Question about Canon MultiPASS MP390 All-In-One InkJet Printer
1" wide shaded line is appearing in center of scans
When I scan, I am getting about a 1" shaded line down the center from top to bottom. The light looks good, so either there is some light effect that started that I can't see or the pickup of the scan is bad. Is there any solution or has the printer met its end-of-life?
  • 22 Answers
May be the scanner issue go to the authorised service centre do will do the needful
Posted on Mar 05, 2009
Shade stuck under sunroof
this is touchy...... FLASH LIGHT .... needle nose pliers..... 2nd person.... to hold flash light.... look inside under the ROOF LINER see is there is anything blocking SUN SCREEN if not them attempt this carefully .... person with pliers pick the center of where the SUN SHADE is reach in carefully with the flashlight shining where the pliers is... the pliers see if you can cover them with DUCK Tape to protect the shade grab shade and start to pull it out... watch both sides in case it gets stuck as your pulling it out from under roof liner... good luck
Apr 16, 2014 | 2004 Chevrolet Tahoe
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
The top half of my pictures with a flash are shaded.
Not seeing the pictures I have to guess. If the shade you mention is not like a straight line, but more rounded, try making the picture without the lens hood. Or use a external flash, when you use another than the standard lens. I don't think you can take a picture in manual, with a shutter speed above 1/250 second, because in such case the top or bottom part could become shaded then, but then the shade is in a straight line from left to right.
Dec 26, 2013 | Nikon D3100 Digital Camera
Samsung un55d8000 shaded area bottom of screen
That is not a good sign. Since a TV screen utilizes what is called scanning lines and the data starts at the top zips side to side until it reaches the bottom; so fast you cannot observe that sequence; the same digital lines should be equal all the way from the top to the bottom. When any variation occurs (such as what you have mentioned) the lower light emitting diode rows are compromised. In a sense these lines are working at 1/2 capacity. This could be an issue with the controller and/or other devices on the circuit board. The company Samsung has a technical service department and a technician should be able to test out the problem described. If it is under warranty, have them replace it. It will only get worse in the future.
Dec 19, 2013 | Samsung UN55D8000 55" 3D LED 240Hz 1080p...
Got the wires mixed up on the distributor cap on my honda accord 2.3 L
1,3,4,2 is the firing order. Look at distributor and picture an imaginary line in the center of it from top to bottom 1 is top left, 3 is top right, 4 is bottom right and 2 is bottom left. There are ony four possible combinations if you mix up the top and bottoms .Write down on a piece of paper how you set them up in the event you get it wrong you can try it a different way. I don't know whybut currently I can't get a picture of this to you .
May 06, 2010 | 2000 Honda Accord
1/3 OF RIGHT SIDE OF PAGE DARK OR LINED TOP TO BOTTOM
Drum Cleaning Blade failure. Open up the top half of the machine as if you were removing a paper jam. Now look under the top half and about in the center from left to right. You should see a burgundy colored cylinder running from the front of the machine to the back. If you can see the toner streaks on the surface....expecially on the 1/3rd like on the copy then this will be proof that the drum cleaning blade is the cause. Simple repair for a tech that knows copier basics. A good estimated cost would be about $25.00 for the blade and whatever the going rate is for a service call in your area.
Jan 28, 2010 | Minolta EP1083 CS/PRO Copier
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Is there any debris under the printhead nozzle plate?
Jun 22, 2008 | Epson Stylus Pro 4800 InkJet Printer
Line down the center from top to bottom, 1/2 inch very light , NOT folded.
hi swan.. i am doing some homework on this i got a similar set today.. will get back to you shortly
Mar 13, 2008 | Televison & Video
Accurate color
Digital cameras rely on "white balance" to control total overall color accuracy as processed for the final image. Colors are greatly affected by light. For example, look at any wall in your home or office and you can easily see that shadows will make the color of the wall appear to be different shades. Sunlight has a very different effect on colors than incandescent light or florescent lights. Digital cameras start with white (the absence of color) to measure the effect of light and adjust the metering (measurement and accuracy) of all the other colors. Of course, white in a poorly lit room may appear gray or even yellow to some digital cameras. So how can you get accurate color? 1) Turn the Mode Dial to MANUAL MODE (Red camera icon with an "M") 2) Use the Arrow Down on the ENTER Button to select W/B (White Balance) 3) Press the center on the ENTER Button to select and adjust W/B (White Balance) 4) Use the Arrow Right (once), then Press and Hold the Arrow Down. Note: Continue to Press and Hold the Arrow Down. There will be a pause as you reach the bottom of the common preset conditions. Then a new "hidden" option will appear. 5) Once PRE SET appears, Press the center of the ENTER Button to select it. 6) A Special screen will appear. Point the camera direct at something WHITE, like a piece of paper, a white wall or a white shirt. Regardless of the lighting conditions, the camera will accept this "white object" as the new starting point "base of reference" or "True White". 7) Press the Shutter Button to program the new "True White" setting. 8) Press the center of the ENTER Button to accept and continue photography. These new settings will be saved as PRE SET True White conditions in Manual Photography Mode until you change the settings with another selection. This will not "go away" when the camera is turned off. These settings do not impact Auto Photography Mode.
Sep 11, 2005 | Toshiba PDR-3330 Digital Camera
Accurate color
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
old marine
old marine
