My FRIGIDAIR washer dryer(very old) when swiched on with the wet clothes, is working as usual. but the clothes are still wet, no heat air is coming. What could be the problem, and how to solve it.
Some dryers have a thermal trip which can be reset often from the rear. Other than that, best to check the heating element with a multimeter - this will show you if power is reaching it, and if so, the element is bust. If no power, then it will be a wiring fault or perhaps a problem with the PCB electronics.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
