Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Wi-fi without computer connected
I have a DSL connection through AT & T, the problem is the phone wire goes across the carpet about 15 feet. I don't have a phone plug near the computer. I want to know if i can connect the router without the being connected to the computer? I plan to put a USB wireless connector on the main PC and laptops.
  • rphnb407 Jan 22, 2009
    Do i have to change anything in side the router for it to act as an access point?
  • Belkin Master
  • 6,487 Answers
If this is your router F5D9230-4 then the answer is YES, you can make all your computer wireless using a Wireless USB adapter for your desktop and laptop and this router will be your wireless access point so you don't need to run cable on your network ...
Posted on Jan 22, 2009
  • Mark Gil
    Mark Gil Jan 22, 2009
    Nothing to change that is a wireless router already , meaning it will work as a wireless access point and router at the same time..
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
May 01, 2015 | Computers & Internet
Talk talk, technical assistance
How did you connect the computer to the router. If you are using a DSL modem it will have a DHCP server in it that is allocating IP addresses across your network. If you added the router to the computer via a hub or network switch what is the computers ip .
address. Remove the WI FI router - turn off P.C and then Go to cmd or dos prompt if windows based system and type in ipconfig and press enter to see if ip addresses are if they are your dlink router uses so you need to make the dlink router ip addressand subnet setting to match the Modem ip addresses of the DHCP server. Change the ip address of the dlink router to be and change the modem to allocate DHCP IP addresses from to Only do this if IP addresses are 10,0,0,1 to 10.0.0.,254 on the desktop p.c with the dsl or cable modem connected.without the router being involved. (you may need to ask the ISP what the user name and password is of the modem and it should be ip address xx.xx.xx.1 so type this into a browser to change the modem settings. or just remember if the modem is so is the Wi router from d-link and you will have an ip clash problem)
. How do you do this by ethernet connection from only the desktop directly with only the Wi FI . router. Go to a internet browser and type in the URL and then change the router ip address to match what the DSL modem DHCP issues..
Page 14 of Router instructions see
in the manual it states to use a direct ethernet connection for the setup program but you need to be connected to the internet for it to work but if the IP addresses are wrong or clashing will have no internet. You also want to set the modem as the DCHP server and disable the DHCP server in the set up of the wi fi tand set the WI FI router default gateway as the ip address of the Modem. if any DHCP server options in the WI FI router sert to the modem ip address. .
Sep 08, 2014 | D-Link D Link Dir 615 Wireless Router...
Why my phone not connect internet service?
You have to set it up. Your phone will only connect to a Wi-Fi service not your home DSL or Cable direct. If have a have modem or Router which accept Wi-Fi then you can use your phone for your own local ISP. Its only a setup problem, knowing the same information as you setup your computer at home.
May 10, 2014 | LG GX500 Cell Phone
How to connect to the wifi with 3g iphone
Hello Jane,
When using a Wi-Fi network with your iPhone, you may occasionally encounter the following issues,Unable to locate or join a nearby Wi-Fi network,Weak or low Wi-Fi signal strength,Connected to Wi-Fi network, but unable to access the Internet.
Tap Settings > Wi-Fi and turn Wi-Fi off and then on again. Verify that you are in range of your Wi-Fi router or base station. Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on. Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet. Update your Wi-Fi router to the latest firmware.
Jun 03, 2011 | Lands Phones
Let me clear up a little confusion. You don't have wi-fi on your account, you have Internet access. Wi-fi is not something that you subscribe to or purchase separately. Wi-fi (wireless) access is provided by a router that allows the Internet connection you pay for to be shared by several computers. The typical router has both wired connections (usually 4 of them) for computers that don't have wireless capability, and acts as the access point for your wireless network.
Your modem is the device that connects you to the Internet through your service provider (ISP). Most ISPs are supplying a combination modem/router for their customers since so many people want wireless access in their homes. If you have one of these, you actually have wireless capability already. But your modem might be an older type, supplying a single wired connection for one computer only. You didn't give the model number of your Westell modem so I can't tell you what you have, but you can tell by looking at it.
A single-connection DSL modem will have only two ports. One is the connection to the DSL phone line, and is a standard-size phone jack labeled "DSL". The other is the network cable connection to your computer, usually labeled "COMPUTER", "LAN" (short for Local Area Network), or "ETHERNET" which is the type of cable used. If this describes your modem, you will need to provide your own wireless router to make your new wireless netbook work.
On the other hand, a combination modem/router will have the DSL connection jack and 4 connectors for computers. It may also have an antenna for the wireless function, but some newer models have internal antennas. If you have one of these, you already have wi-fi capability. You will probably need to set up your network so that your netbook can use it.
There is plenty of information available about how to install a wireless router if you don't have one already. In fact, almost every one now comes with an installation CD that will guide you through all the steps. They aren't expensive and are for sale almost everywhere that sells electronics (office places, Radio Shack, retailers like Wal-Mart, etc.). If you already have the combination device, you can call your ISP customer service for help in setting up your network, or find the information on their website.
So yes, the Sylvania netbook will work in your home, although you may need to do a little work first. But it's really pretty simple, and you'll have that computer online without wires in no time.
Mar 24, 2011 | AT&T High Speed DSL Modem
What is wi fi whats does it do
Wi-Fi stands for wireless fidelity. The term Wi-Fi, which is alternatively pushed by the Wi-Fi Alliance, a trade group that pioneered commercialization of the technology. Wi-Fi is mostly about connecting to the Internet without physically attaching your computer to anything. Mostly it's about using laptop computers.
A Wi-Fi enabled device such as a personal computer, video game console, mobile phone, MP3 player or personal digital assistant can connect to the Internet when within range of a wireless network connected to the Internet. The coverage of one or more (interconnected) access points — called a hotspot — can comprise an area as small as a few rooms or as large as many square miles. Coverage in the larger area may depend on a group of access points with overlapping coverage. Wi-Fi technology has been used in wireless mesh networks, for example, in London.
In addition to private use in homes and offices, Wi-Fi can provide public access at Wi-Fi hotspots provided either free-of-charge or to subscribers to various commercial services. Organizations and businesses - such as those running airports, hotels and restaurants - often provide free-use hotspots to attract or assist clients. Enthusiasts or authorities who wish to provide services or even to promote business in selected areas sometimes provide free Wi-Fi access.
Routers that incorporate a digital subscriber line modem or a cable modem and a Wi-Fi access point, often set up in homes and other premises, can provide Internet-access and internetworking to all devices connected (wirelessly or by cable) to them. One can also connect Wi-Fi devices in ad-hoc mode for client-to-client connections without a router. Wi-Fi also enables places that would traditionally not have network access to connect, for example bathrooms, kitchens and garden sheds.
Good luck and have a nice day.
rating the solution is highly appreciated.
Jul 29, 2010 | RIM BlackBerry Curve 8520 Smartphone
Cannot receive phone calls on a dsl setup
There must be DSL Spliter inbetween telephone line & Wi-fi modem. Please check whether you have connected telephone instrument line with that Spliter or not. According to me, Telephone instrument should connect to telephone line option on DSL Splitter to use same telephone line as internet as well Telephone.
Mar 03, 2010 | Computers & Internet
How to connect my router without the phone line
since you have a wireless router... you can turn on your wireless connection..try to reinstall it..and proceed to the admin page and turn your wi-fi there...then put password so that you can secure your connection..
after that your computer must have a usb bluetooth device.. you can ask for it in the market...just ask for your purpose...
note: connection of your wi-fi in your computer depends on what is the capacity of the bluetooth device you will buy... i mean it has it's limit in size in transmitting and receiving data...
Feb 25, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Cant connect wii to internet
The unit can connect to the Internet by utilizing its 802.11b/g Wi-Fi, which is built in, for wireless connections or via a USB-to-Ethernet adaptor for DSL connections.
For your wireless connection or Wi-Fi, the 802.11b Wi-Fi has a data rate of 11 Mbits per second and has an indoor range of 30m or approximately 98 ft. The 802.11g has the same indoor range, however the data rate is at 54 Mbits per second. If you have an existing wireless connection or are in a Wi-Fi hotspot, the unit will connect to your wireless connection automatically out of the box. If you do not have a wireless network, however, you will need to have your wireless network subscription done or set-up first. Once you have wireless Internet access, you then search for your access point, put in your security settings and you’re good to go. It would also be advisable to have a wireless router for this so that you won’t have to shuttle the connection between your PC and your Wii. wi-fi-usb-connector.thumbnail.jpgAnother option would be to connect your Wii via the Nintendo Wi-Fi USB Connector. This accessory allows Nintendo Wii users who do not have an existing Wi-Fi connection or a compatible Wi-Fi network to create one through their broadband or DSL connected computer. This is inserted into your existing computer’s USB port and the Wi-Fi USB Connector acts as a wireless access point for the Wii. This allows the user access to the internet and to play Wi-Fi Connection games from Nintendo Online.
nintendo-wii-lan-adapter.thumbnail.jpgFor your DSL connection, however, you will need to have quite a few things. You can use a WII LAN adapter to connect your Wii to your DSL modem. You can also use a router so that you can use your PC and your Wii at the same time. With the LAN Adapter though, to use or plug in the Wii, you must disconnect your PC. This can be quite tedious since you will have to plug in and out your PC and your Wii every time you need to use one or the other. A LAN Adapter is fairly cheap, but if you get a router, your PC and your Wii can go online at the same time, saving you the hassle of connecting one or the other when you need them. You can then hook up the existing ethernet cords to the back of the router and connect it to the Wii via a USB 2.0 cord.
i hope this helps
Nov 05, 2009 | Nintendo Wii Console
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
49 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
