Question about Vizio L32 32 in. LCD HDTV
Vizio tv no picture until it warms
No clear picture until it warms up. It is taking longer and longer to warm up.
  • 11800 Answers
SOURCE: after warming up the picture
It flickers because the tension to the plasma panel isn't stable - the power source is faulty. You must open the tv and check the source, the Y and Z boards for failing parts (especially the capacitors).  Also look for loose connectors, bad solderings or bad wires.
Posted on Aug 23, 2010
  • 1623 Answers
SOURCE: tv comes on no picture let it warm up turn it on
either a mosfet or capacitors are ready to fail check the power board for bulging on the tops of the capacitors and replace with the same
Posted on Mar 24, 2011
jhinsincity
  • 616 Answers
SOURCE: my vizio 42" plasma tv one started having a fuzzy
needs Z-sustain board
Posted on Jul 31, 2011
  • 302 Answers
SOURCE: 46in Vizio LCD HDTV distorted black picture when tv is turned on
Hi There are three things that can cause this problem. Your lcd screen, t-con board or the signal board. Most likelly in your case since you say it's only half the screen it's going to be your t-con board. You can try removing it and cleaning all the contacts and replacing it see if that helps. If that doesn't help then replace it. If that does not solve it then it's going to be your screen.
You can get parts at www.interliquidparts.com
Posted on Dec 02, 2011
Vizio Model #VOJ320F1A picture is scrambled until warm up and then small black spot on lower screen for ever
When this happens that usually means that your pixels are burned up you can no longer use them for that area
Feb 06, 2018 | Vizio Televison & Video
Vizio Model# E3D42OVX. Black vertical lines on start up except for top 2"s of screen.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Feb 18, 2017 | Vizio Televison & Video
Vizio picture
you may have a dry joint on the screen controller board or a lose connection on to the screen. clean the board on the back of the screen. but take it out first and clean the copper parts on the screen cable.
Sep 15, 2013 | Televison & Video
White horizontal lines covering picture on Toshiba 51HC85
The set uses a Hyper board inside that processes all signals, it is well known for this issue, board no longer available=reason is quite simple : about a dozen tiny surface mounted filter caps on that board with age dry out, at first it will work after warms up as poor caps regain some capacitance and seem to be ok.
Buy a new set, you can send that board out and have it repaired/rebuilt but the last one I saw which was under extended warranty cost about 200 just for the board rebuild.
In the last 4 years Here on Fixya I have encountered only 2 people who were able with instructions had the skill to remove the board and replace those caps, both were top notch computer repair techs.
Dec 09, 2012 | Televison & Video
We have a Sony Bravia KDL 52 xbr9 tv. It is about 1 1/2 years old. We bought it Nov 29, 2009. For the last few weeks when we turn the TV on, the picture is distorted and dark (there are horizontal...
The board that call the T-CON board it is dying and dead soon.That why it is causing horizontal or vertical lines and distoted pictures.This T-CON board sit in at the bottom in the middle of the tv LCD screen panel and it only job are to decoded pictures pixels before it go onto the tv LCD screen panel.Tries websites Shopjimmmy.com,Ebay.com to buy a whole new refurbish T-CON board for the replacement.
Jul 20, 2011 | Sony KDL-52XBR9 52 in. LCD HDTV
TV picture is unstable until the TV warms up. This is taking longer and longer. Picture gets large, small, large, small... Quality is also lacking until it is warmed up. This is a Phillips 60'' Is this...
What model and brand is your television?
Is it a CRT type or DLP?
If picture is getting smaller then larger, and its a crt rear projection television sound like you have bad connections around the Flyback transformer and or horizontal circuits. This usually happens when a connection is made on the circuit board and the picture returns to normal especially during a cold start, but as the television warms up the connections on the board start to seperate and the problem starts occuring or it could be in the reverse process. Unstable at first then when tv gets warm it make better connections. All in all have a technician check the HV section of your deflection board.
Sep 29, 2009 | Televison & Video
Blurred picture, after some warm-up it back to clear picture
If the problem doesn't return after the picture becomes normal, then it could just be due to the electron gun taking longer to fire up. I don't know how old your TV is, but TVs older than ten years typically take longer to warm up than more modern sets.
Jun 02, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
Picture won't come in clear until TV "warms up" for 15 minutes or more
Change the capacitors first per the instructions in the link below. Symptoms could be anything from high-pitched hum to no picture at all. On these defective models, I would start at the caps and work back. It won't hurt to replace them anyway.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Aug 28, 2008 | Polaroid FLM-323B Television
57h82 toshiba projection tv
Hyper board bad = No longer available part # 23148024 PTS
rebuild only...send core in........57H82..............................T.
Part # is specific to model !....
Mar 20, 2008 | Toshiba 50H82 50" Rear Projection...
Vizio L32 32 in. LCD HDTV Logo
80 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
