jun 23, 2009
I have a Symbo LS2208 Scanner with a USB cable. The code is 39 I wan to program Shift + Tab and the tab key into the scaner. Here is the steps of what I want to accomplish. I have a window form...
give me the name of the program you curently use so i can try to see how i can convince it to move to the product code when you first scan.
Nov 28, 2011 | Symbol LS2208 Handheld
Tip
Set up a GPRS data connection for email Please note: Please note that you need a...
Set up a GPRS data connection for email info.png boxAdd('subj0', cBoxClosed);
Please note: Please note that you need a POP3 email account in order to send and receive email messages on your phone. You cannot access web-based email accounts (e.g. Hotmail accounts). 1 Find "Access points"
  • Press the menu icon.
  • Press the fourth tab.
  • Press Phone settings.
  • Press Connectivity.
  • Press Access points.
2 Create new or edit existing data connection
  • To create a new data connection:
  • Press Add.
  • To edit an existing data connection:
  • Press the required data connection.
  • Press the icon to the bottom left.
  • Press Edit.
  • Press the Connection title input field.
  • Press C to clear the input field.
  • Key in EMAIL GPRS and press OK.
3 Select data bearer
  • Press the Bearer drop down list.
  • Press UMTS or GPRS.
  • Press OK.
4 Select authentication
  • Press the Authentication drop down list.
  • Press PAP or CHAP.
  • Press OK.
5 Enter username
  • Press the Username input field.
  • Key in user and press OK.
6 Enter password
  • Press the Password input field.
  • Key in one2one and press OK.
boxAdd('info6', cBoxClosed); The APN name general.t-mobile.uk must be in lower case letters. 7 Enter APN name
  • Press the APN input field.
  • Key in general.t-mobile.uk and press OK.
8 Save and exit
  • Press Save.
  • Press Disconnect to return to stand-by mode.
on Apr 30, 2008 | LG KU990 Viewty
Several keys on my keyboard not working Latitude E4300 - keys POIQWE Any ideas - I have tried drain the flea but does not seem to work for me
You will need to replace it.
Search eBay for one... lots there for about $15
To replace it open screen all the way... lay it back.
On right end just above keyboard to the right of the power button, you should see a small groove that will allow you to pop up the hinge cover that covers the kybd lights and hinges. remove this carefully as it is just plastic and will break.
Once the bezel is off there are 3 screws that hold the kybd in place ... remove them
Carefully lift the top edge of the kybd... it will flex and the sides should pop out. Pull it gently towards the screen to release the tabs on the bottom.disconnect the ribbon cable and replace it by reversing these instructions
Jan 02, 2011 | Dell Latitude E4300 PC Notebook
Access database was copied now no tables in dropdown list
Your version of Access may require slightly different menus and clicks than mine, but the procedure is straightforward and should be very similar to what you will need to do. Read the whole post first!
Make sure you have permission to modify the database, then go to the form (I assume the drop-down table is in a form) and go to design view.
In design view, click once on the dropdown box you are having a problem with, and a properties screen with several tabs should pop up; click on the data tab, and look at 'data source'. In the list look for 'row source type' to see if the source of your data is a) a table or a query, b) a value list or c) a field list. Most dropdown boxes use either a value list or data from another table or a query (based on a table).
Check the source of data by going down to the next line in the list titled 'Row Source' (this is the list on the data tab that popped up when you clicked on the dropdown box in design view).
If the source is a table/query type you should see some code in the Row Source box like "SELECT....". Without changing anything, click once immediately to the right of the box, and whatever source the rows are coming from should pop up--if a query, for instance, it will pop up the underlying query in design view.
You should be able to troubleshoot the underlying query to see why no data is given in the dropdown box.
Another point where underlying query or table is used: If the table was based on a query that pulls data from the records in the current database, the drop down list will be blank until new records are added so the query has something to list.
And if the source is a 'value list', the values should be included in the row source box below, separated by semicolons. If not you simply need to add them in.
If your source is a field list, go back to whomever copied the database and tell them you need help with the copy they gave you...
Sep 13, 2009 | Microsoft OFFICE 2003 BASIC OEM ENGLISH MS...
Microsoft access form problem
In the Design view for your form element (eg textbox), go to the Data Tab. Look at the options for:
Input Mask, Validation Rule and Validation Text. You can use any combination of these to force a user to enter something in the field. If you just want to check that the contents of the element has a non-zero length, then you can write an event (Events tab) to check the length of the values entered. If 0, then throw a message box and re-focus the cursor on the textbox.
May 19, 2009 | Microsoft Access 2003 for PC
Data in one record changes to the data in the following record
You have to go into the design view of the form. On the field(s) that this is happening to, right click and select properties. The select the Event tab. Go down the list and look for the "On Mouse Move" perperty. See if there is an Event Procedure in the block to the left. If there is, that is most likely what is causing this to happen. The procedure is probably written to perform this action.
Mar 23, 2009 | Microsoft Access 2003 for PC
I need to turn on my help and support server
I believe you mean help and support service. In which case:
1> Go Start -> Control Panel -> ( under Performance) Admin Tools -> Computer Mangement
2> After opening the computer manager, you'll see three explorer branches on the left of the util, the last will be Services and Applications. Click the + next to it to expand it if needed.
3>Under Services and Apps, click on Services in the left explorer panel.
4> It should show several services to the right hand side. Click anywhere on a service and hit "h" to fast navigate until you hit Help and Support.
4.1>On the same line as the name, there should be an entry saying what startup mode it is in - Auto, Manual, or Disabled. If it is in auto, it should already be running, and the "Status" field should say "Started" - if it isn't started, it will be in step 5.
4.2If the service is on Manual, it wont start itself - if you need it in the future, you should right click on the entry and then Properties.
4.2.1>Once in properties, make sure you're in the "General" tab. Once there, a pop-down field next to a label of "Startup type" is where you want to change it to Automatic.
4.3> If the service is Disabled, you will need to follow step 4.2, and set it through Properties to either Manual or Auto.
5> Right Click the entry for Help and Support, and click Start. This should start the service.
Have a nice day and please rate. Thank you.
Dec 15, 2008 | Computers & Internet
Microsoft Access
You need to set up security and different profiles for different people. that is the safest way. But an easier way is to have you enter data in one form and them enter their data in another form. In their form edit the properties of the fields that you want left alone. You need to set the properties to locked in the form where they do their data entry but leave them unlocked where you do your data entry. Just creat a second form by saving the first one under a different name. Also you might want to remove the fields from the tab stop list.
Oct 23, 2008 | Computers & Internet
Viewing ms Sql Server database on Access
Are you familiar with "Linking" tables in Access? In Access: File --> Get External Data --> Link Tables. This will bring up a dialog box which allows you to browse to your SQL server and select the table you want.
Aug 23, 2007 | Microsoft SQL Server Standard Edition for...
Logitech Marble Mouse Trackball Logo
104 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
