Fuse rating on the motherboard
  • Computers & ... Master
  • 5,660 Answers
A) Didn't know there was one. A fuse.
Unless you are talking SMD fuses. (Surface Mount Device. And they are also SMT. Surface Mount Technology)
B) Kinda' hard to know without the manufacturer name, and model number of the motherboard. But, the motherboard would have to be sitting in front of me, to determine the rating of the SMD fuse, anyway. (IF, this is what you are referring to)
If it is a gamer motherboard perhaps a fuse was used in the power circuit of the motherboard.
Again, do not know what motherboard you are referencing to.
Post back in a Comment.
Regards,
joecoolvette
Posted on Jan 11, 2013
I have an asus n550jk laptop the motherboard video fuse has blown does anyone know where to get a replacement fuse and what rating it should be
I've been debugging various backlight brightness problems lately, and I've learned a lot in the process. First lets take a look at how all the bits fit together. There are 3 parts involved in changing the brightness:
  • Detecting brightness up / down key presses
  • Processing the key presses
  • Controlling the actual back light
  • http://hansdegoede.livejournal.com/13889.html
    Jan 13, 2017 | ASUS Computers & Internet
    I need to know the value of the fuse and the type
    Try this website for more information on resistors: http://www.dannyg.com/examples/res2/resistor.htm
    If you are literally meaning fuse, look on the side: somewhere on the metal it will have the size and rating stamped.
    May 13, 2011 | Computers & Internet
    My wii will not work the wires are plugged in but the light is not on it was working fine yesterday but it wont work now please help
    Try your wii power supply in your friends' house. If your power supply didn't work on your friends wii, Buy new power supply. If it worked on your friend's wii then your wii is dead. Call Nintendo to take care of it. If you dont have a warranty, do it yourself. Take out the motherboard and google Wii FUSE. Chage the fuse. If you don't have the fuse, use soldering iron and join the palce you place the fuse together. If that didn't work again, Replace the wii motherboard. Trust me your wii will work this time and your MII you created will still be there because they are all on your harddrive not wii motherboard.
    Rate if this helped you.
    Apr 12, 2011 | Nintendo Wii Console
    Help me please i have problems with my sistem x-530 logitech!!! i need to change the fusel i dont know
    The speaker is designed for computer and not designed for playing at loud volume. Sound like you have blown a fuse, check the fuse on the back of the subwoofer and replace it with the same rating fuse. The speaker are only rated at 2 to 20 watts max, with the sub at full volume it did not have the power required to produce the sound thus blowing a fuse or burned out. The bass is the most power hungry of all the frequency, if you are using 5 watts and the note spikes to double your amp has to have 50 watts of power to produce the sound. Hopefully it was only the fuse, good luck.
    Mar 14, 2011 | Computers & Internet
    What is the fuse for this subwoofer Altec Lansing ACS 300.1 ?
    The fuse is for the amplifier. The fuse will tell you the amp rating on it. If the amp for some reason gets a power jump or if something fails the fuse will blow and save your amplifier from getting damaged. Do not put a higher rating fuse in there this will only damage your equipment. It will not make it louder.
    Mar 12, 2011 | Computers & Internet
    I have no VGA signal. I think the fuse is damage. Where is it placed on the board D845GBV from Intel?
    Please remove the cmos battery,
    And install it again,
    Please click on the bellow link for details.
    http://www.fixya.com/support/t7838152-display_problem
    It is same problem, already I have told .
    Hope this helps.
    There is an rate option "Was this helpful?" Yes or No.
    If you are helped you can rate ,that is your choice.
    Jan 16, 2011 | Intel Desktop Board D845GBV Motherboard
    Using a T1.6AL fuse it blows in my JVC XV-N316 DVD Player. I wonder if the fuse should be a 6A fuse and not 1.6A?
    only replace a fuse with smaller rating never larger,if it keeps blowing out some componet is shorting
    Jan 08, 2011 | Computers & Internet
    Epson 7550c projector - ELPLP07 lamp fuse.
    Have a nice day!
    We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
    wheel,
    motherboard, powersupply ... with high quality and competitive price.
    Lampdeng Limited
    Jerry
    Oct 04, 2009 | Epson 5550c / 7550c Replacement Projector...
    Keyboard is dead how do you check for the fuses in kw3500 casiop
    First I would check to ensure it is the keyboard and not the port on the motherboard. Get a working keyboard and plug it in if it works then you know it is the keyboard and not the motherboard.Turn the keyboard over remove the back cover and check for a fuse in the +5VDC. Just as a hint: on these types of keyboards the fuse will blow if you unplug or plug it in with the power on...if changing the fuse does not fix it then the motherboard has to be replaced as you cannot change the port. Let me know if you have any questions.
    Don't forget to rate this solution before you log out.
    Feb 04, 2009 | Casio WK110 Portable Keyboard
    Computers & Internet Logo
    49 people viewed this question
    David Payne
    David Payne
