Question about Whirlpool Duet GHW9150P Front Load Washer
F 21 problem whilpool duet washer
We bought our whirlpool in dec. have run 7 lds through it the seventh load was last night before bed when I came down stairs there was a electrical smell coming from the washer and it was flashing f21 it had'nt drained I hit cancel 2 times power off unplugged it checked the hose clogs or kinks but there was nothing I could blow air into the cylinder, then plugged it back in turnt it on put it on drain/spin it just sat there counting down until it finally came up with f21 again, as these machines faulty in some way or is this machine just a fluke...could using an extention cord, or any thing else have cause a problem like this?
    Novelist:
  • 101 Answers
F21 has to do with your pump. These machines have had problems with the pumps since the beginning and it is something that needs to be fixed. With these front loaders you have to make sure every time you use it to check that front bellow boot and make sure there is nothing left in there from the wash. Socks and under ware like to hide out in there and will eventually get sucked down into the pump causing your machine to not drain. Coins and anything else left in pockets are a big nuisance too. They will get down into the pump and cause the motor in the pump to jam up. If you remove that bottom panel you will see the pump there. Clamp off the hoses with two hose clamps and remove the pump. Look inside the pump and whatever is in there take it out with a pair of needle nose pliers. This should fix your problem. Just make sure you remember to always check that bellow boot after every wash and always make sure pockets are empty. Let me know if you have any other questions and let me know if this was helpful for you. Good luck and I am glad that I could help.
Posted on Jan 22, 2009
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Six year old Whilpool Duet washer on pedestal and level front and back still vibrates excessively and makes loud noise when spinning water out of machine. Is sitting on concrete floor. Have owned since new...
check the inner struts on the bottom of the tub you need to remove the front panel some have a split lower section so you can access inside where the struts are also check that the struts are not worn out hope this helps
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150PW1 very noisy when spinning
its most likely bad bearings and basket. usually it happens over wear and tear or overloading.
May 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control locked is on, how do i unlock it ?
I think you're on line. Okay, power shd be on, see that button 'end of cycle' on the right side of your panel? Hold it down for 3 seconds. You'll be ok. Dont forget to rate, its a way of saying thk u!
Mar 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet squeaks
you can call whirlpool at 800-253-1301 and they will set up and recommend a service company that is authorized to repair your unit. just let them know its less then a year old and they will get you taken care of.
squeaks are hard to find, but you need to get it set up before your warranty runs out.
Jan 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer has done GREAT for two years..now suddenly,
this means your drain pump is clogged--- there are 3 screws at the bottom of the lower front panel. Remove these screws and there is a drain pump cleanout located in the middle. Twist this off by hand can clean out the debris--- WATCH OUT LOTS OF WATER will come out so have towels ready.
Jan 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Old whirlpool washing machine won't run.
Need the Model # from the unit open the lid if it is a top load look at rear where lid closes to on the rim
Oct 12, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
101 people viewed this question
Dan Webster
Dan Webster
Sal De
