Back to:
Tags:
Toshiba Gigabeat MEGF40S  MP3 Player
Toshiba Gigabeat F40 MP3 Player (by 4 users)
posted by chervey on Jul 04, 2007
I have a Toshiba Gigabeat F40 MP3 player that turns on, but sticks at the timezone screen. It seems as if it's stuck in Hold mode, but the hold button is not turned on. The only way to turn the unit off is to turn off the battery button on the bottom of the unit. When it started having problems, the unit would scroll quickly through the selections, but would not stop or let me make a selection. I am thinking the control buttons are not working. Is there a way to open this unit and check them. I could also reset the unit if there is a way to do that!?!?
Thanks for any advice you can offer,
Cindy
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by Guest, posted on Sep 09, 2008
i have the same problem too
Comment by braulioba, posted on Sep 08, 2008
i have the same problem to can u plz help me???????
Comment by mac530, posted on May 21, 2008
i am having the exact same probs with mine. have you found a way to unfreeze yours yet?
Best Solution
posted on Apr 18, 2008
FixYa! (100)
Lapoot
Rank:Apprentice Apprentice
Rating: 100%, 2 votes
My experience is that sometimes the battery swells up and puts pressure on the keypad, causing it scroll. Get a new battery and the scrolling stops....
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Toshiba Gigabeat F40 MP3 Player:
I don't want to Accept this solution
Solution #2
posted on Sep 02, 2007
FixYa! (100)
gangulee
Rating: 85%, 2 votes
Hi1 I have exectly the same problem and i try
so many times the battery button of but still have the same problem
any further idea or solution will be appriciated
thank you
gangulee
Thank You!
Solution #3
posted on Nov 24, 2007
FixYa! (100)
Guest
Rating: 0%, 0 votes
I had the same problem with the continuous scrolling. I thought it was a sticky key. I opened the face of the unit and clean out the dust. Problem fixed.
Getting the unit opened can be tricky. You have to carefully remove the plastic pieces from the top and bottom of the unit. Try to gently pry out one edge and it will lift off. You will need a tiny phillips head screwdriver. You only need to remove the top two screws and the face plate can be removed.
Warning: Once the plastic piece is removed from the bottom, the switch that turns the battery on/off can easily fall out. Keep and eye on it.
Thank You!
Solution #4
posted on Jul 14, 2007
Thanks for Trying (70)
eman711
Rating: 74%, 7 votes
You can reset by turning the on/off switch at the bottom of the unit to the off position and then back to on. I would wait about 5-10 seconds in the off position before turning it back on. This actually turns the battery off and then back on.
Hope this works for you.
Eric
Thank You!
Solution #5
posted on Feb 27, 2008
Not Rated (0)
conwaymike19
Rating: 0%, 0 votes
I had this problem for my For my MEGF20 gigabeat. While the face plate is removed (see instructions for cleaning dust out from around the key area as described by another member), see whether the front panel itself is putting pressure on the keys and causing it to scroll. I pressed the panel gently from the inside with my thumb where the key slot was so it bulged out slightly. This seems to help.
Thank You!
Can you Help with these MP3 and Digital Media Players problems?
Toshiba Gigabeat MEGF40S (40 GB) MP3 Player
hola! tengo un toshiba gigabeat f40 pero le di formato y...
Aparentemente mi equipo tenia un virus, lo formatee y...
I've had my MEGF 40 for almost two years and recently got...
Is there a connection device available to connect a...
My device needs to be reformatted according to Napster. My...
Loading problems.
Repair Service
Find MP3 and Dig. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
