Question about KDS K717s 17" LCD Monitor
Shadows All of the sudden everything on the monitor words, pictures,etc. has shadows
    President:
  • 2,692 Answers
Have you tried to substitute another monitor to confirm it is the PC and not the monitor?  If yes  then:
Start by check the video card and drivers. Take it out and reinsert it .Reinstall softwae and drivers.  Another option: Restore computer to a time before the problem started.
Posted on Jan 22, 2009
HP w19b "shadow"
OSD has no shadow shows monitor itself is OK and problem is in cable. Barrow a cable from friend and confirm the result.
Regards,
Sep 02, 2008 | HP Computers & Internet
My hitachi big screen has red shadows on picture how do i fix it
What you described sounds like a convergence problem. When convergence has failed the colors will commonly look 3D,warped, etc. This tips page here on Fixya has more details.
Jan 27, 2013 | Hitachi 43FWX20B 43" Rear Projection...
I have a lg flat screen monitor, the words are blurred
Is it just the fonts that are blurry, or everything? If fonts only, then this almost certainly suggests that running the ClearType tuner again would solve the problem. But this applies to all displays, so if one is good and the other is not, then this isn't it.
If everything is a little blurry, then this suggests one of two problems -- the first, you report trying, which is that the display adapter is set to a different resolution than the native resolution of the LCD monitor itself. Your display adapter should probably be able to drive 2 monitors (the built-in laptop monitor and the external monitor) at once. You should be able to set their resolutions separately.
Assuming Windows XP: Start > Control Panel > Display > Settings > at which point, you should see two monitors listed in a dropdown. Set them to their native resolutions there (using the slider bar, usually all the way to the right), and save.
If you do have the display resolutions set to their native resolutions for both monitors, then it's possible that your external monitor is messed up. A quick test would be to run the on-screen settings, usually from a button on the monitor itself. If what is displayed there is sharp and what is displayed from Windows is not, then this points to a problem with the display driver. If everything, even the on-screen display is blurry, then perhaps the monitor settings are messed up -- usually there's an option to restore to factory settings -- try that.
Apr 02, 2012 | LG 22" FLATRON LCD Monitor
WHY DID MY PICTURES LOOK DARK WHEN I TOOK THEM OUTSIDE USING THE AUTOMATIC SETTING?
Was everything set automatic?
Was it a cloudy day?
Did you take pictures in the sun of an object in shadow?
Are your indoor pictures normal?
If you are sure everything was OK, no shadows, no bright objects in the picture, ISO was not set 400, flash was not forced on, etc., call Canon. There are adjustments that calibrate the camera for outdoors. It may need to be recalibrated.
Apr 02, 2010 | Canon EOS Rebel T2 with 28-90 lens 35mm...
Monitor display is blurry, with shadows and waves next to text
Jnanda,
Could be one of two related situations both have to do with built up magnetic flux:
!. If you have used the monitor for a significant amount of time and have never degaussed it that might be it.
To fix: Go to where your monitor's controls are (eg screen size/position, Brightness, Contrast, etc.). Providing that we are referring to an older style monitor (like a TV) and not a flat screen, you should find a degaussing button located there. This button is marked with a depiction of a horseshoe magnet. Press it.
If you have on screen settings control, hit the menu button and select the icon that looks like a horseshoe magnet.
You'll hear a buzz and the screen will go kooky for a moment.
You're then degaussed. Your problem should go away.
2. You may have moved the monitor close to a source of electromagnetic interference (or vice-versa) this will also cause that sort of thing you describe (remember that there are electrical lines in the walls (another source of EMI)
In that case move the monitor away from the EMI source or move the EMI source away from the monitor.
Remember that it could be both 1 and 2. So if the problem lessens but does not go away fully try both steps.
Feb 06, 2009 | Dell E173FP 17" LCD Monitor
Shadow images on monitor
if it is vista it is normal otherwise I would need more info operating system video card monitor etc.
Dec 03, 2008 | Computers & Internet
RCA 56 inch hdwidescreen
Did you use the Automatica Convergence to try and straighten it out? If that does not help, you can manually adjust the convergence.
Jul 12, 2008 | RCA HD56W58 56" TV
My monitor is monkeying around
The problem is with your Memory IC. Replace it.
Dec 04, 2007 | Gateway FPD2275W LCD Monitor
Picture problems
My computer did this and I think my TVs just gone the same way. Was definitely a loose connection somewhere. In the computer monitor it was because the pins in the plug were slightly bent and if I moved the wire the picture got better. In the end I had to replace the connecting cable
Mar 17, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
KDS K717s 17" LCD Monitor Logo
63 people viewed this question
Top KDS Computers & Internet Experts
Denise
RobertFonner
RobertFonner
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
