Question about Reddy R155D Utility Heater
The fan comes on but the burner won't kick on and then shuts off
Last time I used it the heater would run a litte bit shut off , a minute later turn back on did that a few times and then blew a big puff of smoke. now plug it in the fan turns on but the burner won't kick on and it shuts back off.
  • 92 Answers
Check your fuel line for cracks and also the air line. Most likely is the CAD flame sensor, easy to change and only 3 bucks or so. Might also want to check all of your filters. Mine was doing the same thing and it was the high heat limit control and the flame sensor.
Posted on Jan 22, 2009
1999 Goodman down draft natural gas furnace. It starts as normal, the burners fire and it warms up, but the blower doesn't start, after a couple minutes the burners shut down and the blower immediently...
IT SOUNDS LIKE THE FAN CYCLE RELAY OR BOARD IS NOT MAKING THE FAN COME ON WHEN IT SHOULD THE BURNER SHUTS OFF PROBABLY BECAUSE IT REACHES THE HIGH LIMIT.
Feb 03, 2015 | Heating & Cooling
Dg606i have afurnace that the burner comes on and burns then shuts off a minute later the fan comes and blows for minute or so then shuts and the burner comes again burns for 3 or4 minutes shuts off then...
Your Furnace is short cycling...cutting out too soon. I would call for service on this one. If it has a flame sensor and you know where it is, clean or replace the sensor. If there is a air/sail switch, make sure it is free to float/swing.
Oct 17, 2013 | Dryers
Fan continues to run after the burners kick off. Fan should run for awhile then shut off, but mine is running all the time
Auto matic fan control AFC is not shutting down , you can roemove this and clean the back of it . It could be blocked with dust , or it may need replacing.
Mar 10, 2012 | Heating & Cooling
Hi, I have a Dayton 3ug73 heater. The heater will not shut down after the initial heat requirement is met. I have the thermostat set on low but it continues to heat. I shut the power off to it to keep...
It sounds to me like your thermostat may be bad. I would check power incoming to t-stat then turn temp. setting up and down to see if it is switching on and off. If not then replace. If it does then I would check all wiring to gas valve and if power is shutting off to valve but burner continues then replace gas valve. Thank you.
Mar 07, 2011 | Dayton (3UG73) Electric Utility Heater
Our furnace seems to run on idle constantly . we are using more oil but not electric if i tap on the box it stops but starts again a few minutes later??
We need to get a few details cleared up:
Is it the Furnace (Oil burner) that is running, (on idle you called it..)
or is it the FAN that is running?
What are you tapping, that shuts off what?
Is the fan that blows the air around the home shutting off, or the burner?
(When the burner is running, there is a loud roar!-- the fan should be much quieter..)
If it is the fan that is running,-- I might ask, is the air coming from the registers too cold?-- for with the fan running, you are getting all the heat from the oil that was burned. But naturally, you don't want it to be uncomfortable.. So-- you can open the cover on that Fan control switch, and raise the temperature at which the fan turns ON and OFF..
Let us know what you find.
Mack B
Dec 28, 2010 | Heating & Cooling
We have a tempstar down draft furnace. 2 years ago the heat exchangers where replace because we were told they were cracked. This year the downdraft motor was makikg a lot of noise & we were told the...
Sounds like the low limit or high limit is out these control the fan motor.They are usually set to kick on around 150 degrees and set to go off around 95 to 100 degrees. Over heating does happen with cracked heat exchangers and it can possibly take these two items out. Normally your furnace should run approximately five minutes or a little less then your fan motor comes on and then for cooling down burners should drop and the fan motor should run again roughly five minutes or so then shut down. Times may vary as to your settings.
Dec 20, 2010 | Heating & Cooling
Dayton 3E227A Heating Cycle
The sensor for the thermostat is probably going bad or has bad connections. It is (or thinks it is) heating up fast and therefore shuts of the heater.
Dec 30, 2007 | Dayton (3E386) Heater
Reddy R155D Utility Heater Logo
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
