Question about Water Heaters
How do I replace hot water pop off valve?
I have slight leak at bottom of pop off valve. how do I replace ?
  • 51 Answers
Shut off water,gas or power
Then drain about half of the water from the heater.
The pop off valve unscrews from the tank.
Some times its rusted really bad and will break off because its soft bras. If that happens then get a inside the pipe pipe wrench and try remove the broken valve. If that fails then you need a new water heater.
There are a few types of valves some are lomger than others and some have a 90 degree turn. best thing is to get your old one out(if posible) before you buy the new one so you get the right one.
Good luck
Posted on Jan 12, 2013
WhoDoctorK9
  • 41 Answers
SOURCE: the pan at the bottom of the water heater is
Now, the pipe that leads from the base water pan should lead to the wall where the water can go outside. If you see water in it, but very little in the pan, then you have water from outside (rain or water hose) coming inside the house. You should have a valve, usually on the side of the water tank near the top that looks like brass with a silver 'flip' handle on it. There may be some plastic pvc pipe attached to it as well. If the water is coming from this valve then you need to have the valve replaced. You may get some extra time by gently tapping the valve where the handle is attached with a mallet so that the valve seats itself. This valve is a pressure release valve. If the water in the tank gets too hot or water pressure gets too high, this valve will open to relieve that pressure. it doesn't happen often, so if this is the first time you have seen it and it doesn't seem to be leaking any more, I would not worry about it. If it is still leaking, you can get a replacement relief valve from your local Lowe's or hardware/lumber yard. They usually cost less than $20 USD
Posted on Mar 29, 2009
  • 686 Answers
SOURCE: Relief valve constantly releasing water.
lower your thermostats a bit. If your temperature is set to the hottest setting, then chances are no relief valve will do
Posted on Jan 08, 2009
gary1121
  • 332 Answers
SOURCE: how to check thermstat pop off valve starts
you might want to check the water pressure going into the unit, it should only be no more then 75lbs anything over that will make the top pressure valve blow off
Posted on Jun 27, 2009
  • 35 Answers
SOURCE: pop off valve dripping Rheem 50 gal electric valve at bottom
If you are reffering to the drain valve at the bottom of the hot water tank. It may be leaking due to the O ring being cracked or worn out. You can either drain the tank and replace the valve or you can buy a hosebib brass cap and thread it on the existing valve. There is no cause for alarm when doing this as this valve is just to drain the tank when replacing your hot water heater
Posted on Feb 25, 2010
  • 409 Answers
SOURCE: leaking pressure relief valve
what is the water pressure on the cold side? You may need to install a pressure reducing valve at the water heater inlet to reduce inlet pressure and keep pop off valve from opening when not needed.
Posted on Mar 10, 2010
Natural gas water heater pop off valve leaking even after replacement
This is unusual. The first thing to ask is what is the water pressure reading at your location? It could be too high. That would cause the valve to be close to opening and leak. The second could be something to do with the thread area that the valve screws into. What is the age of the heater and has it ever been dropped or damaged? Third is how hot is the water temp?
Jul 18, 2017 | Water Water Heaters
My hot water tank is continually leaking ? I shut off the valve at the top of the tank and it is still leaking ??
They wear out especially if they are older. You did not say what make and model it is but if there is water coming out the bottom it is time for a new unit. The leak is still happening because even though there is not supply pressure, gravity is pulling the water out the break in the liner.
Jul 05, 2016 | Water Water Heaters
Water meter is ticking away. No sign of water or
If you have a gas hot water heater, water may be dripping onto the baffle plate at the bottom and vaporizing whenever the burner fires. There would be no evidence of water under the heater in this case. Yes, I speak from experience. Also check exterior sill cocks for leakage as one might be open just a tiny bit. If you wait for freezing weather, a leaky sill cock will grow a "beard" of ice.
Oct 30, 2013 | Rheem Water Heaters
Premier Plus Model#MHE62-30H-045DV Ser#45T421608 I just purchased this hot water heater.I had it professionally installed by a plumber.We had hot water before I went to bed but when I woke in the morning...
sounds like you have a power problem. or worst than that a leak . So lets look at the leak first. Turn off the water supply at the water heater on top. This valve should be on the cold side of the heater on top.
Turn it off, check and see if you have pressure in the house by turning on a faucet. It should run for a second then stop. That is good if it does. Leave the valve off on the heater and check that your breaker is on. Reset the breaker by turning it on and off.
Wait about 2 hours turn the heater back on and check to see how hot the water is hot then you might have a leak in the building. If there is not or little hot water. Check the wires where it connects to the water heater. You might only have one wire that is connected right.
The best thing to do is to get a amo meter and check to see if you have 220 if you dont have 220 you will not warm up the water the way it should.
Thanks Richard
Sep 07, 2011 | Premier Water Heaters
Hot water heater is constantly runnin and sds like water is running. the noise seems to be coming from the emergency valve area. there is water pooling around the bottom of the heater
Open following link to identify specific leak and remedy:
http://waterheatertimer.org/Water-heater-is-leaking.html
If TP valve is leaking: replace TP valve:
http://waterheatertimer.org/How-to-replace-TP-valve.html
If tank is rusted and ready to rupture, then turn water heater off:
Over next days, turn water heater on for short periods to make hot water when needed, then replace water heater.
http://waterheatertimer.org/Emergency-steps-for-leaking-water-heater.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 19, 2011 | RELIANCE ELECTRIC WATER HEATER
Pop off valve keeps popping off and makes hot water run all the time
Is the water extremely hot?? If so, then I would probably recommend new thermostats for top and bottom of the unit. The only time these temperature related overflows are activated is when the water temperature reaches a certain temperature and they are there to safely relieve the pressure/temperature so the unit doesn't explode.
If water is not terribly hot from normal, then I would say the TMP valve ( the valve that you are referring to) needs to be replaced and can be done easily by turning water off, and picking one up at any home improvement store for your model and just unscrewing the one you have out, putting on pipe thread sealant on new and rescrewing the new TMP valve into the tank.
Good to go after that,
Let me know!
Chip
Apr 11, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Pop off valve dripping Rheem 50 gal electric valve at bottom
Feb 23, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have a propane hot water tank that in discharging the hot water out the relief valve (Champion energy saver series)
possible problems not knowing age of unit the
control valve could be sticking open allowing gas to continue to flow until high limit is reached and shuts down valve another possible problem with the newer style back flow preventer being install by water companys the rapid heating and expansion of the water over pressures the water system causing releif valve to pop open and reclose most water heater manufacters are recommending instalation of an expansion tank to allow the growth in volume of water somewhere to go is valve constantly leaking or only during heating cycle if you could supply additional information does unit only leak when heating
or is steam expelled when releif valve opens
t-stat not opening gas valve sticking partially open
bad high limit bad pressure releif valve no expansion tank to allow for thermal expansion if steam is present and unit is boiling water inside replacement of water heater for safety concerns,would be reccomended if only water and pops couple of times water temp not over 140 degrees after most hot water has been used out of tank and is reheating most of capacity probably lack of expansion tank as the releif valve is the final safety device on a water heater is of great concern
the temp control gas valve or high limit are supposed to shut unit done long before the safety limit of releif valve is reached
Dec 11, 2009 | Water Heaters
Hot water tank shuts down after5 minutes pilot still on water
Carefully catch some water in a container from pressure relief valve (pull lever slightly) at top of tank, and see if it's up to temperature. If it's hot there, I suspect your by-pass at back of the tank, is faulty. Depending on what by-pass system your using, it may be in wrong position, blocked, or mixing hot and cold. Cold water flows into bottom of tank, and hot out the top. If any valve in between the 2 lines, close it, and make sure valves in and out of bottom and top are open. Let me know what you find, or if water from pressure relief valve is not hot either.
Jul 12, 2009 | RTO Atwood Water Heater - 6 Gal LP
Leaking tp valve
It is time for a New Water Heater.....But there are a few steps you can take to "TROUBLE SHOOT" the situation. There is a Drain Valve at the Bottom of the Water Heater. You may have a build up of ....gunk...at the bottom of your water heater, if you have a floor drain in a basement or some way for the water to drain, than you can carefully loosen the drain at the bottom of the tank to FLUSH the tank.....The other option will still reqiure draining the tank and replacing the heating element.. My best Solution is to make sure the bottom of your Mobile home is Insulated Properly From the Wind and Elements. Even Bails of Hay stacked around your Foundation Can be VERY Effective.....MOSTLY THOUGH I THINK IF YOU DRAIN THE TANK AND REPLACE THE HEATING ELEMENT, your problem will be over, With proper Insulation under the Mobile. This has worked for me a few times..... Hope it helps.....Joe
Jan 10, 2009 | Water Heaters
Water Heaters Logo
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
