Question about Lexmark X6170 All-In-One InkJet Printer
New cartridges - printer not printing
Installed new cartridges and reset alignment yesterday. Printer worked.
Today will not even copy a page. I cannot find the info used yesterday that told me how to reset alignment. Can you help?
  • 64 Answers
Align your cartridges to solve print quality problems such as: • Characters are not properly formed or are not aligned at the left margin. • Vertical, straight lines are wavy. 1 Load paper in the paper support. 2 On the control panel, press Copy. 3 Press Options until Maintenance appears. 4 Press the right arrow until Align Cartridges appears, and then press Select. An alignment page prints. Once this page prints, your automatic alignment is complete.
Please rate this solution.thanks and good luck.
Posted on Jan 30, 2009
Our copier (model x5650) stopped while receiving several pages , and displayed FAX IN MEMORY COLOR AND BLACK INK CARTRIDGE NEEDS REPLACED. I installed a new black cartridge , however the display...
YOU NEED TO LET THE PRINTER RE-ALIGN ITSELF AFTER INSTALLING PRINT CARTRIDGES, THE PRINTER SHOULD HAVE PAPER IN IT TO DO THIS, THE TEST PAGE PRINTED WILL THEN NEED TO BE PLACED IN THE PRINTER ON THE GLASS, PRESS SCAN, THIS SHOULS RESET YOUR PRINTER.
HOPE THIS HELPS!
MARTIE
Aug 24, 2011 | Lexmark C533DN InkJet Printer
Tip
How to reset the counter when replacing the inkjet cartridge.
Typically when you put a new ink cartridge in a printer you need to go to the cartridge maintenance location of the driver and "reset" the counter so the computer knows you have a new cartridge installed. By doing this the computer can keep track of the ink level because it knows approximately how many sheets can be printed on an average cartridge. This location can be accessed from the desktop by clicking on "start", then "control panel" then "printers and other hardware" then "view installed printers and other hardware", then click on the appropriate printer, then click on "printer" then "properties" then "cartridge maintenance". At this point there should be a selection where you can reset the counter, print a test page, print an alignement page, etc. I would recommend printing an alignment page. Every time you remove and install a new printer the alignment changes. Follow the instructions on the screen and your printer should be reset and printing like a champ.
hardrocko
Thanks for using FixYa
on Mar 03, 2010 | Office Equipment & Supplies
I was given an HP Officejet J3640. I installed the HP21/22 ink cartridges, printed the alignment page, then loaded the alignment sheet in the feeder. After I loaded the alignment sheet, it responds...
Hi
Check if the alignment page has been printed correctly i mean the bars printed with a little yellow color around it right?
Okay what you can do is do a reset first. Follow the below things
1. When the printer is on remove the power directly from the back of the printer.
2. hold # and 9 key and connect the power
3. Printer will show you on the screen it is resetting the NVRAM then release the buttons
The printer will print alignment page again this time try to scan and it should work.
DO RATE MY SOLUTION
Jun 30, 2011 | Office Equipment & Supplies
Printer is only half printing doc on each line, have done test page, very faint, aligned ink, clean cartridges, all with top v faint and bottom dark ink, new cartridge last fri and was working well,...
Open the rear of the printer and make sure theres no paper jam or broken parts.
Try printing a document with the rear of the printer open and watch to see if anything out of the ordinary happens.
Mar 01, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
I installed a new printer cartridge. The alignment page printed out but I threw it out. I didn't realize I would need it for any reason. How do I align my cartridge without the paper.
Every HP I've owned has printed the alignment page until you scan it. Just plug in the printer, power it up, and check it out. If that doesn't work, try removing the ink cartridge, and reinstall it. One way or the other, I'm sure the HP will print a new alignment page.
Carl
Dec 30, 2010 | HP Officejet 5610 All-In-One InkJet...
I just installed a new color cartridge in my 8650 Lexmark printer. The ink cartridge acts as if it is empty. Printer keeps telling me to align cargridge. Worked perfectly before the new ink installed. Not...
  1. On your computer, go to "Start," "Programs," "Lexmark Series." Click "Lexmark Control Program."
  2. Step 2 Select the "Cartridges" tab. Click "Change Cartridges." The Change Cartridges screen appears, displaying the animated instructions for installing or changing cartridges. When you have finished viewing the animation, click the "Finished" button.
  3. Step 3 Remove the tape covering the print head of the new print cartridge. Insert the new print cartridge as shown in the animation.
  4. Step 4 When the "Choose Cartridges" screen appears, select the cartridge(s) you installed in your printer from the list boxes. Click the appropriate box to reset the ink levels to full. Click "OK."
  5. Step 5 The Automatic Alignment screen appears. Click "Align" to align the print cartridges for best print quality. The printer prints a page with a bi-directional alignment pattern. On the printed test page, locate the number that comes closest to forming a straight line under the bi-directional alignment pattern. Enter that number as the bi-directional alignment setting in the Alignment Cartridge dialog box. Click "OK."
Nov 25, 2009 | Lexmark All-in-One Printer with PictBridge
Printer will not print or make copies. Our alignment page got accidently thrown away. Can we align the printer without it? Can we get a new alignment page?
alignment page is done during the installation of new ink cartridges. you could re align the printer.
press setup > tools - ok > align cartridges - ok and then scan the aligned print out
Oct 31, 2009 | HP OfficeJet J4580 All-In-One Laser...
Continuous Alignment Message, Please Wait.
Click here and follow the instructions to do a partial reset on your printer and try to align cartridges. Click here for instructions to align cartridges.
Jun 08, 2009 | HP J3680 Officejet All In One Printer
Will not print black , HP PSC 1610 All-in-One
Is it a new genuine cart? If so, I have had this problem. Run multiple copies of black only text, Run 50 copies, will still spit out blank pages.Then head clean. If no black repeat. I did this for around 200-250 copies then Volia! black. Hope this helps
Apr 28, 2009 | HP PSC 1610 All-In-One InkJet Printer
Problems priniting
copy alignment..did you try a test page`?
Oct 13, 2008 | Lexmark X3470 All-In-One InkJet Printer
Lexmark X6170 All-In-One InkJet Printer Logo
330 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
