Question about Ovens
I have a Simpson Riviera upright oven & stove top, there is no model or serial number .The oven element is fixed & not working, everything else is.It is not a fuse problem. Do I require a service man & is the element available /
ranger25
  • 72 Answers
SOURCE: GE Oven bake element not work
It sounds like a problem with the selector switch. You have to remove the back panel to get to the back of the switch in the head unit, and find what wire goes from there to the bake element. With a meter set on 240ACV, or whichever setting is on yours that's HIGHER than that i.e. 400ACV, with the red probe on the terminal and the black one going to ground, see if you are getting 210-240 through it. If so, then it's either a faulty neutral wire connection (the other wire coming out of the element) or the selector switch. Hope this helps.
Posted on Jan 29, 2008
  • 8 Answers
SOURCE: stove works, oven does not
in repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
Posted on Oct 11, 2008
  • 6 Answers
SOURCE: Hi my Fisher & Paykel Paprika stove (Model
Yes the regulators/simmerstats are stuffed but are not hard to replace...but please turn off the power 1st when removeing the backing plate as you will kill yourself....yes you will.
Use a multimeter set on volts ac or a volt detector stick, test tester on a known live sourse 1st like a power point....switched on
Posted on Sep 13, 2009
  • 3 Answers
SOURCE: simpson 2001 series upright electric stove oven does not get hot only gets warm
It could be the oven element (behind the cover plate in the back of the oven), or the fan not blowing the heat into the oven.
Posted on Feb 22, 2010
  • 250 Answers
SOURCE: Simpson Apollo can't set clock so oven won't work
I don't know if this will help. For the 720ef , this is what you need to do.
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
TO SET THE TIME OF DAY
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
TO SELECT AN ALARM TONE.
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
SETTING THE MINUTE MINDER.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remaining time.
If you want all the information, then it is best if you supply a vaild email address and this will give you access to my BT Digital Vault, where you can have a complete copy of the handbook that I have scanned in.
Posted on May 29, 2010
My electolux superba convection oven is not maintaining it's temperatures?
Heating elements cold be going bad look at them with a flashlight if either of the elements look thinner than the rest of it then it needs replacing before it goes out completely. With aloud bang a bright arc flash and smoke. Very scary. There's a metal tag on the inside of the oven door jam.write the model and serial number down. Shut off the circuit breaker for the stove should be a 50 amp double breaker. Remove 2 small 1/4 inch screws. Slide the element out straight to you. Remove the 2 wires with the same 1/4 inch nut driver keeping the wires separated .Do Not turn on the circuit breaker till the new elements are installed! !! Use the model and serial number to get your new elements first.
Sep 26, 2014 | Ovens
What are the dimensions of a Simpson 2001 wall oven
4 burners. 540mm wide x 600mm. Oven is 1040mm high at rear and 890mm at front. Good condition. Only selling because I am upgrading.
Just to confirm is youre stove a Simpson Riviera ?
I hope this helps
Feb 20, 2012 | Ovens
The inside oven is not heating. The top burners are working fine.
If this is an electric oven, most likely the oven bake element has burnt out.
the model and serial number should be behind the bottom drawer,
most elements are held in with (2) 1/4 inch socket hex head screws.
Remember to unplug stove or shut off breaker before servicing.
The element can be slid out usually, then unplugged or remove
the back cover behind stove and unplug it from the wiring harness.
I hope this is useful
Aug 02, 2011 | Tappan Ovens
The oven will not heat up. model # RF315PXEW serial # RG3219362 i was cleaning it and the top element( where the connector slides onto the element) touched the back of the stove and created a spark. i...
Test element for continuity first and if it has continuity you need to look elsewhere, possibly at they switch or thermostat as you said you shorted it out, let me know after you have done continuity and i will help you further if required, David "The Famous Forry"
Sep 30, 2017 | Whirlpool Ovens
I need a baking element for the tappen oven model number 486847a. The stove serial number is VF41807648. Can you help
Go to www.ukwhitegoods.co.uk you will need the model number and serial number and place an enquiry. They will get back to you.
hope this is helpful
John
Jun 05, 2011 | Ovens
I have a Simpson electric oven with stove top elements, and one of the burners will only cook at the highest level, I cant figure out how to change it, any suggestions?
You need to change the "Simmerstat", take the model number to your local electrical parts supplier/parts counter at your local stove retail shop that sells Simpson stoves and ask for one for that model, make sure you get the right one for the position as some control a single element and some control dual elements.
*** TURN OFF THE WALL SWITCH AND ENSURE NO POWER IS APPLIED TO THE STOVE BEFORE PROCEEDING ****
Remove the upper back panel of the stove. Swap wire for wire of the old simmerstat to the new one, remove the knob from the old Simmerstat, undo the nut securing the simmerstat in the oven control panel and discard, fit new one, secure, fit knob, fit back panel, turn on wall switch and test.
Some countrys/states require registered electricians perform this task on electrical appliances so you must ensure you can do this legally before you start and take the relevant safety precautions and don't electrocute yourself.
Apr 13, 2011 | Ovens
Magic chef oven does not work
Stove top works but oven does not light. This is an electric spark ignition unit.
Sep 07, 2008 | Ovens
Simpson 2001 series upright electric stove oven does not get hot only gets warm
Aug 19, 2008 | Ovens
Ovens Logo
135 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
