Question about Whirlpool ED2FHSS Side by Side Refrigerator
Freezer not freeaing
Freezer not freezing, model hss251fmb ww, i believe it is low on freon, type 134a...i have gauges but need to know the pressures
  • 27 Answers
The suction pressure should not be less than 5-10psig
Posted on Mar 10, 2009
What are the AC pressures supposed to be on a 2000 Monte Carlo?
On hot day @ 85=+ degrees it should be between 45 to 50 pounds on the low side pressure port
Jul 01, 2011 | 2000 Chevrolet Monte Carlo
My recently acquired used hotpoint refrigerator model number hss251fmb ww freezer side freezes sometimes but at times it just refrigerates, the refrigerator side almost never gets cold....(enough...
I would check for ice build up in the freezer area. Take the food out, remove the shelves and then remove the 4-6 screws to take the inner back panel off and take a good look for ice. The defrost assembly might not be working if you have an ice build up.
You also need to see if the fan is working or not.
You can either let the unit sit with the door open and defrost naturally or use a hair dryer to speed it up some.
http://www.partselect.com/ModelFrames.aspx?ModelID=379769&ModelNum=HSS25IFMBWW&mfgModelNum=&ManufactureID=2&Selected=00113066i06&Position=5&mfg=GE&Type=&Mark=3
Jun 08, 2011 | Hotpoint Refrigerators
Air conditioner does not cool in 2000 Yukon.How do I check freon level and how to replace freon if need be
Get an r134a refrigerant add kit from Walmart or your local auto parts store.
You can even get a can of Arctic Freeze by Intermatics that has a hose and a gauge on it.
Connect the hose to the low side port. You can find this port on the 'thicker' piping that comes off of the compressor (versus the thinner piping that comes off the compressor which is the high pressure side).
Pressure should read 25 psi to 45 psi on the low pressure side when the compressor is running and the a/c is on.
Pressure should read 75 psi to 100 psi on a hot day when the car is off.
However, you'll want the a/c to be running when you add freon.
Press the button on the can to install more freon, if needed.
Aug 19, 2010 | 2000 GMC Yukon Denali
What could cause an evaporator coil to freeze up on a true t-19f. Also what is the suction pressure on this model.
Hello
Could be low on freon,i belive this model uses 134A.
So the suction pressure should be 31 to 35 psig,for a temp of 36 to 40.f
Also check the defrost timer and the door seal. The eveap should have a drain line on it, make sure this is working and not plugged.
Apr 07, 2010 | True 19 cu. ft. / 538 liter Commercial...
The kenmore 20 frostless deep freezer is cold in the lower section of the freezer but the upper half is warm the setting is maxed out. the air that is blowing across the coil appears to be warm. that leads...
The evaporator coil must be lightly frosted from the top to bottom. This proves that all of the r-134a freon is still present in the system. If you visiblely see that it is not (half frosted the other half warm?no frost) then this is a sign that the r-134a freon has leaked out. Another way to determine for sure is to use refrigeration gauges to check the pressure.
let me know what you found then we can take it from there... hope this was helpful
Apr 05, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer not freezing blowing out 22 degree air obviously not cold
Its been a while since I have done a freezer but I believe they are much lower than that. I think it is more like -10 to 0 pounds. at most 1-3 pounds
Feb 24, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer side of refridgerator doesn't freeze foods properly and also makes only about 10 cubes a day. food side works fine, it's a Hotpoint model #HSS251FMB WW
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
thumbs up
Aug 17, 2009 | Refrigerators
Need to know what type of freon to use to recharge a one yaer old Beverage Air Sandwich table refrigeration unit. Is this the same process as recharging an automotive AC system?
Beverage air used R134a almost exclusively on refrigerators. The process is similiar to ac systems. You should weigh the charge in as per the data plate. Be precise as over or under charge can dramitically affect the performance of the unit. Hope this helps
Mar 29, 2009 | Beverage-Air 44.9 cu. ft. / 1271 liter...
Freezing
YOU COULD GO TO THE AUTO ZONE AND BUY A TAP VALVE AND FREON 134A CHARGE IT THROUGH THE LOW SIDE SHOULD READ 5 AND HIGH 150 USE 134A. IT MIGHT WORK FOR A FEW MONTHS TO A YEAR IF NOT LONGER BUT YES IT HAS A LEAK THE CONDENSOR IS BUILTIN AND MADE OUT OF STEEL AND IT RUST THROUGH OUT THE YEARS THEY SHOULD OF USED COPPER NOT STEEL
Aug 29, 2007 | Amana 16.8 cu. ft. / 476 liter Upright...
Whirlpool ED2FHSS Side by Side Refrigerator Logo
374 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
