Question about Hotpoint 3.5 cu. ft. / 99 liter Upright Freezer RZA30
Freezing up too frequently
What is the proper number on dial to set freezer
Refrigerator and freezer is freezing everything
Its either a bad defrost timer not kicking on, bad main control board or the temp switch. Sorry not much help but the only way to really tell is check with a ohlm meteor and eliminate each part.
Mar 04, 2015 | Kenmore 26.5 cu. ft. Side-by-Side...
Need mamual model FFU11FKODWO upright Freezer
temperature is set by dial #1 being the warmest and 9 being the coldest the numbers on the dial are only for reference they do not reperesent a certain temperature you will need a thermometer to figure out what number is what temp but they do recommend starting in the middle
Jul 26, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Electrolux freezer will not turn on automatically when termperature warms in compartment, controls don't appear to turn compressor on, any help would be appreciated?
Sounds like your thermostat is bad. You probably have to replace it and the sending unit also. Big job! Look for a manual at : http://www.servicemanuals.net
Apr 28, 2014 | Electrolux Freezers
My Fridgidaire upright Gallery freezer is freezing my food but the appliance seems to be constantly running and the temperature control on the outside is reading 29 Celsius when it obviously isn't
Hi Susan Abboud - Modern freezers have increased storage capacity and keep more even temperature that may require the compressors to run longer but use less energy. Was the unit disconnected previously for any reason? If so, freezer requires a minimum of 4 hours to cold down completely. Confirm that the temperature control is not set too cold and that the door is not being open frequently. A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Keep in mind that there should also be at least 4-6 in of air space on all sides of the unit. If freezer is built in or has items stored on top that cover the unit, the can cause long run times, high temperature in the freezer and premature failure to the unit. Do not block the toe grille on the lower front of the unit. Sufficient air circulation is essential for the properly operation of your freezer, about 3 inches around the unit.
Nov 22, 2012 | Frigidaire 20.6 cu. ft. / 583 liter...
Have a ColdTech refrigerator/freezer that the drain line on the center back wall of unit, keeps freezing up. Have had the drain line heater replaced twice in less than two months. Suggestions?
I have a coldtech ice freezer 43SLG-L3-JF, the thermostat dial is blank, which way do I turn dial to lower the temp, clock or counter clockwise?
Apr 13, 2010 | Freezers
Frezeer fz90 thye hight temp light is on and the food is de freezing and we would like to know what the dial be on
the food in the freezer is getting warm (de freezing?) because you have a faulty part. changing the dial now wont do any good, but it should be in the middle setting. I cant tell what part is bad with your lack of description.
Mar 20, 2010 | Freezers
Whirlpool ED25RFXRWFreezer/Fridge temps unstable...either too hot
check the defrost timer but the cold control could be bad
Mar 01, 2010 | Whirlpool Freezers
Chest Freezer not freezing
check the temp dial. and set to a lower temp. *be mindful of the surrounding temp of the freezer. it will not work properly if it is in 125 degree surrounding air. * check the coils on the freezer and make sure that they are clean. this allows for proper heat transfer from the inside of the box to the outside air. also check to see if the blower is running. * Check to see if there are signs of oil around the freezer, if so contact a service tech
Nov 14, 2009 | Freezers
My hotpoint under counter freezer isn't freezing properly
A freezer has a very simple operating design and there are only 2 customer serviceable components.
1. Make sure the cold control is set at the proper level.
2. Make sure that the door seal is making good contact with the cabinet. You can apply a thin coat of Vaseline to the door seal to help tight closure of the door.
Keep the door opening to a minimum during extreme heat conditions. Any small air leak can drastically reduce the operating norms during extreme heat conditions.
That's about all that you can do to regain control, the rest will have to be performed by a refrigeration tech. if you are still dissatisfied.
Jul 05, 2009 | Amana Freezers
Kelvinator Fridge/Freezer C 340 RM does not switch off
the problem is your thermostat in your frig.the dial with numbers on it.it is no longer sensing properly and theres nothing you can do but replace.that is as long as your dial is not broken[the plastic pice with the numbers] God bless ,tom
Jan 10, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Hotpoint 3.5 cu. ft. / 99 liter Upright Freezer RZA30 Logo
35 people viewed this question
Top Hotpoint Freezers Experts
AJMAL KHAN
Victor Nwachukwu
Victor Nwachukwu
Justin Duby
Justin Duby
Are you a Hotpoint Freezer Expert? Answer questions, earn points and help others
