Question about Yamaha RX-V1600 Receiver
Unit won't power on - Yamaha RX-V1600 Receiver
Cd player won't open and won't power off.
This means that something in the mechanism is jammed. It keeps on trying to correct for the misalignment- a service technician will need to see the unit.
Dec 08, 2012 | JVC XL-FZ258BK 5-Disc CD Changer
What's your problem?The horn won't work, the light that is supposed to go on when you open the doors won't work, the cigarette lighter won't work, and the head unit won't work
on 1987 all you mentioned are on same fuse #11 located in fuse box below steering wheel 3rd row 3rd fuse from left next to either a blank space if you do not have power windows,or next to silver circuit breaker if you do have power windows.
May 23, 2012 | 1987 Chevrolet Camaro
My sgx is locked up and won't do anything - won't
Remove the battery and the unit will shut down. Wait 1 minute, install battery and the unit should power up and work as normal.
Sep 18, 2011 | SkyGolf SkyCaddie Handheld GPS Unit
My samsung s3600 won't turn on. I charge it but it won't open.
maybe the problem that sir, is the flex bcoz the connection of the power on, came from flex,if the flex damage it result you can't power ur unit..better change it, flex for s360. gudluck
Jul 27, 2011 | Cell Phones
I have a 1992 mecrury sabe sw that i'm trying to put a new head unit in. i took the stock radio out and disconnected the wires and power cord but now the new head unit won't turn on, the stock...
check here and make sure that you have power coming into the harness, if not back track it to the fuse http://www.installdr.com/Harnesses/Ford-Wiring.asp you want to look at this one Standard 2 Piece Harness Up To Late 1990's
Jul 19, 2011 | 1997 Mercury Sable
Won't power up. Fuse not blown. Q5101 was blown, but I have replaced it. No joy.
when you say won't power up, does it mean there is no indication of light whatsoever on the unit? If yes, then it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
Let me have a feedback if you need more info or help concerning this issue.
Yours sincerely.
Elect_Comp.
May 12, 2011 | JVC SRV101US S-VHS VCR
Player won't come on
when you say won't come on, does it mean there is no indication of light whatsoever on the unit? If yes, then it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
Yours sincerely.
Elect_Comp.
May 12, 2011 | Sony BDP-BX37 Player
Yamaha RX-V1600 Receiver Logo
29 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
